| 1 |
.\" RCSid "$Id: rmtxop.1,v 1.22 2021/01/21 17:47:07 greg Exp $"
| 2 |
.TH RMTXOP 1 5/31/2014 RADIANCE
| 3 |
.SH NAME
| 4 |
rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices
| 5 |
.SH SYNOPSIS
| 6 |
.B rmtxop
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B \-f[afdc]
| 11 |
| 12 |
.B \-t
| 13 |
| 14 |
.B "\-s sf .."
| 15 |
| 16 |
.B "\-c ce .."
| 17 |
| 18 |
.B "\-rf|\-rb"
| 19 |
| 20 |
.B m1
| 21 |
| 22 |
.B ".+*/"
| 23 |
| 24 |
.B ".."
| 25 |
.SH DESCRIPTION
| 26 |
.I Rmtxop
| 27 |
loads and concatenates or adds/multiplies/divides
| 28 |
together component matrix files given on the command line.
| 29 |
Each file must have a header containing the following variables:
| 30 |
.sp
| 31 |
.nf
| 32 |
NROWS={number of rows}
| 33 |
NCOLS={number of columns}
| 34 |
NCOMP={number of components}
| 35 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze}
| 36 |
.sp
| 37 |
.fi
| 38 |
The number of components indicates that each matrix element is actually
| 39 |
composed of multiple elements, most commonly an RGB triple.
| 40 |
This is essentially dividing the matrix into planes, where each component
| 41 |
participates in a separate calculation.
| 42 |
If an appropriate header is not present, it may be added with a call to
| 43 |
.I rcollate(1).
| 44 |
A matrix may be read from the standard input using a hyphen by itself ('-')
| 45 |
in the appropriate place on the command line.
| 46 |
.PP
| 47 |
Any of the matrix inputs may be read from a command
| 48 |
instead of a file by
| 49 |
using quotes and a beginning exclamation point ('!').
| 50 |
.PP
| 51 |
Two special cases are handled for component matrices that are either
| 52 |
XML files containing BSDF data, or Radiance picture files.
| 53 |
In the first case, the BSDF library loads and interprets the
| 54 |
transmission matrix by default.
| 55 |
Alternatively, the front (normal-side) reflectance is selected if the
| 56 |
.I \-rf
| 57 |
option precedes the file name, or the backside reflectance if
| 58 |
.I \-rb
| 59 |
is specified.
| 60 |
(XML files cannot be read from the standard input or from a command.)\0
| 61 |
In the second case, the RGBE or XYZE values are loaded in a 3-component
| 62 |
matrix where the number of columns match the X-dimension of the picture, and
| 63 |
the number of rows match the Y-dimension.
| 64 |
The picture must be in standard pixel ordering, and the first row
| 65 |
is at the top with the first column on the left.
| 66 |
Any exposure changes that were applied to the pictures before
| 67 |
.I rmtxop
| 68 |
will be undone, similar to the
| 69 |
.I pcomb(1)
| 70 |
.I \-o
| 71 |
option.
| 72 |
.PP
| 73 |
Before each file, the
| 74 |
.I \-t
| 75 |
and
| 76 |
.I \-s
| 77 |
or
| 78 |
.I \-c
| 79 |
options may be used to modify the matrix.
| 80 |
The
| 81 |
.I \-t
| 82 |
option transposes the matrix, swapping rows and columns.
| 83 |
The
| 84 |
.I \-s
| 85 |
option applies the given scalar factor(s) to the elements of the matrix.
| 86 |
If only one factor is provided,
| 87 |
it will be used for all components.
| 88 |
If multiple factors are given, their number must match the number of matrix
| 89 |
components.
| 90 |
Alternatively, the
| 91 |
.I \-c
| 92 |
option may be used to "transform" the element values, possibly changing
| 93 |
the number of components in the matrix.
| 94 |
For example, a 3-component matrix can be transformed into a single-component
| 95 |
matrix by using
| 96 |
.I \-c
| 97 |
with three coefficients.
| 98 |
A four-component matrix can be turned into a two-component matrix using 8
| 99 |
coefficients, where the first four coefficients will be used to compute
| 100 |
the first new component, and the second four coefficients
| 101 |
yield the second new component.
| 102 |
Note that the number of coefficients must be an even multiple of the number
| 103 |
of original components.
| 104 |
The
| 105 |
.I \-s
| 106 |
and
| 107 |
.I \-c
| 108 |
options are mutually exclusive, insofar as they cannot be applied together
| 109 |
to the same input matrix.
| 110 |
.PP
| 111 |
If present, the second and subsequent matrices on the command
| 112 |
line are concatenated together, unless separated by a plus ('+'),
| 113 |
asterisk ('*'), or forward slash ('/') symbol,
| 114 |
in which case the individual matrix elements are added,
| 115 |
multiplied, or divided, respectively.
| 116 |
The concatenation operator ('.') is the default and need not be specified.
| 117 |
Note also that the asterisk must be quoted or escaped in most shells.
| 118 |
In the case of addition, the two matrices involved must have the same number
| 119 |
of components.
