| 1 |
.\" RCSid "$Id: xform.1,v 1.5 2015/06/29 00:32:51 greg Exp $"
| 2 |
.TH XFORM 1 6/4/99 RADIANCE
| 3 |
.SH NAME
| 4 |
xform - transform a RADIANCE scene description
| 5 |
.SH SYNOPSIS
| 6 |
.B xform
| 7 |
| 8 |
.B \-c
| 9 |
| 10 |
.B \-I
| 11 |
| 12 |
.B "\-n name"
| 13 |
| 14 |
.B "\-m newmod"
| 15 |
| 16 |
.B "\-f argfile"
| 17 |
| 18 |
.B xf0
| 19 |
| 20 |
.B "\-a n1 xf1 .."
| 21 |
| 22 |
.B "\-i 1 xff"
| 23 |
| 24 |
.B "file .."
| 25 |
.SH DESCRIPTION
| 26 |
.I Xform
| 27 |
transforms each scene description
| 28 |
.I file
| 29 |
according to the options given.
| 30 |
If no
| 31 |
.I file
| 32 |
is specified, the standard input is read.
| 33 |
The
| 34 |
.I \-c
| 35 |
option causes commands in the input not to be expanded.
| 36 |
The default is to execute all in line commands.
| 37 |
(See note below about file names.)\0
| 38 |
The
| 39 |
.I \-n
| 40 |
option causes all identifiers to be prefixed with
| 41 |
.I name.
| 42 |
The
| 43 |
.I \-m
| 44 |
option causes all surfaces to be given the modifier
| 45 |
.I newmod.
| 46 |
The
| 47 |
.I \-I
| 48 |
option causes all surfaces to be inverted, reversing their
| 49 |
surface normal orientations.
| 50 |
These options are followed by the transformation options,
| 51 |
which are described below.
| 52 |
.PP
| 53 |
The
| 54 |
.I \-f
| 55 |
option causes the
| 56 |
.I xform
| 57 |
command line to be constructed from the given file,
| 58 |
by inserting each line of the file at the
| 59 |
current point in the command argument list.
| 60 |
Each line in the file will result in a logically separate invocation of
| 61 |
.I xform,
| 62 |
and may contain any valid
| 63 |
.I xform
| 64 |
arguments, including nested
| 65 |
.I \-f
| 66 |
options.
| 67 |
This is a convenient way to specify multiple copies of an object that
| 68 |
do not fit a regular array pattern, without having to actually execute
| 69 |
.I xform
| 70 |
many times.
| 71 |
Separate scene files may be specified this way as well, but remember
| 72 |
that the constructed command line must fit the format of initial options
| 73 |
.I "(-n, -m, -c, -I)"
| 74 |
followed by the transform then the scene files.
| 75 |
No initial options may appear after the first transform option, and
| 76 |
no transform options will be understood after the first named file.
| 77 |
In the special case where the argument to the
| 78 |
.I \-f
| 79 |
option is a hyphen ('-'),
| 80 |
.I xform
| 81 |
will take its arguments from the standard input.
| 82 |
Note that
| 83 |
.I xform
| 84 |
cannot simultaneously take its scene information from the standard input
| 85 |
if the option is used in this way.
| 86 |
Competely empty lines and lines beginning with a pound sign ('#') will be
| 87 |
passed through to the output.
| 88 |
Beginning "!xform" or "xform" command names will also be ignored.
| 89 |
.PP
| 90 |
If one or more scene files are given on the command line,
| 91 |
.I xform
| 92 |
will search the RADIANCE library directories for each file.
| 93 |
(No search takes place if a file name begins with a '.', '/' or '~'
| 94 |
character.)\0
| 95 |
Unless the
| 96 |
.I \-c
| 97 |
option is present,
| 98 |
.I xform
| 99 |
will also change to that file's directory before loading it.
| 100 |
Thus, any commands executed within that file will happen in that
| 101 |
file's directory, which simplifies object hierarchy construction.
| 102 |
.PP
| 103 |
The transformation consists of a sequence of operations which
| 104 |
are executed in the order they appear.
| 105 |
.SH OPTIONS
| 106 |
.TP 10n
| 107 |
.BI -t " x y z"
| 108 |
Translate the scene along the vector
| 109 |
.I "x y z".
| 110 |
.TP
| 111 |
.BI -rx \ degrees
| 112 |
Rotate the scene
| 113 |
.I degrees
| 114 |
about the x axis.
| 115 |
A positive rotation corresponds to counter-clockwise
| 116 |
when looking down the axis.
| 117 |
.TP
| 118 |
.BI -ry \ degrees
| 119 |
Rotate the scene
| 120 |
.I degrees
| 121 |
about the y axis.
| 122 |
.TP
| 123 |
.BI -rz \ degrees
| 124 |
Rotate the scene
| 125 |
.I degrees
| 126 |
about the z axis.
| 127 |
.TP
| 128 |
.BI -s \ factor
| 129 |
Scale the scene by
| 130 |
.I factor.
| 131 |
.TP
| 132 |
.BR \-mx
| 133 |
Mirror the scene about the yz plane.
| 134 |
.TP
| 135 |
.BR \-my
| 136 |
Mirror the scene about the xz plane.
| 137 |
.TP
| 138 |
.BR \-mz
| 139 |
Mirror the scene about the xy plane.
| 140 |
.TP
| 141 |
.BI -i \ count
| 142 |
Iterate (repeat) the following transformation (up to the next
| 143 |
.I \-i
| 144 |
option)
| 145 |
.I count
| 146 |
times.
| 147 |
This option is primarily to support the
| 148 |
.I \-a
| 149 |
option, which is described below.
| 150 |
.SS Arrays
| 151 |
An array is a repeated transformation that results in a repeated object.
| 152 |
It is specified using the
| 153 |
.I \-a
| 154 |
option, which takes the number to repeat as its argument.
| 155 |
The objects will step by the transformation given between
| 156 |
this
| 157 |
.I \-a
| 158 |
option and the next
| 159 |
.I \-a
| 160 |
or
| 161 |
.I \-i
| 162 |
option.
| 163 |
The first object will have zero applications of the transform.
| 164 |
A two-dimensional array is given by two different transformations
| 165 |
each preceded by an array count.
| 166 |
.SH EXAMPLE
| 167 |
To rotate ``book'' 30 degrees about the x axis then
| 168 |
move 20 in y, prepending the name book1:
| 169 |
.IP "" .2i
| 170 |
xform \-n book1 \-rx 30 \-t 0 20 0 book > book1
| 171 |
.PP
| 172 |
To expand all commands and see what information is actually used by RADIANCE:
| 173 |
.IP "" .2i
| 174 |
xform scene | more
| 175 |
.PP
| 176 |
To create a two-dimensional array of 20 lights, after an initial rotation
| 177 |
and followed by a global translation (no command expansion):
| 178 |
.IP "" .2i
| 179 |
xform \-c \-rz 90 \-a 5 \-t 2 0 0 \-a 4 \-t 0 1.5 0 \-i 1 \-t 0 0 10 light
| 180 |
.SH ENVIRONMENT
| 181 |
RAYPATH path to search for scene files
| 182 |
.SH AUTHOR
| 183 |
Greg Ward
| 184 |
.SH BUGS
| 185 |
Only regular (distortion-free) transformations are allowed.
| 186 |
.SH "SEE ALSO"
| 187 |
genbox(1), gensurf(1), oconv(1), replmarks(1), rpict(1), rvu(1)
