root/radiance/doc/man/man1/rsplit.1
Revision: 1.13
Committed: Wed May 15 18:58:54 2024 UTC (17 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.12: +1 -3 lines
fix: removed non-existent -ocN option from usage
1 .\" RCSid "$Id: rsplit.1,v 1.12 2022/03/16 00:06:08 greg Exp $"
2 .TH RSPLIT 1 7/8/97 RADIANCE
3 .SH NAME
4 rsplit - splits standard input into multiple output files or streams
5 .SH SYNOPSIS
6 .B rsplit
7 [
8 .B \-tS
9 ][
10 .B \-ih
11 ][
12 .B \-iH
13 ][
14 .B \-oh
15 ][
16 .B \-oH
17 ][
18 .B "\-x xres \-y yres"
19 ][
20 .B \-oaN
21 |
22 .B \-ofN
23 |
24 .B \-odN
25 |
26 .B \-oiN
27 |
28 .B \-owN
29 |
30 .B \-obN
31 ][
32 .B \-f
33 ][
34 .B \-a
35 ][
36 .B "\-on M"
37 ]
38 output1 [options] output2 ..
39 .SH DESCRIPTION
40 .I Rsplit
41 writes lines or fields from the standard input to one or more output
42 streams.
43 By default, fields are separated by a
44 newline character (i.e., input is distributed by lines),
45 but the terminator can be changed using the
46 .I \-t
47 option.
48 If a space is specified as the terminator, then fields are separated by
49 any number of white spaces, including tabs, returns, and newlines.
50 Different terminators may be given for different fields by specifying
51 additional
52 .I \-t
53 options between each output specification.
54 Note that there is no space between this option and its argument, and
55 certain arguments, such as a space or a tab, must be quoted or escaped
56 with a backslash in most shells.
57 If no argument is given, the default newline terminator is re-established.
58 .PP
59 Output is either to a file, to a command, to the standard output, or to discard.
60 If a named output file exists, it will not be overwritten unless the
61 .I \-f
62 option is given, or it is being appended using the
63 .I \-a
64 option.
65 The same output file may not appear more than once.
66 Commands are given in quotes, and begin with an exclamantion point ('!').
67 At most, one command may reliably write to its standard output, and
68 doing so is incompatible with
69 .I rsplit
70 also writing to standard output.
71 A hyphen ('-') by itself tells
72 .I rsplit
73 to write directly to its standard output, and may appear multiple times.
74 The options before the first appearance determine the
75 standard output header parameters.
76 A period ('.') tells
77 .I rsplit
78 to discard the corresponding data, and also may appear multiple times.
79 .PP
80 The
81 .I \-oa
82 option may be used to specify ASCII data (the default), or the
83 .I \-of
84 option may be used to indicated binary IEEE 32-bit floats.
85 Similarly, the
86 .I \-od
87 and
88 .I \-oi
89 options may be used to indicate binary 64-bit doubles or integer words,
90 respectively.
91 The
92 .I \-ow
93 option specifies 2-byte short words, and the
94 .I \-ob
95 option specifies bytes.
96 If a number immediately follows any of these options, then it
97 indicates that multiple such values are expected for each record.
98 For example,
99 .I \-of3
100 indicates three floats per output record for the next named output.
101 In the case of the
102 .I \-oa
103 option, no number writes one line or field per stream, and numbers
104 greater than zero write multiple fields per record to the same stream.
105 If the terminating character is set to something other than newline ('\\n'),
106 a newline is added after each record (in addition to the terminator).
107 For binary output formts, no number implies one value per output.
108 No terminator characters are expected or written for binary outputs.
109 .PP
110 If a
111 .I \-on
112 option is given with a positive integer argument, this will be the
113 maximum number of records that will be written by
114 .I rsplit.
115 .PP
116 The
117 .I \-ih
118 option tells
119 .I rsplit
120 to expect a Radiance header on its input.
121 The
122 .I \-iH
123 option says to expect a resolution string for an image or similar.
124 The
125 .I \-x
126 and
127 .I \-y
128 options may alternatively be used to specify the input dimensions.
129 The
130 .I \-oh
131 option tells
132 .I rsplit
133 to produce a Radiance header on the next output stream.
134 The
135 .I \-oH
136 option will write a resolution string.
137 These options toggle the associated mode on and off,
138 so it is possible to have one output include a header or
139 resolution string and not the next by specifying the option(s) again.
140 Neither
141 .I \-oh
142 nor
143 .I \-oH
144 may be used with the append mode ('-a'), which may also be toggled.
145 .SH EXAMPLES
146 To alternate 5 lines between two output files:
147 .IP "" .2i
148 rsplit -oa5 output1.txt output2.txt < input.txt
149 .PP
150 To send the first of each double precision triplet to one file, and the second
151 and third to a second file, stopping after 500 triplets:
152 .IP "" .2i
153 rsplit -on 500 -od firstvals.dbl -od2 followingpairs.dbl < triplets.dbl
154 .PP
155 To convey material, color and distance information from rtrace to
156 separate files:
157 .IP "" .2i
158 vwrays [viewspec] | rtrace [options] -x 1024 -y 768 -h+ -oMlv octree | rsplit -ih -iH -t^I mats.txt -of depth.zbf -oh -oH -of3 '!pvalue -r -df > image.hdr'
159 .SH AUTHOR
160 Greg Ward
161 .SH "SEE ALSO"
162 cnt(1), histo(1), neaten(1), rcalc(1), rcode_depth(1),
163 rcode_ident(1), rcode_norm(1), rcode2bmp(1), rcrop(1),
164 rlam(1), rtpict(1), rtrace(1), split(1), tabfunc(1), total(1)
