root/radiance/doc/man/man1/ximage.1
Revision: 1.4
Committed: Thu Jan 1 19:31:45 2004 UTC (21 years, 10 months ago) by greg
CVS Tags: rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: ximage.1,v 1.3 2003/12/09 15:59:07 greg Exp $"
2 greg 1.1 .TH XIMAGE 1 10/27/98 RADIANCE
3     .SH NAME
4 greg 1.2 ximage - RADIANCE picture display for X window system
5 greg 1.1 .SH SYNOPSIS
6     .B ximage
7     [
8     .B \=geometry
9     ][
10     .B "\-di display"
11     ][
12     .B "\-c ncolors"
13     ][
14     .B \-d
15     ][
16     .B \-b
17     ][
18     .B \-m
19     ][
20     .B "\-g gamma"
21     ][
22     .B \-f
23     ][
24     .B "\-e spec
25     ][
26     .BI -o spec
27     ][
28     .B "\-t intvl"
29     ][
30     .B \-s
31     ]
32     .B "picture .."
33     .SH DESCRIPTION
34     .I Ximage
35     takes one or more RADIANCE picture files
36     and displays them on an X server.
37     The
38     .I \-c
39     option specifies the number of colors to use (default fills color table).
40     The
41     .I \-d
42     option turns off color dithering.
43     The
44     .I \-b
45     option displays the image in black and white (greyscale).
46     The
47     .I \-m
48     option forces monochrome output.
49     The
50     .I \-g
51     option specifies the exponent used in gamma correction;
52     the default value is 2.2.
53     The
54     .I \-f
55     option stores a Pixmap on the server side for faster refresh.
56     This may not work with large images on some servers.
57     The
58     .I \-o
59     option specifies a sequence of information to print to the standard
60     output for the 't' command (see below).
61     The
62     .I \-t
63     option specifies a minimum interval (in milliseconds)
64     between successive ray outputs
65     in mouse tracking mode (right button pressed).
66     .PP
67     The
68     .I \-e
69     option specifies an exposure compensation in f-stops (powers of two).
70     Only integer stops are allowed, for efficiency.
71     If the special word,
72     .I auto
73     is given instead of a number of stops, then
74     .I ximage
75     performs an automatic exposure adjustment similar to
76     .I pcond(1),
77     compressing the dynamic range of the image to fit
78     within the dynamic range of the display.
79     If the special word,
80     .I human
81     is given instead, then
82     .I ximage
83     performs an exposure adjustment similar to
84     .I pcond
85     with the
86     .I \-s
87     and
88     .I \-c
89     options, which compensate for human contrast and color sensitivity
90     at the corresponding scene luminance levels.
91     This option yeilds and appearance of the scene on the display that
92     closely matches what would be experienced in the real world.
93     .PP
94     The
95     .I \-s
96     option tells
97     .I ximage
98     to display multiple pictures sequentially, rather than all at once.
99     If no
100     .I picture
101     is given, input is read from stdin provided either the
102     .I \-b
103     or
104     .I \-m
105     option is in effect, or the X server is capable of 24-bit color.
106     However, many of the commands given below will not work.
107     .SH COMMANDS
108     Once a picture is displayed, the user
109     may perform a number of operations.
110     Some of the operations make use of an area of interest, defined by pressing
111     the left mouse button and dragging the cursor over a section of the image.
112     Pressing the button and immediately releasing it defines a single point as
113     the area of interest.
114     A command is a single character.
115     .TP 10n
116     .BR q
117     Quit picture.
118     (Also Q or ^D.)\0
119     .TP 10
120     .BR <space>
121     Redraw the area of interest.
122     .TP 10
123     .BR ^R
124     Redraw the entire image.
125     .TP
126     .BR <return>
127     Display the radiance averaged over the area of interest.
128     .TP
129     .BR l
130     Display the luminance value in the area of interest.
131     This assumes that the image was correctly computed in terms of
132     luminance.
133     .TP
134     .BR c
135     Display the color in the area of interest.
136     .TP
137     .BR p
138     Display the x and y location of the cursor.
139     .TP
140     .BR i
141     Identify identical pixels by assigning a random color at the cursor position.
142     This is useful for displaying contours, especially when combined
143     with the -b option.
144     .TP
145     .BR t
146     Print information about the pixel under the cursor
147     according to the string following the
148     .I \-o
149     command line option.
150     The valid characters for this option correspond roughly to the other
151     .I ximage
152     commands:
153     .IP
154     o ray origin
155     .IP
156     d ray direction
157     .IP
158     v radiance value
159     .IP
160     l luminance value
161     .IP
162     p pixel position
163     .IP
164     The default output is "-ood", which prints
165     the ray origin and direction.
166     This can be used as input to rtrace(1) to get additional information
167     about the image (ie. pipe the output of ximage into rtrace).
168     Pressing the middle mouse button is equivalent to typing the 't' key.
169     Pressing and holding the right mouse button is equivalent to
170     continuously pressing the 't' key.
171     .TP
172     .BR =
173     Adjust the exposure to the area of interest.
174     A crude adjustment is made immediately, and the number of stops
175     is printed while the colors are resampled.
176     After a few seconds to a minute, the final image is redisplayed.
177     If the area of interest is already within 1/2 stop of the ideal,
178     no adjustment is made.
179     .TP
180     .BR @
181     Same as '=' command, only the exposure is adjusted to provide
182     roughly the same visibility for the selected region
183     on screen as a viewer would experience
184     in the actual space.
185     Like the 'l' command, this adjustment assumes that the image
186     has been correctly computed in terms of luminance.
187     (See also the 'h' command, below.)
188     .TP
189     .BR a
190     Perform automatic exposure compensation, as if
191     .I ximage
192     were started with the
193     .I "\-e auto"
194     option.
195     If a rectangular area has been selected, the pixels in this region
196     will be emphasized in the histogram, offering this area exposure preference.
197     (Each pixel within the rectangle will be weighted as 21 outside pixels.)
198     .TP
199     .BR h
200     Perform human expsoure compensation, as if
201     .I ximage
202     were started with the
203     .I "\-e human"
204     option.
205     See the 'a' command above regarding pixel weighting.
206     .TP
207     .BR 0
208     Reset the origin to the upper left corner of the image.
209     This command is used to restore the original image position after
210     using the shift or control key with the mouse to relocate the image
211     within the frame (see below).
212     .TP
213     .BR f
214     Switch on the fast redraw option
215     .I (\-f),
216     loading the image pixmap over to the server side.
217     This command is useful when network delays are causing slow image
218     refresh, and the user didn't notice it until after
219     .I ximage
220     was started.
221     .TP
222     .BR F
223     Switch off the fast redraw option.
224     This frees up some memory on the server, as well as the color table
225     for other windows.
226     .PP
227     In addition to the commands listed above, the control or shift key may
228     be held while the cursor is dragged to reposition the image within the
229     window.
230     .SH "X RESOURCES"
231     radiance.gamma the default gamma correction value
232     .SH ENVIRONMENT
233     DISPLAY_GAMMA the default gamma correction value
234     .SH AUTHORS
235     Greg Ward
236     .br
237     Anat Grynberg (Paris)
238     .br
239     Philip Thompson (MIT)
240     .SH "SEE ALSO"
241     aedimage(1), normtiff(1), pcond(1), pfilt(1), rpict(1), rtrace(1),
242 greg 1.4 rvu(1), xglaresrc(1), xshowtrace(1)
