root/radiance/doc/man/man1/rvu.1
Revision: 1.14
Committed: Fri May 2 23:56:18 2025 UTC (5 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.13: +13 -12 lines
feat(rvu): Altered the "origin" command to take shift distances
1 .\" RCSid "$Id: rvu.1,v 1.13 2018/03/30 23:14:07 greg Exp $"
2 .TH RVU 1 1/1/04 RADIANCE
3 .SH NAME
4 rvu - generate RADIANCE images interactively
5 .SH SYNOPSIS
6 .B rvu
7 [
8 .B "rpict options"
9 ][
10 .B "\-n nproc"
11 ][
12 .B "\-o dev"
13 ][
14 .B \-b
15 ][
16 .B "\-pe exposure"
17 ]
18 [
19 .B $EVAR
20 ]
21 [
22 .B @file
23 ]
24 .B octree
25 .br
26 .B "rvu [ options ] \-defaults"
27 .br
28 .B "rvu \-devices"
29 .SH DESCRIPTION
30 .I Rvu
31 generates RADIANCE images using
32 .I octree.
33 (The octree may be given as the output of a command enclosed in quotes
34 and preceded by a `!'.)\0
35 Options specify the viewing parameters as well as
36 giving some control over the calculation.
37 Options may be given on the command line and/or read from the
38 environment and/or read from a file.
39 A command argument beginning with a dollar sign ('$') is immediately
40 replaced by the contents of the given environment variable.
41 A command argument beginning with an at sign ('@') is immediately
42 replaced by the contents of the given file.
43 The options are the same as for rpict(1), with a few notable exceptions.
44 The
45 .I "\-pd, \-r, \-z, \-S, \-P, \-PP"
46 and
47 .I \-t
48 options are not supported, and
49 .I \-o
50 specifies which output device is being used instead of the output
51 file.
52 The
53 .I "\-x, \-y"
54 and
55 .I \-pa
56 options are unnecessary, since
57 .I rvu
58 scales the display image to the specified output device.
59 Additionally, the
60 .I \-b
61 option improves the display on greyscale monitors, and
62 .I \-pe
63 may be used to set an initial exposure value.
64 .PP
65 The
66 .I \-n
67 option may be used to specify multiple processes,
68 to accelerate rendering.
69 .PP
70 In the second form, the default values
71 for the options are printed with a brief explanation.
72 In the third form, the list of supported output devices
73 is displayed.
74 .PP
75 .I rvu
76 starts rendering the image from the selected viewpoint and
77 gradually improves the resolution of the display until
78 interrupted by keyboard input.
79 .I rvu
80 then issues a prompt (usually ':') and accepts a command
81 line from the user.
82 .I rvu
83 may also stop its calculation and wait for command input if
84 the resolution of the display has reached the resolution of the
85 graphics device.
86 At this point, it will give the 'done:' prompt and await further
87 instructions.
88 If
89 .I rvu
90 runs out of memory due to lack of resources to store its computed
91 image, it will give the 'out of memory:' prompt.
92 At this prompt, the user can save the image, quit, or even restart
93 a new image, although this is not generally recommended
94 on virtual memory machines for efficiency reasons.
95 .PP
96 .I rvu
97 is not meant to be a rendering program, and we strongly recommend that
98 .I rpict(1)
99 be used instead for that purpose.
100 Since
101 .I rpict(1)
102 does not store its image in memory or update any display of its output,
103 it is much faster and less wasteful of its resources than
104 .I rvu.
105 .I rvu
106 is intended as a quick interactive program for deciding viewpoints
107 and debugging scene descriptions and is not suited for producing
108 polished images.
109 .SH COMMANDS
110 Once the program starts, a number of commands can be used
111 to control it.
112 A command is given by its name, which can be abbreviated,
113 followed by its arguments.
114 .TP 10n
115 .BI aim " [ mag [ x y z ] ]"
116 Zoom in by
117 .I "mag"
118 on point
119 .I "x y z".
120 The view point is held constant;
121 only the view direction and size are changed.
