root/radiance/doc/man/man1/rtrace.1
Revision: 1.20
Committed: Tue Jan 26 04:42:16 2010 UTC (15 years, 9 months ago) by greg
Changes since 1.19: +4 -3 lines
Corrected description of -lr option.
1 .\" RCSid "$Id: rtrace.1,v 1.19 2009/12/13 19:13:03 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .SH DESCRIPTION
20 .I Rtrace
21 traces rays from the standard input through the RADIANCE scene given by
22 .I octree
23 and sends the results to the standard output.
24 (The octree may be given as the output of a command enclosed in quotes
25 and preceded by a `!'.)\0
26 Input for each ray is:
27
28 xorg yorg zorg xdir ydir zdir
29
30 If the direction vector is (0,0,0), a bogus record
31 is printed and the output is flushed if the
32 .I -x
33 value is unset or zero.
34 (See the notes on this option below.)\0
35 This may be useful for programs that run
36 .I rtrace
37 as a separate process.
38 In the second form, the default values
39 for the options (modified by those options present)
40 are printed with a brief explanation.
41 .PP
42 Options may be given on the command line and/or read from the
43 environment and/or read from a file.
44 A command argument beginning with a dollar sign ('$') is immediately
45 replaced by the contents of the given environment variable.
46 A command argument beginning with an at sign ('@') is immediately
47 replaced by the contents of the given file.
48 Most options are followed by one or more arguments, which must be
49 separated from the option and each other by white space.
50 The exceptions to this rule are the boolean options.
51 Normally, the appearance of a boolean option causes a feature to
52 be "toggled", that is switched from off to on or on to off
53 depending on its previous state.
54 Boolean options may also be set
55 explicitly by following them immediately with a '+' or '-', meaning
56 on or off, respectively.
57 Synonyms for '+' are any of the characters "yYtT1", and synonyms
58 for '-' are any of the characters "nNfF0".
59 All other characters will generate an error.
60 .TP 10n
61 .BI -f io
62 Format input according to the character
63 .I i
64 and output according to the character
65 .I o.
66 .I Rtrace
67 understands the following input and output formats: 'a' for
68 ascii, 'f' for single-precision floating point,
69 and 'd' for double-precision floating point.
70 In addition to these three choices, the character 'c' may be used
71 to denote 4-byte floating point (Radiance) color format
72 for the output of values only
73 .I (\-ov
74 option, below).
75 If the output character is missing, the input format is used.
76 .IP
77 Note that there is no space between this option and its argument.
78 .TP
79 .BI -o spec
80 Produce output fields according to
81 .I spec.
82 Characters are interpreted as follows:
83 .IP
84 o origin (input)
85 .IP
86 d direction (normalized)
87 .IP
88 v value (radiance)
89 .IP
90 V contribution (radiance)
91 .IP
92 w weight
93 .IP
94 W color coefficient
95 .IP
96 l effective length of ray
97 .IP
98 L first intersection distance
99 .IP
100 c local (u,v) coordinates
101 .IP
102 p point of intersection
103 .IP
104 n normal at intersection (perturbed)
105 .IP
106 N normal at intersection (unperturbed)
107 .IP
108 s surface name
109 .IP
110 m modifier name
111 .IP
112 M material name
113 .IP
114 ~ tilde (end of trace marker)
115 .IP
116 If the letter 't' appears in
117 .I spec,
118 then the fields following will be printed for every ray traced,
119 not just the final result.
120 If the capital letter 'T' is given instead of 't', then all rays will
121 be reported, including shadow testing rays to light sources.
122 Spawned rays are indented one tab for each level.
123 The tilde marker ('~') is a handy way of differentiating the final ray
124 value from daughter values in a traced ray tree, and usually appears
125 right before the 't' or 'T' output flags.
126 E.g.,
127 .I \-ov~TmW
128 will emit a tilde followed by a tab at the end of each trace,
129 which can be easily distinguished even in binary output.
130 .IP
131 Note that there is no space between this option and its argument.
132 .TP
133 .BI -te \ mod
134 Append
135 .I mod
136 to the trace exclude list,
137 so that it will not be reported by the trace option
138 .I (\-o*t*).
139 Any ray striking an object having
140 .I mod
141 as its modifier will not be reported to the standard output with
142 the rest of the rays being traced.
