root/radiance/doc/man/man1/robjutil.1
Revision: 1.8
Committed: Tue Jan 31 16:29:19 2023 UTC (2 years, 9 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.7: +3 -4 lines
docs(robjutil): improved clarity on +T option
1 .\" RCSid "$Id: robjutil.1,v 1.7 2021/04/15 23:51:04 greg Exp $"
2 .TH ROBJUTIL 1 3/31/20 RADIANCE
3 .SH NAME
4 robjutil - operate on Wavefront .OBJ file
5 .SH SYNOPSIS
6 .B robjutil
7 [
8 .B +/-r
9 ][
10 .B +/-v
11 ][
12 .B +/-t
13 ][
14 .B +/-n
15 ][
16 .B "+/-m mname"
17 ][
18 .B "+/-g gname"
19 ][
20 .B "-c epsilon"
21 ][
22 .B +T
23 ][
24 .B "-x 'xf spec'"
25 ]
26 [
27 .B input.obj ..
28 ]
29 .SH DESCRIPTION
30 .I Robjutil
31 reads and manipulates a Wavefront .OBJ file, removing degenerate and
32 duplicate faces.
33 If the
34 .I +r
35 option is specified, a Radiance scene description
36 will be produced on the standard output.
37 If
38 .I -r
39 is given, a modified .OBJ file will be sent to the standard output.
40 This is the default, and is more useful for preserving
41 texture coordinates if directed to
42 .I obj2mesh(1).
43 .PP
44 The
45 .I +v
46 option turns on verbose progress reports.
47 .PP
48 The
49 .I \-t
50 option tells
51 .I robjutil
52 to remove texture coordinates from the input.
53 The
54 .I \-n
55 option will cause all surface normals to be removed.
56 .PP
57 The
58 .I "\-m mname"
59 option tells
60 .I robjutil
61 to remove all faces that use the material
62 .I mname.
63 Multiple
64 .I \-m
65 options may be given, each with a single (unique) material name.
66 Alternatively, the
67 .I "+m mname"
68 option may be used to specify a material one wishes to keep, discarding the rest.
69 Multiple
70 .I +m
71 options will keep all the named materials.
72 The
73 .I \-m
74 and
75 .I \+m
76 options are mutually exclusive.
77 .PP
78 Similarly, the
79 .I "\-g gname"
80 option says to remove all faces belonging to the group
81 .I gname,
82 and multiple
83 .I \-g
84 options may be given.
85 There is also a
86 .I +g
87 option to save just the named group(s).
88 Object statements are treated the same as group statements in the input, so
89 .I +/-g
90 option can also be applied to object names.
91 Note that an object name will be overridden by a group name that follows
92 it in the input, and vice versa.
93 .PP
94 The
95 .I "\-c epsilon"
96 option tells
97 .I robjutil
98 to coalesce vertices that are within the given epsilon.
99 This is useful to improve the connectivity of models that were produced
100 in a sloppy conversion process from independent polygons.
101 When producing a Radiance file via the
102 .I +r
103 option, there will be no savings in the output size, but there can be
104 a benefit in reducing the number of "cracks" in the resulting geometry,
105 at least for triangle mesh input.
106 .I Robjutil
107 does not attempt to break up non-planar polygons into triangles,
108 which is usually not a problem for .OBJ output, but may be for Radiance
109 scene descriptions (+r).
110 To break all surfaces into triangles, include the
111 .I +T
112 option.
113 .PP
114 The
115 .I \-x
116 option may be used to specify a final transform to apply to all
117 coordinates in the file before output.
118 This specification must be contained in a single quoted word and
119 match the standard arguments used by
120 .I xform(1),
121 except that the
122 .I \-a
123 option is not supported for creating arrays of objects.
124 Also, any scaling factors do not affect the epsilon value given for
125 coalescing vertices, as this operation is applied prior to the transform,
126 even if
127 .I \-c
128 appears later in the command line.
129 .SH EXAMPLES
130 To remove degenerate and duplicate faces from "orig.obj" and write to "final.rad":
131 .IP "" .2i
132 robjutil +r orig.obj > final.rad
133 .PP
134 To extract only the groups "cat" and "bell" from the file "kitty.obj" and
135 write to a Radiance triangle mesh using materials from "kitty.mat":
136 .IP "" .2i
137 robjutil +g cat +g bell kitty.obj | obj2mesh -a kitty.mat > kitty.rtm
138 .PP
139 To rotate the scene 90 degrees about the Y-axis and scale by 10:
140 .IP "" .2i
141 robjutil -x "-ry 90 -s 10" orig.obj > transformed.obj
142 .SH NOTES
143 The .OBJ output of
144 .I robjutil
145 uses relative indices, so files it produces may be concatenated
146 on the input of other tools such as
147 .I obj2rad
148 and
149 .I obj2mesh
150 by piping from
151 .I cat(1)
152 or similar.
153 This offers a convenient way to separate geometry from a single .OBJ
154 input, manipulate it in some way, then recombine during conversion.
155 .PP
156 Unlike
157 .I obj2rad
158 and
159 .I obj2mesh,
160 .I robjutil
161 with the
162 .I +r
163 option will not substitute the group name for a material id if no
164 .I usemtl
165 statements are found on the input.
166 Instead, it will assign each surface the material
167 .I DEFAULT_MATERIAL.
168 Since it is possible to use the
169 .I +/-g
170 option to select groups to include or exclude on output, it is
171 still possible to assign materials by group manually.
172 .SH AUTHOR
173 Greg Ward
174 .SH "SEE ALSO"
175 cat(1), genbox(1), gensurf(1), obj2mesh(1), obj2rad(1) oconv(1), xform(1)
