| 1 |
greg |
1.1 |
SETTING RENDERING OPTIONS |
| 2 |
| 3 |
The table below gives some useful ranges for some Radiance 2.4 parameters. |
| 4 |
The "min" value gives the fastest, crudest rendering. It is not |
| 5 |
necessarily the smallest value numerically. The "fast" value gives |
| 6 |
a reasonably fast rendering. The "accur" value gives a reasonably |
| 7 |
accurate rendering. The "max" value gives the ultimate in accuracy. |
| 8 |
| 9 |
Param Description Min Fast Accur Max Notes |
| 10 |
| 11 |
-ps pixel sampling rate 16 8 4 1 |
| 12 |
-pt sampling threshold 1 .15 .05 0 |
| 13 |
-pj anti-aliasing jitter 0 .6 .9 1 A |
| 14 |
-pm pixel motion 0 0 1 1 B |
| 15 |
-dj source jitter 0 0 .7 1 B |
| 16 |
greg |
1.3 |
-ds source substructuring 0 .5 .15 .05 |
| 17 |
greg |
1.1 |
-dt direct thresholding 1 .5 .05 0 C |
| 18 |
-dc direct certainty 0 .25 .5 1 |
| 19 |
-dr direct relays 0 1 3 6 |
| 20 |
-dp direct pretest density 32 64 512 0 C |
| 21 |
-sj specular jitter 0 .3 .7 1 A |
| 22 |
-st specular threshold 1 .85 .15 0 C |
| 23 |
-aw ambient weight 0 100 10 inf A |
| 24 |
-ab ambient bounces 0 0 2 8 |
| 25 |
greg |
1.2 |
-aa ambient accuracy .5 .2 .1 0 C |
| 26 |
-ar ambient resolution 8 32 256 0 C |
| 27 |
-ad ambient divisions 0 128 1024 8192 |
| 28 |
-as ambient super-samples 0 32 512 2048 |
| 29 |
greg |
1.1 |
-ms mist sampling dist. 0 10 1 .01 |
| 30 |
greg |
1.2 |
-lr limit reflection 0 6 8 16 |
| 31 |
greg |
1.1 |
-lw limit weight .05 .01 .002 0 C |
| 32 |
| 33 |
NOTES: |
| 34 |
A) This option does not affect the rendering time |
| 35 |
B) This option adversely affects image sampling (ie. use -ps 1) |
| 36 |
C) Maximum value disables optimization and can be very expensive |
| 37 |
| 38 |
| 39 |
| 40 |
ARTIFACTS ASSOCIATED WITH OPTIONS |
| 41 |
| 42 |
Param Artifact Solution |
| 43 |
| 44 |
-ps "missing pieces" to objects decrease value by 50% |
| 45 |
-pt some soft edges are very jagged decrease value by 50% |
| 46 |
-pj diagonal edges are like staircases increase value to 0.9 |
| 47 |
-pj edges look too erratic decrease value to 0.4 |
| 48 |
-dj shadows are unnaturally sharp increase value to 0.7 |
| 49 |
-ds large sources cast unnatural shadows decrease value by 50% |
| 50 |
-dt some shadows disappear decrease value by 50% |
| 51 |
-dc inaccurate values with many sources increase value to .75 |
| 52 |
-dr missing multiple mirror reflections increment value |
| 53 |
-dp incorrect mirror reflections double value |
| 54 |
-sj specular reflections too fuzzy decrease value to 0.2 |
| 55 |
-sj specular reflections too sharp increase value to 1 |
| 56 |
-st some specular highlights missing decrease value to 0.02 |
| 57 |
-aw shadows appear to glow set value to 0 |
| 58 |
-ab lighting in shadows too flat increment value |
| 59 |
-av overall light level seems too high/low decrease/increase value |
| 60 |
-aa uneven shading boundaries in shadows decrease value by 25% |
| 61 |
-ar shading wrong in some areas double or quadruple value |
| 62 |
-ad "splotches" of light double value |
| 63 |
-as "splotches" of light increase to half of -ad setting |
| 64 |
-ms "noisy" mist scattering divide value by 2 |
| 65 |
-lr some multiple specular reflections gone increment value |
| 66 |
-lw some specular reflections gone decrease value by 50% |
| 67 |
| 68 |
| 69 |
| 70 |
TIMINGS ASSOCIATED WITH OPTIONS |
| 71 |
| 72 |
Param Effect on Execution Time |
| 73 |
| 74 |
-ps inverse, halving value increases rendering time up to four times |
| 75 |
-pt minor, decreasing value causes modest increase in rendering time |
| 76 |
-pj no effect |
| 77 |
-dj indirect, increasing value requires -ps parameter to be reduced |
| 78 |
-ds inverse, halving value causes rendering time to approximately double |
| 79 |
-dt inverse, halving value causes rendering time to increase about 50% |
| 80 |
-dc direct, affects rendering time up to 50% over its 0 to 1 range |
| 81 |
-dr direct, depending on the scene each new reflection can double time |
| 82 |
-dp minor, affects start-up time only, higher values take longer |
| 83 |
-sj no effect |
| 84 |
-st minor, a value of zero may increase rendering by 50% over maximum of 1 |
| 85 |
-ab direct, doubling this value can double rendering time |
| 86 |
-aa direct, doubling this value approximately quadruples rendering time |
| 87 |
-ar direct, effect depends on scene, can quadruple time for double value |
| 88 |
-ad direct, doubling value may double rendering time |
| 89 |
-as direct, effectively adds to -ad parameter and its cost |
| 90 |
-lr minor, increase causes very slightly longer rendering time |
| 91 |
-lw minor, decrease causes very slightly longer rendering time |
