root/radiance/doc/man/man5/lamptab.5
Revision: 1.2
Committed: Sat Aug 21 07:04:32 2021 UTC (4 years, 1 month ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.1: +5 -1 lines
docs: update from Rob Fritz
1 .\" RCSid $Id$
2 .TH LAMP.TAB 5 2021-08-18 RADIANCE
3 .SH NAME
4 lamp.tab \- table of lamp colors and lumen depreciation factors
5 .SH DESCRIPTION
6 Lamp.tab contains a table of lamp data. The lines are formatted thus:
7 .IP
8 .RI / "light source name re" /
9 .I x y m
10 .PP
11 or
12 .IP
13 .RI / "light source alias re" /
14 .RI ( "light source name" )
15 .PP
16 The first form gives the color and depreciation of a lamp whose name
17 matches the light source name regular expression. The second gives
18 an alternate name for a light source. Comments beginning with '#'
19 are supported.
20 .SS Notes
21 .IP \(bu
22 Basic regular expressions (original grep) are used with the addition
23 of "\\<" for beginning of word and "\\>" for end-of-word.
24 .IP \(bu
25 .I x
26 and
27 .I y
28 are CIE x and y coordinates. These give the color of the light. See
29 .UR https://www.iso.org/standard/74165.html
30 ISO/CIE 11664-3:2019
31 .UE
32 \*(lqColorimetry \(em Part 3: Cie Tristimulus Values\*(rq for
33 definitions.
34 .IP \(bu
35 .I m
36 is a "coefficient of depreciation." This is a multiplier used to
37 reduce the output of a lamp to the value it would have after it has
38 been in operation for its expected life. It is used to predict the
39 output of a lighting system comprised of many lamps. See the
40 .I IES Lighting Handbook
41 for more information.
42 .IP \(bu
43 Any character except '#' may be used to delimit the light source name
44 regular expression; '/' is conventional, but not required.
45 .IP \(bu
46 Regular expressions may contain '\\' followed by the delimiter
47 character; aliases may contain '\\' followed by ')'.
48 .IP \(bu
49 Comments begin with '#' and may occur at the end of any line.
50 .IP \(bu
51 Blank lines are ignored.
52 .SH AUTHOR
53 Greg Ward
54 .SH SEE ALSO
55 .BR ies2rad (1),
56 .BR pfilt (1)