143 This option has no effect unless either the 't' or 'T'
144 option has been given as part of the output specifier.
145 Any number of excluded modifiers may be given, but each
146 must appear in a separate option.
147 .TP
148 .BI -ti \ mod
149 Add
150 .I mod
151 to the trace include list,
152 so that it will be reported by the trace option.
153 The program can use either an include list or an exclude
154 list, but not both.
155 .TP
156 .BI -tE \ file
157 Same as
158 .I \-te,
159 except read modifiers to be excluded from
160 .I file.
161 The RAYPATH environment variable determines which directories are
162 searched for this file.
163 The modifier names are separated by white space in the file.
164 .TP
165 .BI -tI \ file
166 Same as
167 .I \-ti,
168 except read modifiers to be included from
169 .I file.
170 .TP
171 .BR \-i
172 Boolean switch to compute irradiance rather than radiance values.
173 This only affects the final result, substituting a Lambertian
174 surface and multiplying the radiance by pi.
175 Glass and other transparent surfaces are ignored during this stage.
176 Light sources still appear with their original radiance values,
177 though the
178 .I \-dv
179 option (below) may be used to override this.
180 This option is especially useful in
181 conjunction with ximage(1) for computing illuminance at scene points.
182 .TP
183 .BR \-u
184 Boolean switch to control uncorrelated random sampling.
185 When "off", a low-discrepancy sequence is used, which reduces
186 variance but can result in a brushed appearance in specular highlights.
187 When "on", pure Monte Carlo sampling is used in all calculations.
188 .TP
189 .BR \-I
190 Boolean switch to compute irradiance rather than radiance,
191 with the input origin and direction interpreted instead
192 as measurement point and orientation.
193 .TP
194 .BR \-h
195 Boolean switch for information header on output.
196 .TP
197 .BI -x \ res
198 Set the x resolution to
199 .I res.
200 The output will be flushed after every
201 .I res
202 input rays.
203 A value of zero means that no output flushing will take place.
204 .TP
205 .BI -y \ res
206 Set the y resolution to
207 .I res.
208 The program will exit after
209 .I res
210 scanlines have been processed, where a scanline is the number of rays
211 given by the
212 .I \-x
213 option, or 1 if
214 .I \-x
215 is zero.
216 A value of zero means the program will not halt until the end
217 of file is reached.
218 .IP
219 If both
220 .I \-x
221 and
222 .I \-y
223 options are given, a resolution string is printed at the beginning
224 of the output.
225 This is mostly useful for recovering image dimensions with
226 .I pvalue(1),
227 and for creating valid Radiance picture files using the color output
228 format.
229 (See the
230 .I \-f
231 option, above.)
232 .TP
233 .BI -n \ nproc
234 Execute in parallel on
235 .I nproc
236 local processes.
237 This option is incompatible with the
238 .I \-P
239 and
240 .I \-PP,
241 options.
242 Multiple processes also do not work properly with ray tree output
243 using any of the
244 .I \-o*t*
245 options.
246 There is no benefit from specifying more processes than there are
247 cores available on the system or the
248 .I \-x
249 setting, which forces a wait at each flush.
250 .TP
251 .BI -dj \ frac
252 Set the direct jittering to
253 .I frac.
254 A value of zero samples each source at specific sample points
255 (see the
256 .I \-ds
257 option below), giving a smoother but somewhat less accurate
258 rendering.
259 A positive value causes rays to be distributed over each
260 source sample according to its size, resulting in more accurate
261 penumbras.
262 This option should never be greater than 1, and may even
263 cause problems (such as speckle) when the value is smaller.
264 A warning about aiming failure will issued if
265 .I frac
266 is too large.
267 .TP
268 .BI -ds \ frac
269 Set the direct sampling ratio to
270 .I frac.
271 A light source will be subdivided until
272 the width of each sample area divided by the distance
273 to the illuminated point is below this ratio.
274 This assures accuracy in regions close to large area sources
275 at a slight computational expense.
276 A value of zero turns source subdivision off, sending at most one
277 shadow ray to each light source.
278 .TP
279 .BI -dt \ frac
280 Set the direct threshold to
281 .I frac.
282 Shadow testing will stop when the potential contribution of at least
283 the next and at most all remaining light sources is less than
284 this fraction of the accumulated value.