122 If
123 .I "x y z"
124 is missing, the cursor is used to select the view center.
125 A negative magnification factor means zoom out.
126 The default factor is one.
127 .TP
128 .BR ^C
129 Interrupt.
130 Go to the command line.
131 .TP
132 .BI exposure " [ spec ]"
133 Adjust exposure.
134 The number
135 .I spec
136 is a multiplier used to compensate the average exposure.
137 A value of 1 renormalizes the image to the computed average, which
138 is usually done immediately after startup.
139 If
140 .I spec
141 begins with a '+' or '-',
142 the compensation is interpreted in f-stops (ie. the power of two).
143 If
144 .I spec
145 begins with an '=', an absolute setting is performed.
146 An '=' by itself permits interactive display and setting of the exposure.
147 If
148 .I spec
149 begins with an '@', the exposure is adjusted to present similar
150 visibility to what would be experienced in the real environment.
151 If
152 .I spec
153 is absent, or an '@' is followed by nothing, then
154 the cursor is used to pick a specific image
155 location for normalization.
156 .TP
157 .BI focus " [distance]"
158 Set focus distance for depth-of-field sampling.
159 If a distance in world coordinates is absent, then the cursor
160 is used to choose a point in the scene on which to focus.
161 (The focus distance setting does not affect rendering in
162 .I rvu,
163 but can be used in
164 .I rpict
165 with the
166 .I \-pd
167 option to simulate depth-of-field on views saved from
168 .I rvu.)
169 .TP
170 .BI frame " [ xmin ymin xmax ymax ]"
171 Set frame for refinement.
172 If coordinates are absent, the cursor is used to
173 pick frame boundaries.
174 If ``all'' is specified, the frame is reset to the entire image.
175 .TP
176 .BR free
177 Free cached object structures and associated data.
178 This command may be useful when memory is low and a completely
179 different view is being generated from the one previous.
180 .TP
181 .BI last " [ file ]"
182 Restore the previous view.
183 If a view or picture
184 .I file
185 is specified, the parameters are taken from the last view entry
186 in the file.
187 .TP
188 .BI L " [ vw [ rfile ] ]"
189 Load parameters for view
190 .I vw
191 from the
192 .I rad(1)
193 input file,
194 .I rfile.
195 Both
196 .I vw
197 and
198 .I rfile
199 must be given the first call, but subsequent calls will use the last
200 .I rfile
201 as a default, and "1" as the default view (ie. the first view
202 appearing in
203 .I rfile).
204 If
205 .I rvu
206 was started by
207 .I rad,
208 then the
209 .I rfile
210 parameter will initially default to the
211 .I rad
212 input file used.
213 .TP
214 .BI move " [ mag [ x y z ] ]"
215 Move camera
216 .I mag
217 times closer to point
218 .I "x y z".
219 For a perspective projection (or fisheye view),
220 only the view point is changed;
221 the view direction and size remain constant.
222 The view size must be modified in a parallel projection since
223 it determines magnification.
224 If
225 .I "x y z"
226 is missing, the cursor is used to select the view center.
227 A negative magnification factor decreases the object size.
228 The default factor is one.
229 Care must be taken to avoid moving behind or inside other objects.
230 .TP
231 .BI new " [ nproc ]"
232 Restart the image, using the specified number of rendering processes.
233 Usually used after the "set" command.
234 .TP
235 .BI origin " [ forward [ right [up] ] ]"
236 Move the view origin forward or backwards the distance specified by the
237 .I forward
238 argument, along the view direction vector.
239 If at least two arguments are given, the second distance will be a
240 .I right
241 shift, or left if negative relative to the current view direction.
242 If three arguments are given, the third distance will be a distance of
243 .I up
244 along the view up vector, or down if negative.
245 The view direction and size are unchanged in any of the above cases.
246 With no arguments, the cursor is used to select the
247 view origin, and the direction will be determined by the
248 (reoriented) surface normal.
249 The view type and size will not be altered, but the up vector
250 may be changed if the new direction coincides.
