| 1 |
greg |
1.16 |
.\" RCSid "$Id: rtpict.1,v 1.15 2023/12/12 17:18:27 greg Exp $" |
| 2 |
greg |
1.1 |
.TH RTPICT 1 3/19/2018 RADIANCE |
| 3 |
.SH NAME |
| 4 |
greg |
1.13 |
rtpict - generate a RADIANCE picture, hyperspectral image, or layers using rtrace |
| 5 |
greg |
1.1 |
.SH SYNOPSIS |
| 6 |
.B rtpict |
| 7 |
greg |
1.2 |
.B "-n nproc" |
| 8 |
greg |
1.1 |
| 9 |
greg |
1.13 |
.B -co |
| 10 |
| 11 |
greg |
1.3 |
.B "-o[vrxlLRXnNsmM] out_dir" |
| 12 |
| 13 |
.B "-d ref_depth/unit" |
| 14 |
| 15 |
| 16 |
greg |
1.1 |
.B "rpict options" |
| 17 |
| 18 |
| 19 |
.B @file |
| 20 |
| 21 |
.B octree |
| 22 |
.SH DESCRIPTION |
| 23 |
.I Rtpict |
| 24 |
greg |
1.13 |
is a script that generates a picture or hyperspectral image |
| 25 |
from the RADIANCE scene given in |
| 26 |
greg |
1.1 |
.I octree |
| 27 |
and sends it to the standard output, or to a file specified with the |
| 28 |
.I \-o |
| 29 |
option. |
| 30 |
Most options and defaults are the same as |
| 31 |
.I rpict(1), |
| 32 |
greg |
1.13 |
although a few options are silently ignored, and the |
| 33 |
.I rtrace(1) |
| 34 |
.I \-co |
| 35 |
boolean switch is supported. |
| 36 |
Options incompatible with multi-processing may generate an error. |
| 37 |
greg |
1.1 |
.PP |
| 38 |
The |
| 39 |
greg |
1.13 |
.I rtrace |
| 40 |
greg |
1.1 |
tool is called with |
| 41 |
.I vwrays(1) |
| 42 |
to perform the actual work. |
| 43 |
This enables the |
| 44 |
.I \-n |
| 45 |
option for multiprocessing on platforms that support it. |
| 46 |
If the |
| 47 |
.I \-n |
| 48 |
option is not specified or is set to 1, then |
| 49 |
.I rpict |
| 50 |
is called directly. |
| 51 |
There is no benefit in setting the number of processes to anything |
| 52 |
greater than the number of virtual cores available on your machine. |
| 53 |
Also, it is very important to set the |
| 54 |
.I \-af |
| 55 |
option if an irradiance cache is being generated; |
| 56 |
otherwise, your speed-up will be far from linear. |
| 57 |
greg |
1.3 |
.PP |
| 58 |
If the |
| 59 |
.I \-o |
| 60 |
option has additional characters corresponding to output types from |
| 61 |
.I rtrace, |
| 62 |
it must be followed by the name of a directory that either exists or |
| 63 |
will be created to contain image layers, one per output type. |
| 64 |
The supported types are listed below, and do not include types that |
| 65 |
are useless or have no convenient representation. |
| 66 |
The table below shows the correspondence between output type and file name |
| 67 |
in the specified directory: |
| 68 |
.sp |
| 69 |
.nf |
| 70 |
v radiance.hdr |
| 71 |
greg |
1.4 |
r r_refl.hdr |
| 72 |
x r_unrefl.hdr |
| 73 |
l d_effective.dpt |
| 74 |
L d_firstsurf.dpt |
| 75 |
R d_refl.dpt |
| 76 |
X d_unrefl.dpt |
| 77 |
greg |
1.3 |
n perturbed.nrm |
| 78 |
N unperturbed.nrm |
| 79 |
s surface.idx |
| 80 |
m modifier.idx |
| 81 |
M material.idx |
| 82 |
.fi |
| 83 |
.sp |
| 84 |
Different encodings are associated with different data types. |
| 85 |
Color data (from the 'v', 'r', and 'x' types) will be converted to |
| 86 |
a flat RGBE picture by |
| 87 |
greg |
1.13 |
.I pvalue(1), |
| 88 |
unless the |
| 89 |
.I \-co+ |
| 90 |
option is specified and |
| 91 |
.I \-cs |
| 92 |
is greater than 3. |
| 93 |
In this case, a hyperspectral image will be generated for each |
| 94 |
of the value types, converted by |
| 95 |
greg |
1.14 |
.I rcomb(1) |
| 96 |
greg |
1.13 |
and with its suffix set to ".hsr" rather than ".hdr". |
| 97 |
greg |
1.3 |
Distances (from the 'l', 'L', 'R', and 'X' types) will be |
| 98 |
converted to a 16-bit representation by |
| 99 |
.I rcode_depth(1), |
| 100 |
and the |
| 101 |
.I \-d |
| 102 |
greg |
1.5 |
option should be used to assign the reference (median) depth and world |
| 103 |
units, which applies to the overall scene. |
| 104 |
greg |
1.3 |
Surface normals (from the 'n' and 'N' types) will be converted |
| 105 |
to a 32-bit representation by |
| 106 |
greg |
1.12 |
.I rcode_norm(1). |
| 107 |
greg |
1.3 |
Finally, identifiers (from the 's', 'm', and 'M' types) will be |
| 108 |
converted to a 16-bit index format by |
| 109 |
.I rcode_ident(1). |
| 110 |
.PP |
| 111 |
If the |
| 112 |
.I \-i |
| 113 |
option is used to turn on irradiane output, then the picture associated |
| 114 |
with the 'v' type will be renamed |
| 115 |
.I "irradiance.hdr" |
| 116 |
greg |
1.13 |
or |
| 117 |
.I "irradiance.hsr" |
| 118 |
and some other output types become irrelevant |
| 119 |
(i.e., 'r', 'x', 'R', and 'X'). |
| 120 |
greg |
1.3 |
If one or more of the associated output files already exists in the |
| 121 |
greg |
1.8 |
destination directory, an error will be printed and the command will abort. |
| 122 |
greg |
1.3 |
.SH EXAMPLES |
| 123 |
greg |
1.1 |
To render a scene with four processes: |
| 124 |
.IP "" .2i |
| 125 |
rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oct > scene_pers.hdr |
| 126 |
greg |
1.3 |
.PP |
| 127 |
To render radiance, first surface distance, and normals in a layered image: |
| 128 |
.IP "" .2i |
| 129 |
rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct |
| 130 |
greg |
1.13 |
.PP |
| 131 |
To render a hyperspectral irradiance image with 18 spectral samples: |
| 132 |
.IP "" .2i |
| 133 |
greg |
1.15 |
rtpict -vf inside.vf -i+ -cs 18 -co+ scene.oct > scene_inside.hsr |
| 134 |
greg |
1.1 |
.SH AUTHOR |
| 135 |
Greg Ward |
| 136 |
.SH "SEE ALSO" |
| 137 |
greg |
1.3 |
getinfo(1), mkpmap(1), oconv(1), pfilt(1), |
| 138 |
greg |
1.12 |
pvalue(1), rad(1), rcode_depth(1), rcode_norm(1), rcode_ident(1), |
| 139 |
greg |
1.14 |
rcomb(1), rcrop(1), rmtxop(1), |
| 140 |
greg |
1.16 |
rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), rxpiece(1), vwrays(1) |
