root/radiance/makeall
Revision: 1.24
Committed: Sat Oct 31 22:29:06 2009 UTC (15 years, 11 months ago) by greg
Changes since 1.23: +13 -61 lines
Removed outdated operating systems and updated OS X entry
1 #!/bin/csh -f
2 # RCSid $Id: makeall,v 1.23 2008/04/17 14:58:57 greg Exp $
3 #
4 # Make all the Radiance programs
5 #
6 if ( $#argv < 1 ) then
7 echo "Usage: makeall install [clean] [make options]"
8 echo " or: makeall clean"
9 echo " or: makeall library"
10 exit 1
11 endif
12 if ( "$1" == library ) then
13 source installib
14 cp -f src/*/*.{cal,tab,hex} $ldir
15 echo ""
16 echo "Set the environment variable RAYPATH=.:$ldir"
17 echo 'For C-shell users, put the following into ~/.cshrc'
18 echo " setenv RAYPATH .:$ldir"
19 echo 'For Bourne shell users, put the following into $HOME/.profile'
20 echo " RAYPATH=.:$ldir"
21 echo " export RAYPATH"
22 echo ""
23 exit 0
24 endif
25 set srcdirs=( common rt meta cv gen ot px hd util cal )
26 if ( "$1" == install ) then
27 cat << _EOF_
28
29 `cat src/rt/VERSION` INSTALLATION
30
31 This script rebuilds all of the Radiance programs and installs
32 them on your system. You should read the file README before running
33 this script. You can type ^C (followed by return) at any time to abort.
34
35 You must first answer the following questions.
36
37 _EOF_
38 if ( ! $?EDITOR ) then
39 echo -n "What is your preferred editor [vi]? "
40 set ans="$<"
41 if ( "$ans" != "" ) then
42 setenv EDITOR "$ans"
43 else
44 setenv EDITOR vi
45 endif
46 endif
47 again1:
48 echo -n "Where do you want the executables [/usr/local/bin]? "
49 set idir=$<
50 (echo $idir) >/dev/null
51 if ( $status ) then
52 goto again1
53 endif
54 set idir=$idir
55 if ( "$idir" == "" ) then
56 set idir=/usr/local/bin
57 else if ( "$idir" !~ /* ) then
58 echo "Directory must be relative to root, please reenter"
59 goto again1
60 endif
61 if ( ! -d $idir ) then
62 mkdir $idir
63 if ( $status ) then
64 echo "Cannot create directory, please reenter"
65 goto again1
66 endif
67 endif
68 if ( ! -d $idir/dev ) then
69 mkdir $idir/dev
70 if ( $status ) then
71 echo "Cannot create subdirectory, please reenter"
72 goto again1
73 endif
74 endif
75 set inpath=0
76 foreach i ( $path )
77 if ( "$i" == "$idir" ) then
78 set inpath=1
79 break
80 endif
81 end
82 set rmake=$idir/rmake
83 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
84 goto gotrmake
85 endif
86 set newrmake
87 more src/common/copyright.h
88 echo -n "Do you understand and accept the terms of this agreement [n]? "
89 set ans="$<"
90 if ( "$ans" !~ [yY]* ) exit
91 set special=
92 set arch=
93 set opt=
94 set mach=
95 set compat=
96 set extras=
97 set esuffix=
98 cat << _EOF_
99
100 Please select your system type from the following list:
101
102 1) Sun Solaris
103 2) Linux
104 3) MacOS X
105 4) FreeBSD
106 5) Cygwin
107 6) Other
108
109 _EOF_
110 echo -n "Choice? "
111 set arch="$<"
112 switch ("$arch")
113 case 1: # SPARC Station
114 set arch=sun
115 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
116 set opt="-O"
117 set compat="strcmp.o"
118 breaksw
119 case 2: # Linux
120 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
121 set opt="-O2"
122 set arch=IBMPC
123 set compat="erf.o"
124 set extras=CC=gcc
125 breaksw
126 case 3: # MacOS X
127 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
128 set opt="-O2"
129 set arch=Intel
130 set extras="CC=cc CONFIGURE_ARCH=i386"
131 set special="ogl"
132 breaksw
133 case 4: # FreeBSD
134 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
135 set opt="-O"
136 set compat="erf.o"
137 set extras='CC=cc MLIB="-lcompat -lm"'
138 set arch=IBMPC
139 breaksw
140 case 5: # Cygwin
141 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
142 set opt="-O2"
143 set arch=IBMPC
144 set compat="erf.o"
145 set extras="CC=gcc"
146 set special="ogl"
147 set esuffix=".exe"
148 breaksw
149 case 6: # Other
150 set opt="-O"
151 set compat="erf.o strcmp.o"
152 echo -n "Are you using the GNU C compiler [n]? "
153 if ( "$<" =~ [yY]* ) then
154 set extras="CC=gcc"
155 endif
156 set arch=other
157 breaksw
158 default:
159 echo "Illegal choice\!"
160 echo "Installation aborted."
161 exit 1
162 breaksw
163 endsw
164 source installib
165 sed 's/[ ]*$//' > $rmake << _EOF_
166 #!/bin/sh
167 exec make "SPECIAL=$special" \
168 "OPT=$opt" \
169 "MACH=$mach" \
170 ARCH=$arch "COMPAT=$compat" \
171 INSTDIR=$idir \
172 LIBDIR=$ldir \
173 ESUFFIX=$esuffix \
174 $extras "\$@" -f Rmakefile
175 _EOF_
176 chmod 755 $rmake
177 chmod 644 src/*/Rmakefile src/rt/devtable.c
178 gotrmake:
179 echo "Current rmake command is:"
180 cat $rmake
181 echo -n "Do you want to change it? "
182 set ans="$<"
183 if ( "$ans" =~ [yY]* ) then
184 cp $rmake /tmp/rmake$$
185 $EDITOR $rmake
186 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
187 rm -f /tmp/rmake$$
188 endif
189 if ( ! -d src/lib ) then
190 mkdir src/lib
191 endif
192 if ( $?newrmake ) then
193 echo 'New rmake command -- running "makeall clean"...'
194 csh -f $0 clean
195 endif
196 cd src
197 echo "Making programs..."
198 set errs=0
199 foreach i ( $srcdirs )
200 pushd $i
201 echo "In directory $i..."
202 $rmake -k $*
203 @ errs += $status
204 popd
205 end
206 if ( $errs ) then
207 echo "There were some errors."
208 else
209 echo "Done."
210 endif
211 cd ..
212 if (! $inpath ) then
213 echo ""
214 echo "Add $idir to the beginning of your execution path:"
215 echo 'For C-shell users, put the following into ~/.cshrc'
216 echo " set path=( $idir "'$path )'
217 echo 'For Bourne shell users, put the following into $HOME/.profile'
218 echo " PATH=$idir"':$PATH'
219 echo " export PATH"
220 endif
221 else
222 cd src
223 foreach i ( $srcdirs )
224 pushd $i
225 echo "In directory $i..."
226 make -f Rmakefile $*
227 popd
228 end
229 cd ..
230 foreach i ( $* )
231 if ( "$i" == clean ) then
232 echo "Removing library archives..."
233 rm -f src/lib/*.{a,o,la}
234 endif
235 end
236 echo "Done."
237 endif
238 exit 0
