root/radiance/lib/Earth.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:16 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
# User Rev Content
1 greg 1.1 {
2     Coordinate mapping for point above Earth
3     assuming uniform projection of latitude and longitude
4
5     5/1/96 Greg Ward
6
7     A1 = latitude position (degrees)
8     A2 = longitude position (degrees)
9     A3 = height above Earth (kilometers)
10     A4 = Julian date (1-365)
11     A5 = Greenwich Mean Time (0-24)
12
13     By modifying this file so that the above arguments are defined
14     instead as constants, significant gains in speed are possible.
15     (Be sure to change Su, Sv and Sw to constant definitions also.)
16
17     Y-axis points North, Z-axis points up (away from Earth)
18     }
19     {
20     Example usage:
21
22     void colorpict epict
23     7 Eval Eval Eval Earth.pic Earth.cal u v
24     0
25     5 lat long height JDate GMT
26
27     epict glow eglow
28     0
29     0
30     4 1 1 1 0
31
32     eglow source earth
33     0
34     0
35     4 0 0 -1 max_angle
36
37     where:
38     max_angle = 2*180/PI * asin(EarthRad/(EarthRad+height))
39
40     If you are really close to the Earth (below atmosphere), use:
41
42     !gensky month day time -a lat -o lon -m std_meridian
43
44     skybright colorpict epict
45     7 noop noop noop Earth.pic Earth.cal u v
46     0
47     3 lat long height
48
49     epict glow eglow
50     0
51     0
52     4 1 1 1 0
53
54     eglow source earth
55     0
56     0
57     4 0 0 -1 max_angle
58     }
59
60     EarthRad : 6378.5; { Earth radius in kilometers }
61     EarthTilt : 23.45*DEGREE; { Earth's orbital axis tilt }
62     EarthIrrad : 770 {watts/meter^2}; { Maximum Earth irradiance }
63     PA : 256/512; { Picture Height/Width }
64
65     { Change the following to constants to speed things up }
66     Lat = arg(1)*DEGREE; { Position latitude }
67     Lon = arg(2)*DEGREE; { Position longitude }
68     Height = arg(3); { Position height above Earth (km) }
69     JDate = arg(4); { Julian date (1-365) }
70     GMT = arg(5); { Greenwich Mean Time (0-24) }
71
72     GOu = EarthRad*sin(Lon)*cos(Lat); { Starting Earth position }
73     GOv = EarthRad*cos(Lon)*cos(Lat);
74     GOw = EarthRad*sin(Lat);
75
76     raduv = max(FTINY, sqrt(GOu*GOu + GOv*GOv)); { Earthwise direction vector }
77     GVXu = -GOv / raduv;
78     GVXv = GOu / raduv;
79     GVXw = 0;
80     GVYu = (-GOw*GOu) / EarthRad / raduv;
81     GVYv = (GOw*-GOv) / EarthRad / raduv;
82     GVYw = (GOu*GOu + GOv*GOv) / EarthRad / raduv;
83     radxy = max(FTINY, sqrt(Dx*Dx + Dy*Dy));
84     GDu = (GVXu*Dx + GVYu*Dy) / radxy;
85     GDv = (GVXv*Dx + GVYv*Dy) / radxy;
86     GDw = (GVXw*Dx + GVYw*Dy) / radxy;
87
88     tana = if(FTINY+Dz, radxy/FTINY, radxy/-Dz);
89
90     det = sq(EarthRad+Height) - (tana*tana + 1)*(2*EarthRad*Height + Height*Height);
91
92     a = if(tana-FTINY, b/tana, Height);
93
94     b = if(tana-FTINY, (EarthRad + Height - Sqrt(det)) / (tana + 1/tana), 0);
95
96     c = EarthRad + Height - a;
97
98     digfactor = 1 - (a - Height)/EarthRad;
99     { Global position vector }
100     GPu = GOu*digfactor + GDu*b;
101     GPv = GOv*digfactor + GDv*b;
102     GPw = GOw*digfactor + GDw*b;
103     { Earthly coordinates }
104     longitude = atan2(GPu, GPv);
105     latitude = Asin(GPw/EarthRad);
106     { Image lookup coordinates }
107     u = if(PA-1, 1, 1/PA) * (.5 - longitude/(2*PI));
108     v = if(PA-1, PA, 1) * (.5 + latitude/PI);
109     { Solar declination (lat.) }
110     Slat = EarthTilt * sin(2*PI/368 * (JDate - 81));
111     { Solar longitude }
112     Slon = 2*PI/24 * (GMT - 12);
113     { Solar position vector }
114     Su = EarthRad*sin(Slon)*cos(Slat);
115     Sv = EarthRad*cos(Slon)*cos(Slat);
116     Sw = EarthRad*sin(Slat);
117     { Solar cosine }
118     Scos = (Su*GPu + Sv*GPv + Sw*GPw)/(EarthRad*EarthRad);
119     { Earth radiance multiplier }
120     Eradmult = EarthIrrad / PI * noneg(Scos);
121     { Earth radiance }
122     Eval(rho) = Eradmult * rho;
