root/radiance/doc/notes/compile_switches
Revision: 1.8
Committed: Tue May 31 10:31:42 2016 UTC (9 years, 4 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Minor corrections to compile_switches
1 Here is a list of compile switches, used to customize Radiance code
2 for specific machines and users:
3
4 -DALIGNT=(type) Alignment type, machine-dependent. Most RISC
5 architectures align on 8-word boundaries (double).
6 The default alignment type is int.
7
8 -DWFLUSH=(rays) Override for number of rays before flush in rvu.
9
10 -DBSD Operating system has a strong Berkeley flavor, which
11 affects certain system calls, such as signal handling and
12 resource tracking.
13
14 -DSMLMEM The system has little RAM available, so size hash
15 tables and the like accordingly. Only allows for
16 small scene descriptions (32,256 primitives).
17
18 -DSMLFLT This setting tells Radiance to use short floats
19 (32 bits) throughout, which saves lots of memory
20 but can cause calculation inaccuracies in many
21 cases. Its use has been discontinued for this reason.
22
23 -DSHADCACHE=N The array size to use for caching occluders.
24 Setting this to 0 turns off this optimization.
25 Values greater than 20 use over 4 Kbytes per
26 light source, which can add up to a lot of
27 memory in scenes with many sources.
28
29 -DAVGREFL=R Set the average surface reflectance for the purpose
30 of indirect irradiance calculations to R, where
31 R is a real number in the range (0,1.0). The
32 default value is 0.50 (50%).
33
34 -DPMAP_OOC Builds the out-of-core photon map. The photon data resides
35 in a leaf file on disk with suffix ".leaf" and is loaded on
36 demand. This is intended for very large photon maps (up to
37 4.3 billion photons) particularly for annual simulations
38 with rcontrib. This switch is disabled by default, which
39 builds the in-core photon map used in previous releases;
40 this resides entirely in main memory. These options are
41 mutually exclusive, and the resulting photon map files are
42 incompatible.
43
44 -DPMAP_PRIMARYPOS
45 Stores photon primary hitpoints for binning using the -f
46 option with rcontrib if the function file requires them.
47 This consumes an additional 3 floats and is disabled per
48 default to reduce the size of the resulting photon maps.
49
50 -DPMAP_FLOAT_FLUX
51 Stores photon flux as floats instead of more compact RGBE
52 (the default). In terms of accuracy, the difference would
53 only be noticeable with highly saturated colours.
54
55 -DPMAP_ROI Enables the -api option to mkpmap. This constrains photon
56 deposition only to the specified region of interest (defined
57 as a bounding volume) for situations where it is known a
58 priori that photon map lookups will only occur inside this
59 region. This is disabled per default as it can lead to
60 biased results outside the ROI, or near its boundaries. Ziss
61 option for ze eckspertz only!
62
63 -DPMAP_RUNAWAY_WARN
64 Causes mkpmap to issue a warning if a photon reaches the
65 maximum number of bounces (as specified with -apm) and is
66 terminated.
67
68 -DPMAP_LOOKUP_WARN
69 Causes rtrace et al to issue warnings when short photon
70 lookups occur, i.e. fewer photons are found than specified
71 as lookup bandwidth with -ap. This is generally not fatal,
72 but can increase noise, and may indicate a higher bandwidth
73 is needed. This is disabled per default as it can result in
74 excessive console clutter.
75
76 -DPMAP_LOOKUP_REDO
77 Causes rtrace et al to repeat short photon map
78 lookups with a progressively larger radius until the
79 target photon count specified with -ap is met. This switch
80 has no effect in conjunction with the -am option, since this
81 disables lookup radius adaptation.
82
83 -DPMAP_EPANECHNIKOV
84 Causes rtrace et al to apply an Epanechnikov filter during
85 photon density estimates. This weights photons according to
86 the inverse distance to the lookup point in order to reduce
87 bias. The default behaviour does not perform filtering.