285 (See the
286 .I \-dc
287 option below.)
288 The remaining light source contributions are approximated
289 statistically.
290 A value of zero means that all light sources will be tested for shadow.
291 .TP
292 .BI \-dc \ frac
293 Set the direct certainty to
294 .I frac.
295 A value of one guarantees that the absolute accuracy of the direct calculation
296 will be equal to or better than that given in the
297 .I \-dt
298 specification.
299 A value of zero only insures that all shadow lines resulting in a contrast
300 change greater than the
301 .I \-dt
302 specification will be calculated.
303 .TP
304 .BI -dr \ N
305 Set the number of relays for secondary sources to
306 .I N.
307 A value of 0 means that secondary sources will be ignored.
308 A value of 1 means that sources will be made into first generation
309 secondary sources; a value of 2 means that first generation
310 secondary sources will also be made into second generation secondary
311 sources, and so on.
312 .TP
313 .BI -dp \ D
314 Set the secondary source presampling density to D.
315 This is the number of samples per steradian
316 that will be used to determine ahead of time whether or not
317 it is worth following shadow rays through all the reflections and/or
318 transmissions associated with a secondary source path.
319 A value of 0 means that the full secondary source path will always
320 be tested for shadows if it is tested at all.
321 .TP
322 .BR \-dv
323 Boolean switch for light source visibility.
324 With this switch off, sources will be black when viewed directly
325 although they will still participate in the direct calculation.
326 This option is mostly for the program
327 .I mkillum(1)
328 to avoid inappropriate counting of light sources, but it
329 may also be desirable in conjunction with the
330 .I \-i
331 option.
332 .TP
333 .BI -sj \ frac
334 Set the specular sampling jitter to
335 .I frac.
336 This is the degree to which the highlights are sampled
337 for rough specular materials.
338 A value of one means that all highlights will be fully sampled
339 using distributed ray tracing.
340 A value of zero means that no jittering will take place, and all
341 reflections will appear sharp even when they should be diffuse.
342 .TP
343 .BI -st \ frac
344 Set the specular sampling threshold to
345 .I frac.
346 This is the minimum fraction of reflection or transmission, under which
347 no specular sampling is performed.
348 A value of zero means that highlights will always be sampled by
349 tracing reflected or transmitted rays.
350 A value of one means that specular sampling is never used.
351 Highlights from light sources will always be correct, but
352 reflections from other surfaces will be approximated using an
353 ambient value.
354 A sampling threshold between zero and one offers a compromise between image
355 accuracy and rendering time.
356 .TP
357 .BR -bv
358 Boolean switch for back face visibility.
359 With this switch off, back faces of opaque objects will be invisible
360 to all rays.
361 This is dangerous unless the model was constructed such that
362 all surface normals on opaque objects face outward.
363 Although turning off back face visibility does not save much
364 computation time under most circumstances, it may be useful as a
365 tool for scene debugging, or for seeing through one-sided walls from
366 the outside.
367 This option has no effect on transparent or translucent materials.
368 .TP
369 .BI -av " red grn blu"
370 Set the ambient value to a radiance of
371 .I "red grn blu".
372 This is the final value used in place of an
373 indirect light calculation.
374 If the number of ambient bounces is one or greater and the ambient
375 value weight is non-zero (see
376 .I -aw
377 and
378 .I -ab
379 below), this value may be modified by the computed indirect values
380 to improve overall accuracy.
381 .TP
382 .BI -aw \ N
383 Set the relative weight of the ambient value given with the
384 .I -av
385 option to
386 .I N.
387 As new indirect irradiances are computed, they will modify the
388 default ambient value in a moving average, with the specified weight
389 assigned to the initial value given on the command and all other
390 weights set to 1.
391 If a value of 0 is given with this option, then the initial ambient
392 value is never modified.
393 This is the safest value for scenes with large differences in
394 indirect contributions, such as when both indoor and outdoor
395 (daylight) areas are visible.
396 .TP
397 .BI -ab \ N
398 Set the number of ambient bounces to
399 .I N.
400 This is the maximum number of diffuse bounces
401 computed by the indirect calculation.
402 A value of zero implies no indirect calculation.
403 .TP
404 .BI -ar \ res
405 Set the ambient resolution to
406 .I res.
407 This number will determine the maximum density of ambient values
408 used in interpolation.
