| 1 |
.\" RCSid "$Id: xshowtrace.1,v 1.2 2003/12/09 15:59:07 greg Exp $" |
| 2 |
.TH XSHOWTRACE 1 11/15/93 RADIANCE |
| 3 |
.SH NAME |
| 4 |
xshowtrace - interactively show rays traced on RADIANCE image under X11 |
| 5 |
.SH SYNOPSIS |
| 6 |
.B xshowtrace |
| 7 |
| 8 |
.B \-s |
| 9 |
| 10 |
.B "rtrace options" |
| 11 |
| 12 |
.B octree |
| 13 |
.B picture |
| 14 |
.SH DESCRIPTION |
| 15 |
.I Xshowtrace |
| 16 |
takes a RADIANCE octree and a picture file |
| 17 |
and displays it on an X11 window server using |
| 18 |
.I ximage(1). |
| 19 |
The picture should have been created from a previous |
| 20 |
.I rpict(1) |
| 21 |
or |
| 22 |
.I rvu(1) |
| 23 |
calculation using the given octree. |
| 24 |
Once the image is displayed, the user can use the 't' command of |
| 25 |
.I ximage |
| 26 |
to select points on the image to display the ray tree. |
| 27 |
.I Rtrace |
| 28 |
then produces a ray tree, which |
| 29 |
.I xshowtrace |
| 30 |
will display (in red on a color screen). |
| 31 |
The |
| 32 |
.I \-s |
| 33 |
option slows the display of each ray traced to make it easier to |
| 34 |
follow the process. |
| 35 |
.SH AUTHOR |
| 36 |
Greg Ward |
| 37 |
.SH BUGS |
| 38 |
If the pointer is moved between the time 't' is pressed and |
| 39 |
.I xshowtrace |
| 40 |
starts drawing rays, the rays will be displaced. |
| 41 |
.SH "SEE ALSO" |
| 42 |
oconv(1), rpict(1), rtrace(1), rvu(1), ximage(1) |
