| 1 |
.\" RCSid "$Id: rmtxop.1,v 1.8 2015/02/20 18:26:09 greg Exp $"
| 2 |
.TH RMTXOP 1 7/8/97 RADIANCE
| 3 |
.SH NAME
| 4 |
rmtxop - concatenate, add, transpose, scale, and convert matrices
| 5 |
.SH SYNOPSIS
| 6 |
.B rmtxop
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B \-f[afdc]
| 11 |
| 12 |
.B \-t
| 13 |
| 14 |
.B "\-s sf .."
| 15 |
| 16 |
.B "\-c ce .."
| 17 |
| 18 |
.B m1
| 19 |
| 20 |
.B +
| 21 |
| 22 |
.B ".."
| 23 |
.SH DESCRIPTION
| 24 |
.I Rmtxop
| 25 |
loads and concatenates (multiplies) or adds together component matrix files
| 26 |
given on the command line.
| 27 |
Each file must have a header containing the following variables:
| 28 |
.sp
| 29 |
.nf
| 30 |
NROWS={number of rows}
| 31 |
NCOLS={number of columns}
| 32 |
NCOMP={number of components}
| 33 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze}
| 34 |
.sp
| 35 |
.fi
| 36 |
The number of components indicates that each matrix element is actually
| 37 |
composed of multiple elements, most commonly an RGB triple.
| 38 |
This is essentially dividing the matrix into planes, where each component
| 39 |
participates in a separate calculation.
| 40 |
If an appropriate header is not present, it may be added with a call to
| 41 |
.I rcollate(1).
| 42 |
A matrix may be read from the standard input using a hyphen by itself ('-')
| 43 |
in the appropriate place on the command line.
| 44 |
.PP
| 45 |
Any of the matrix inputs may be read from a command
| 46 |
instead of a file by
| 47 |
using quotes and a beginning exclamation point ('!').
| 48 |
.PP
| 49 |
Two special cases are handled for component matrices that are either
| 50 |
XML files containing BTDF data, or Radiance picture files.
| 51 |
In the first case, a BSDF library is used to load and interpret the
| 52 |
transmission matrix.
| 53 |
(XML files cannot be read from the standard input or from a command.)\0
| 54 |
In the second case, the RGBE or XYZE values are loaded in a 3-component
| 55 |
matrix where the number of columns match the X-dimension of the picture, and
| 56 |
the number of rows match the Y-dimension.
| 57 |
The picture must be in standard pixel ordering, and the first row
| 58 |
is at the top with the first column on the left.
| 59 |
.PP
| 60 |
Before each file, the
| 61 |
.I \-t
| 62 |
and
| 63 |
.I \-s
| 64 |
or
| 65 |
.I \-c
| 66 |
options may be used to modify the matrix.
| 67 |
The
| 68 |
.I \-t
| 69 |
option transposes the matrix, swapping rows and columns.
| 70 |
The
| 71 |
.I \-s
| 72 |
option applies the given scalar factor(s) to the elements of the matrix.
| 73 |
If only one factor is provided,
| 74 |
it will be used for all components.
| 75 |
If multiple factors are given, their number must match the number of matrix
| 76 |
components.
| 77 |
Alternatively, the
| 78 |
.I \-c
| 79 |
option may be used to "transform" the element values, possibly changing
| 80 |
the number of components in the matrix.
| 81 |
For example, a 3-component matrix can be transformed into a single-component
| 82 |
matrix by using
| 83 |
.I \-c
| 84 |
with three coefficients.
| 85 |
A four-component matrix can be turned into a two-component matrix using 8
| 86 |
coefficients, where the first four coefficients will be used to compute
| 87 |
the first new component, and the second four coefficients
| 88 |
yield the second new component.
| 89 |
Note that the number of coefficients must be an even multiple of the number
| 90 |
of original components.
| 91 |
The
| 92 |
.I \-s
| 93 |
and
| 94 |
.I \-c
| 95 |
options are mutually exclusive, insofar as they cannot be applied together
| 96 |
to the same input matrix.
| 97 |
.PP
| 98 |
If present, the second and subsequent matrices on the command
| 99 |
line are concatenated to the result unless separated by a plus ('+') symbol,
| 100 |
in which case the elements are added together.
| 101 |
The number of components in the new matrix after applying any
| 102 |
.I -c
| 103 |
transform must agree with the prior result.
| 104 |
For concatenation (matrix multiplication), the number of columns
| 105 |
in the prior result must equal the number of rows in the new matrix, and
| 106 |
the result will have the number of rows of the previous and the number
| 107 |
of columns of the new matrix.
| 108 |
In the case of addition, the number of rows and columns of the prior
| 109 |
result and the new matrix must match, and will not be changed by the
| 110 |
operation.
| 111 |
.PP
| 112 |
Results are sent to the standard output.
| 113 |
By default, the values will be written in the lowest resolution format
| 114 |
among the inputs, but the
| 115 |
.I \-f
| 116 |
option may be used to explicitly output components
| 117 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or RGBE colors (-fc).
| 118 |
In the latter case, the actual matrix dimensions are written in the resolution
| 119 |
string rather than the header.
| 120 |
Also, matrix results written as Radiance pictures must have either one
| 121 |
or three components.
| 122 |
In the one-component case, the output is written as grayscale.
| 123 |
.PP
| 124 |
The
| 125 |
.I \-v
| 126 |
option turns on verbose reporting, which announces each operation.
| 127 |
.SH EXAMPLES
| 128 |
To concatenate two matrix files with a BTDF between them and write
| 129 |
the result as binary double:
| 130 |
.IP "" .2i
| 131 |
rmtxop -fd view.vmx blinds.xml exterior.dmx > dcoef.dmx
| 132 |
.PP
| 133 |
To convert a BTDF matrix into a Radiance picture:
| 134 |
.IP "" .2i
| 135 |
rmtxop -fc blinds.xml > blinds.hdr
| 136 |
.PP
| 137 |
To scale a matrix by 4 and add it to the transpose of another matrix:
| 138 |
.IP "" .2i
| 139 |
rmtxop -s 4 left.mtx + -t right.mtx > result.mtx
| 140 |
.PP
| 141 |
To send the elements of a binary matrix to
| 142 |
.I rcalc(1)
| 143 |
for further processing:
| 144 |
.IP "" .2i
| 145 |
rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations]
| 146 |
.SH AUTHOR
| 147 |
Greg Ward
| 148 |
.SH "SEE ALSO"
| 149 |
cnt(1), getinfo(1), histo(1), neaten(1), rcalc(1), rcollate(1),
| 150 |
rcontrib(1), rfluxmtx(1), rlam(1), tabfunc(1), total(1), wrapBSDF(1)