409 Error will start to increase on surfaces spaced closer than
410 the scene size divided by the ambient resolution.
411 The maximum ambient value density is the scene size times the
412 ambient accuracy (see the
413 .I \-aa
414 option below) divided by the ambient resolution.
415 The scene size can be determined using
416 .I getinfo(1)
417 with the
418 .I \-d
419 option on the input octree.
420 .TP
421 .BI -aa \ acc
422 Set the ambient accuracy to
423 .I acc.
424 This value will approximately equal the error
425 from indirect illuminance interpolation.
426 A value of zero implies no interpolation.
427 .TP
428 .BI -ad \ N
429 Set the number of ambient divisions to
430 .I N.
431 The error in the Monte Carlo calculation of indirect
432 illuminance will be inversely proportional to the square
433 root of this number.
434 A value of zero implies no indirect calculation.
435 .TP
436 .BI -as \ N
437 Set the number of ambient super-samples to
438 .I N.
439 Super-samples are applied only to the ambient divisions which
440 show a significant change.
441 .TP
442 .BI -af \ fname
443 Set the ambient file to
444 .I fname.
445 This is where indirect illuminance will be stored and retrieved.
446 Normally, indirect illuminance values are kept in memory and
447 lost when the program finishes or dies.
448 By using a file, different invocations can share illuminance
449 values, saving time in the computation.
450 The ambient file is in a machine-independent binary format
451 which can be examined with
452 .I lookamb(1).
453 .IP
454 The ambient file may also be used as a means of communication and
455 data sharing between simultaneously executing processes.
456 The same file may be used by multiple processes, possibly running on
457 different machines and accessing the file via the network (ie.
458 .I nfs(4)).
459 The network lock manager
460 .I lockd(8)
461 is used to insure that this information is used consistently.
462 .IP
463 If any calculation parameters are changed or the scene
464 is modified, the old ambient file should be removed so that
465 the calculation can start over from scratch.
466 For convenience, the original ambient parameters are listed in the
467 header of the ambient file.
468 .I Getinfo(1)
469 may be used to print out this information.
470 .TP
471 .BI -ae \ mod
472 Append
473 .I mod
474 to the ambient exclude list,
475 so that it will not be considered during the indirect calculation.
476 This is a hack for speeding the indirect computation by
477 ignoring certain objects.
478 Any object having
479 .I mod
480 as its modifier will get the default ambient
481 level rather than a calculated value.
482 Any number of excluded modifiers may be given, but each
483 must appear in a separate option.
484 .TP
485 .BI -ai \ mod
486 Add
487 .I mod
488 to the ambient include list,
489 so that it will be considered during the indirect calculation.
490 The program can use either an include list or an exclude
491 list, but not both.
492 .TP
493 .BI -aE \ file
494 Same as
495 .I \-ae,
496 except read modifiers to be excluded from
497 .I file.
498 The RAYPATH environment variable determines which directories are
499 searched for this file.
500 The modifier names are separated by white space in the file.
501 .TP
502 .BI -aI \ file
503 Same as
504 .I \-ai,
505 except read modifiers to be included from
506 .I file.
507 .TP
508 .BI -me " rext gext bext"
509 Set the global medium extinction coefficient to the indicated color,
510 in units of 1/distance (distance in world coordinates).
511 Light will be scattered or absorbed over distance according to
512 this value.
513 The ratio of scattering to total scattering plus absorption is set
514 by the albedo parameter, described below.
515 .TP
516 .BI -ma " ralb galb balb"
517 Set the global medium albedo to the given value between 0\00\00
518 and 1\01\01.
519 A zero value means that all light not transmitted by the medium
520 is absorbed.
521 A unitary value means that all light not transmitted by the medium
522 is scattered in some new direction.
523 The isotropy of scattering is determined by the Heyney-Greenstein
524 parameter, described below.
525 .TP
526 .BI \-mg \ gecc
527 Set the medium Heyney-Greenstein eccentricity parameter to
528 .I gecc.
529 This parameter determines how strongly scattering favors the forward
530 direction.
531 A value of 0 indicates perfectly isotropic scattering.
532 As this parameter approaches 1, scattering tends to prefer the
533 forward direction.
534 .TP
535 .BI \-ms \ sampdist
536 Set the medium sampling distance to
537 .I sampdist,
538 in world coordinate units.
