| 1 |
.\" RCSid "$Id$" |
| 2 |
.TH META 3 11/15/93 Radiance |
| 3 |
.SH NAME |
| 4 |
libmeta.a - simplified interface to metafile(5) |
| 5 |
.SH SYNOPSIS |
| 6 |
.B extern FILE *pout; |
| 7 |
.PP |
| 8 |
.B mline(x, y, type, thick, color) |
| 9 |
.PP |
| 10 |
.B mpoly(x, y, border, pat, color) |
| 11 |
.PP |
| 12 |
.B mdraw(x, y) |
| 13 |
.PP |
| 14 |
.B mtext(x, y, s, cpi, color) |
| 15 |
.br |
| 16 |
.B char *s; |
| 17 |
.PP |
| 18 |
mvstr(xmin, ymin, xmax, ymax, s, d, thick, color) |
| 19 |
.br |
| 20 |
.B char *s; |
| 21 |
.PP |
| 22 |
mrectangle(xmin, ymin, xmax, ymax, pat, color) |
| 23 |
.PP |
| 24 |
mtriangle(xmin, ymin, xmax, ymax, d, pat, color) |
| 25 |
.PP |
| 26 |
msegment(xmin, ymin, xmax, ymax, sname, d, thick, color) |
| 27 |
.br |
| 28 |
.B char *sname; |
| 29 |
.PP |
| 30 |
.B msetpat(pat, pattern) |
| 31 |
.br |
| 32 |
.B char *pattern; |
| 33 |
.PP |
| 34 |
.B mopenseg(sname) |
| 35 |
.br |
| 36 |
.B char *sname; |
| 37 |
.PP |
| 38 |
.B mcloseseg() |
| 39 |
.PP |
| 40 |
.B minclude(fname) |
| 41 |
.br |
| 42 |
.B char *fname; |
| 43 |
.PP |
| 44 |
.B mendpage() |
| 45 |
.PP |
| 46 |
.B mdone() |
| 47 |
.SH DESCRIPTION |
| 48 |
The routines in |
| 49 |
.I libmeta |
| 50 |
provide a simple interface to the metafile(5) 2D graphics stream. |
| 51 |
Output from these routines is sent to |
| 52 |
.I pout. |
| 53 |
.I Pout |
| 54 |
defaults to the standard output, |
| 55 |
and should be piped to the appropriate device driver. |
| 56 |
.PP |
| 57 |
All coordinates range from 0 to 16383 and map to a square area on |
| 58 |
the output device. |
| 59 |
.I D |
| 60 |
values are one of 'r', 'u', 'l' and 'd' corresponding to right, |
| 61 |
up, left, and down respectively. |
| 62 |
.I Color |
| 63 |
values range from 0 to 3 and normally correspond to black, |
| 64 |
cyan, green and blue. |
| 65 |
.I Pattern |
| 66 |
values range from 0 to 3 and default to solid, thick lines, |
| 67 |
thin lines, and candystripe. |
| 68 |
Pattern value mapping may be changed via |
| 69 |
.I setpat. |
| 70 |
All strings are null-terminated, and do not contain newlines. |
| 71 |
.PP |
| 72 |
.I Mline |
| 73 |
starts a line at the given coordinates. |
| 74 |
The line |
| 75 |
.I type |
| 76 |
is a number from 0 to 3 corresponding to solid, dashed, dotted, |
| 77 |
and dot-dashed. |
| 78 |
The line thickness, |
| 79 |
.I thick, |
| 80 |
is a number from 0 to 3. |
| 81 |
Connected lines are drawn with successive calls to |
| 82 |
.I mdraw. |
| 83 |
.PP |
| 84 |
.I Mpoly |
| 85 |
starts a polygon at the given coordinates. |
| 86 |
The boolean |
| 87 |
.I border |
| 88 |
specifies whether or not a border is desired around the polygon. |
| 89 |
.I Mdraw |
| 90 |
is used to add vertices to the polygon. |
| 91 |
The polygon will be closed automatically after the last call. |
| 92 |
.PP |
| 93 |
.I Mtext |
| 94 |
prints a string of hardware characters starting at the given |
| 95 |
coordinates. |
| 96 |
The characters per inch are |
| 97 |
.I cpi. |
| 98 |
Text is always oriented to the right. |
| 99 |
.PP |
| 100 |
.I Mvstr |
| 101 |
places a vector character string within the given boundaries. |
| 102 |
The string is oriented according to |
| 103 |
.I d. |
| 104 |
The character line thickness is given by |
| 105 |
.I thick. |
| 106 |
.PP |
| 107 |
.I Mrectangle |
| 108 |
fills the given box with |
| 109 |
.I pat. |
| 110 |
.I Mtriangle |
| 111 |
fills the half-box with orientation |
| 112 |
.I d |
| 113 |
| 114 |
Right corresponds to a triangle in the lower right half of the |
| 115 |
box. |
| 116 |
Up corresponds to a triangle in the upper right, left is upper |
| 117 |
left, and down is lower left. |
| 118 |
.PP |
| 119 |
.I Msegment |
| 120 |
places an instance of the segment |
| 121 |
.I sname |
| 122 |
| 123 |
The segment is oriented according to |
| 124 |
.I d, |
| 125 |
where 'r' is null rotation. |
| 126 |
If either |
| 127 |
.I thick |
| 128 |
or |
| 129 |
.I color |
| 130 |
is nonzero, |
| 131 |
its value will replace corresponding values in the segment |
| 132 |
primitives. (For area filling, thick changes the fill pattern.) |
| 133 |
.PP |
| 134 |
.I Msetpat |
| 135 |
maps |
| 136 |
.I pat |
| 137 |
to |
| 138 |
.I pattern. |
| 139 |
.I Pattern |
| 140 |
is a string of the form "Pn" where n is a number between 0 and 11. |
| 141 |
.PP |
| 142 |
.I Mopenseg |
| 143 |
opens the segment named |
| 144 |
.I sname. |
| 145 |
All graphics calls up to a matching call to |
| 146 |
.I mcloseseg |
| 147 |
are stored under |
| 148 |
.I sname. |
| 149 |
An instance of the segment is obtained with a call to |
| 150 |
.I msegment. |
| 151 |
Segments can be nested to any level, and redefining segments |
| 152 |
is allowed. |
| 153 |
Beware of calls to |
| 154 |
.I mtext |
| 155 |
within a segment, since text will not rotate or scale. |
| 156 |
.PP |
| 157 |
.I Minclude |
| 158 |
includes the graphics metafile |
| 159 |
.I fname |
| 160 |
in the output stream. |
| 161 |
.I Mendpage |
| 162 |
advances to the next screen or page. |
| 163 |
On a terminal, the bell rings and a line is read to prevent |
| 164 |
premature erasure. |
| 165 |
.I Mdone |
| 166 |
completes metafile output, and is the only required call. |
| 167 |
.SH DIAGNOSTICS |
| 168 |
None. |
| 169 |
.SH SEE ALSO |
| 170 |
t4014(1), mx80(1), impress(1), primout(3), metafile(5) |
