| 1 |
greg |
1.3 |
.\" RCSid "$Id: total.1,v 1.2 2003/12/09 15:59:07 greg Exp $" |
| 2 |
greg |
1.1 |
.TH TOTAL 1 2/3/95 RADIANCE |
| 3 |
.SH NAME |
| 4 |
total - sum up columns |
| 5 |
.SH SYNOPSIS |
| 6 |
.B total |
| 7 |
| 8 |
.B \-m |
| 9 |
| 10 |
.B \-sE |
| 11 |
| 12 |
.B \-p |
| 13 |
| 14 |
.B \-u |
| 15 |
| 16 |
.B \-l |
| 17 |
| 18 |
.B \-tC |
| 19 |
| 20 |
.B \-N |
| 21 |
| 22 |
.B \-r |
| 23 |
| 24 |
| 25 |
file .. |
| 26 |
| 27 |
.SH DESCRIPTION |
| 28 |
.I Total |
| 29 |
sums up columns of real numbers from one or more files |
| 30 |
and prints out the result on its standard output. |
| 31 |
.PP |
| 32 |
By default, |
| 33 |
.I total |
| 34 |
computes the straigt sum of each input column, but multiplication |
| 35 |
can be specified instead with the |
| 36 |
.I \-p |
| 37 |
option. |
| 38 |
Likewise, the |
| 39 |
.I \-u |
| 40 |
option means find the upper limit (maximum), and |
| 41 |
.I \-l |
| 42 |
means find the lower limit (minimum). |
| 43 |
.PP |
| 44 |
Sums of powers can be computed by giving an exponent with the |
| 45 |
.I \-s |
| 46 |
option. |
| 47 |
(Note that there is no space between the |
| 48 |
.I \-s |
| 49 |
and the exponent.) |
| 50 |
This exponent can be any real number, positive or negative. |
| 51 |
The absolute value of the input is always taken before the |
| 52 |
power is computed in order to avoid complex results. |
| 53 |
Thus, |
| 54 |
.I \-s1 |
| 55 |
will produce a sum of absolute values. |
| 56 |
The default power (zero) is interpreted as a straight sum without |
| 57 |
taking absolute values. |
| 58 |
.PP |
| 59 |
The |
| 60 |
.I \-m |
| 61 |
option can be used to compute the mean rather than the total. |
| 62 |
For sums, the arithmetic mean is computed. |
| 63 |
For products, the geometric mean is computed. |
| 64 |
(A logarithmic sum of absolute values is used to avoid overflow, and |
| 65 |
zero values are silently ignored.) |
| 66 |
.PP |
| 67 |
A count can be given as the number of lines to read before |
| 68 |
computing a result. |
| 69 |
By default, |
| 70 |
.I total |
| 71 |
reads each file to its end before producing its result, but the |
| 72 |
.I \-N |
| 73 |
option (where N is a decimal integer) tells |
| 74 |
.I total |
| 75 |
to produce a result and reset the calculation after |
| 76 |
every N input lines. |
| 77 |
In addition, the |
| 78 |
.I \-r |
| 79 |
option can be specified to override reinitialization and thus |
| 80 |
give a running total every N lines. |
| 81 |
If the end of file is reached, the current total is printed |
| 82 |
and the calculation is reset before the next file (with or without the |
| 83 |
.I \-r |
| 84 |
option). |
| 85 |
.PP |
| 86 |
The |
| 87 |
.I \-tC |
| 88 |
option can be used to specify the input and output tab character. |
| 89 |
The default tab character is TAB. |
| 90 |
.PP |
| 91 |
If no files are given, the standard input is read. |
| 92 |
.SH EXAMPLE |
| 93 |
To compute the RMS value of colon-separated columns in a file: |
| 94 |
.IP "" .2i |
| 95 |
total -t: -m -s2 input |
| 96 |
.PP |
| 97 |
To produce a running product of values from a file: |
| 98 |
.IP "" .2i |
| 99 |
total -p -1 -r input |
| 100 |
.SH BUGS |
| 101 |
If the input files have varying numbers of columns, mean values |
| 102 |
will certainly be off. |
| 103 |
.I Total |
| 104 |
will ignore missing column entries if the tab separator is a non-white |
| 105 |
character, but cannot tell where a missing column should have been if |
| 106 |
the tab character is white. |
| 107 |
.SH AUTHOR |
| 108 |
Greg Ward |
| 109 |
.SH "SEE ALSO" |
| 110 |
greg |
1.3 |
cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1) |