| 120 |
If subtraction is desired, use addition ('+') with a scaling parameter of -1
| 121 |
for the second matrix (the
| 122 |
.I \-s
| 123 |
option).
| 124 |
For element-wise multiplication and division, the second matrix is
| 125 |
permitted to have a single component per element, which will be
| 126 |
applied equally to all components of the first matrix.
| 127 |
If element-wise division is specified, any zero elements in the second
| 128 |
matrix will result in a warning and the corresponding component(s) in the
| 129 |
first matrix will be set to zero.
| 130 |
.PP
| 131 |
Evaluation proceeds from left to right, and all operations have
| 132 |
the same precedence.
| 133 |
If a different evaluation order is desired, pipe the result of one
| 134 |
.I rmtxop
| 135 |
command into another, as shown in one of the examples below.
| 136 |
.PP
| 137 |
The number of components in the next matrix after applying any
| 138 |
.I -c
| 139 |
transform must agree with the prior result.
| 140 |
For concatenation (matrix multiplication), the number of columns
| 141 |
in the prior result must equal the number of rows in the next matrix, and
| 142 |
the result will have the number of rows of the previous and the number
| 143 |
of columns of the next matrix.
| 144 |
In the case of addition, multiplication, and division,
| 145 |
the number of rows and columns of the prior result and the
| 146 |
next matrix must match, and will not be changed by the operation.
| 147 |
.PP
| 148 |
A final transpose or scaling/transform operation may be applied to
| 149 |
the results by appending the
| 150 |
.I \-t
| 151 |
and
| 152 |
.I \-s
| 153 |
or
| 154 |
.I \-c
| 155 |
options after the last matrix on the command line.
| 156 |
.PP
| 157 |
Results are sent to the standard output.
| 158 |
By default, the values will be written in the lowest resolution format
| 159 |
among the inputs, but the
| 160 |
.I \-f
| 161 |
option may be used to explicitly output components
| 162 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or RGBE colors (-fc).
| 163 |
In the latter case, the actual matrix dimensions are written in the resolution
| 164 |
string rather than the header.
| 165 |
Also, matrix results written as Radiance pictures must have either one
| 166 |
or three components.
| 167 |
In the one-component case, the output is written as grayscale.
| 168 |
.PP
| 169 |
The
| 170 |
.I \-v
| 171 |
option turns on verbose reporting, which announces each operation.
| 172 |
.SH EXAMPLES
| 173 |
To concatenate two matrix files with a BTDF between them and write
| 174 |
the result as binary double:
| 175 |
.IP "" .2i
| 176 |
rmtxop -fd view.vmx blinds.xml exterior.dmx > dcoef.dmx
| 177 |
.PP
| 178 |
To convert a BTDF matrix into a Radiance picture:
| 179 |
.IP "" .2i
| 180 |
rmtxop -fc blinds.xml > blinds.hdr
| 181 |
.PP
| 182 |
To extract the luminance values from a picture as an ASCII matrix:
| 183 |
.IP "" .2i
| 184 |
rmtxop -fa -c .265 .670 .065 image.hdr > image_lum.mtx
| 185 |
.PP
| 186 |
To scale a matrix by 4 and add it to the transpose of another matrix:
| 187 |
.IP "" .2i
| 188 |
rmtxop -s 4 first.mtx + -t second.mtx > result.mtx
| 189 |
.PP
| 190 |
To multiply elements of two matrices, then concatenate with a third,
| 191 |
applying a final transpose to the result:
| 192 |
.IP "" .2i
| 193 |
rmtxop first.mtx \\* second.mtx . third.mtx -t > result.mtx
| 194 |
.PP
| 195 |
To left-multiply the element-wise division of two matrices:
| 196 |
.IP "" .2i
| 197 |
rmtxop -fd numerator.mtx / denominator.mtx | rmtxop left.mtx - > result.mtx
| 198 |
.PP
| 199 |
To send the elements of a binary matrix to
| 200 |
.I rcalc(1)
| 201 |
for further processing:
| 202 |
.IP "" .2i
| 203 |
rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations]
| 204 |
.SH NOTES
| 205 |
Matrix concatenation is associative but not commutative, so order
| 206 |
matters to the result.
| 207 |
.I Rmtxop
| 208 |
takes advantage of this associative property to concatenate
| 209 |
from right to left when it reduces the number of basic operations.
| 210 |
If the rightmost matrix is a column vector for example, it is
| 211 |
much faster to concatenate from the right, and the result will
| 212 |
be the same.
| 213 |
Note that this only applies to concatenation;
| 214 |
element-wise addition, multiplication, and division are always
| 215 |
evaluated from left to right.
| 216 |
.SH AUTHOR
| 217 |
Greg Ward
| 218 |
.SH "SEE ALSO"
| 219 |
cnt(1), getinfo(1), histo(1), neaten(1), pcomb(1), rcalc(1),
| 220 |
rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1), rlam(1),
| 221 |
rsplit(1), tabfunc(1), total(1), wrapBSDF(1)