539 During source scattering, this will be the average distance between
540 adjacent samples.
541 A value of 0 means that only one sample will be taken per light
542 source within a given scattering volume.
543 .TP
544 .BI -lr \ N
545 Limit reflections to a maximum of
546 .I N,
547 if N is a positive integer.
548 If
549 .I N
550 is zero or negative, then Russian roulette is used for ray
551 termination, and the
552 .I -lw
553 setting (below) must be positive.
554 If N is a negative integer, then this sets the upper limit
555 of reflections past which Russian roulette will be used.
556 In scenes with dielectrics and total internal reflection,
557 a setting of 0 (no limit) may cause a stack overflow.
558 .TP
559 .BI -lw \ frac
560 Limit the weight of each ray to a minimum of
561 .I frac.
562 During ray-tracing, a record is kept of the estimated contribution
563 (weight) a ray would have in the image.
564 If this weight is less than the specified minimum and the
565 .I -lr
566 setting (above) is positive, the ray is not traced.
567 Otherwise, Russian roulette is used to
568 continue rays with a probability equal to the ray weight
569 divided by the given
570 .I frac.
571 .TP
572 .BR -ld
573 Boolean switch to limit ray distance.
574 If this option is set, then rays will only be traced as far as the
575 magnitude of each direction vector.
576 Otherwise, vector magnitude is ignored and rays are traced to infinity.
577 .TP
578 .BI -e \ efile
579 Send error messages and progress reports to
580 .I efile
581 instead of the standard error.
582 .TP
583 .BR \-w
584 Boolean switch to suppress warning messages.
585 .TP
586 .BI \-P \ pfile
587 Execute in a persistent mode, using
588 .I pfile
589 as the control file.
590 Persistent execution means that after reaching end-of-file on
591 its input,
592 .I rtrace
593 will fork a child process that will wait for another
594 .I rtrace
595 command with the same
596 .I \-P
597 option to attach to it.
598 (Note that since the rest of the command line options will be those
599 of the original invocation, it is not necessary to give any arguments
600 besides
601 .I \-P
602 for subsequent calls.)
603 Killing the process is achieved with the
604 .I kill(1)
605 command.
606 (The process ID in the first line of
607 .I pfile
608 may be used to identify the waiting
609 .I rtrace
610 process.)
611 This option may be used with the
612 .I \-fr
613 option of
614 .I pinterp(1)
615 to avoid the cost of starting up
616 .I rtrace
617 many times.
618 .TP
619 .BI \-PP \ pfile
620 Execute in continuous-forking persistent mode, using
621 .I pfile
622 as the control file.
623 The difference between this option and the
624 .I \-P
625 option described above is the creation of multiple duplicate
626 processes to handle any number of attaches.
627 This provides a simple and reliable mechanism of memory sharing
628 on most multiprocessing platforms, since the
629 .I fork(2)
630 system call will share memory on a copy-on-write basis.
631 .SH EXAMPLES
632 To compute radiance values for the rays listed in samples.inp:
633 .IP "" .2i
634 rtrace \-ov scene.oct < samples.inp > radiance.out
635 .PP
636 To compute illuminance values at locations selected with the 't'
637 command of
638 .I ximage(1):
639 .IP "" .2i
640 ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3'
641 .PP
642 To record the object identifier corresponding to each pixel in an image:
643 .IP "" .2i
644 vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct
645 .PP
646 To compute an image with an unusual view mapping:
647 .IP "" .2i
648 cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace
649 \-x 640 \-y 480 \-fac scene.oct > unusual.hdr
650 .SH ENVIRONMENT
651 RAYPATH the directories to check for auxiliary files.
652 .SH FILES
653 /tmp/rtXXXXXX common header information for picture sequence
654 .SH DIAGNOSTICS
655 If the program terminates from an input related error, the exit status
656 will be 1.
657 A system related error results in an exit status of 2.
658 If the program receives a signal that is caught, it will exit with a status
659 of 3.
660 In each case, an error message will be printed to the standard error, or
661 to the file designated by the
662 .I \-e
663 option.
664 .SH AUTHOR
665 Greg Ward
666 .SH "SEE ALSO"
667 getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1),
668 pvalue(1), rpict(1), rtcontrib(1), rvu(1), vwrays(1), ximage(1)