251 .TP
252 .BI pivot " angle [ elev [ mag [ x y z ] ] ]"
253 Similar to the "move" command, but pivots the view about a selected point.
254 The
255 .I angle
256 is measured in degrees around the view up vector using the right hand rule,
257 so a positive value pivots the viewer to the right of the selected point.
258 The optional
259 .I elev
260 is the elevation in degrees from the pivot point; positive raises the view point
261 to look downward and negative lowers the view point to look upward.
262 .TP
263 .BR quit
264 Quit the program.
265 .TP
266 .BR ^R
267 Redraw the image.
268 Use when the display gets corrupted.
269 On some displays, occassionally forcing a redraw can improve appearance,
270 as more color information is available and the driver can make a better
271 color table selection.
272 .TP
273 .BI rotate " angle [ elev [ mag ] ]"
274 Rotate the camera horizontally by
275 .I angle
276 degrees using the right-hand rule.
277 A positive value rotates the view towards the left, and a negative value
278 looks to the right.
279 If an elevation is specified, the camera looks upward
280 .I elev
281 degrees.
282 (Negative means look downward.)
283 .TP
284 .BI set " [ var [ val ] ]"
285 Check/change program variable.
286 If
287 .I var
288 is absent, the list of available variables is displayed.
289 If
290 .I val
291 is absent, the current value of the variable is displayed
292 and changed interactively.
293 Otherwise, the variable
294 .I var
295 assumes the value
296 .I val.
297 Variables include:
298 ambient value (av),
299 ambient value weight (aw),
300 ambient bounces (ab),
301 ambient accuracy (aa),
302 ambient divisions (ad),
303 ambient radius (ar),
304 ambient samples (as),
305 black&white (b),
306 back face visibility (bv),
307 direct jitter (dj),
308 direct sampling (ds),
309 direct threshold (dt),
310 direct visibility (dv),
311 irradiance (i),
312 limit weight (lw),
313 limit recursion (lr),
314 medium extinction (me),
315 medium albedo (ma),
316 medium eccentricity (mg),
317 medium sampling (ms),
318 pixel sample (ps),
319 pixel threshold (pt),
320 specular jitter (sj),
321 specular threshold (st), and
322 uncorrelated sampling (u).
323 Once a variable has been changed, the "new" command can be used
324 to recompute the image with the new parameters.
325 If a program variable is not available here, it may show up under
326 some other command or it may be impossible to change
327 once the program is running.
328 .TP
329 .BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]"
330 Trace a ray.
331 If the ray origin and direction are absent, the cursor is used
332 to pick a location in the image to trace.
333 The object intersected and its material, location and value are displayed.
334 .TP
335 .BI view " [ file [ comments ] ]"
336 Check/change view parameters.
337 If
338 .I file
339 is present, the view parameters are appended to a file, followed by
340 .I comments
341 if any.
342 Alternatively, view options may be given directly on the command line
343 instead of an output view file.
344 Otherwise, view parameters are displayed and changed interactively.
345 .TP
346 .BI V " [ vw [ rfile ] ]"
347 Append the current view as view
348 .I vw
349 in the rad file
350 .I rfile.
351 Compliment to
352 .I L
353 command.
354 Note that the view is simply appended to the file, and previous
355 views with the same name should be removed before using the file
356 with
357 .I rad.
358 .TP
359 .BI write " [ file ]"
360 Write picture to
361 .I file.
362 If argument is missing, the current file name is used.
363 .TP
364 .BR ^Z
365 Stop the program.
366 The screen will be redrawn when the program resumes.
367 .SH ENVIRONMENT
368 RAYPATH the directories to check for auxiliary files.
369 .br
370 DISPLAY_GAMMA the value to use for monitor gamma correction.
371 .SH AUTHOR
372 Greg Ward
373 .SH "SEE ALSO"
374 getinfo(1), lookamb(1), mkpmap(1),
375 oconv(1), pfilt(1), rad(1), rpict(1), rtpict(1), rtrace(1)
