docs: Added rxfluxmtx man page and updated others accordingly
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
docs: Minor wording fixes
docs(rcomb,rmtxop): Added BUGS section
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
feat(rtpict): Added -co+ option support for hyperspectral image output
feat(pfilt): Added support for hyperspectral image filtering
docs(rmtxcomb): Added man page for new rmtxcomb tool
feat(rmtxop): Added -c _file_ and -C options for specifying color spaces
feat(rmtxop): Added 'A' symbolic component for average of all channels
feat(rmtxop): Added symbolic transforms to -c option and made -s apply after any such transform, so both may be used simultaneously
docs: Added mention of Radiance spectral picture support
feat(rcrop): Created simple cropping utility for matrices and pictures
docs: formatting of option reminder
docs: typo
docs: formatting fix
Replaced confusing use of "new" with "next" when talking about matrix ops
Further clarifications and examples
Fixed argument parsing issue and added further explanations to man page
Added mention of rsplit(1)
Clarification
Minor fix
typo
Fixed typos
Added missing -fc option in usage line
Added rmtxop command for manipulating component matrices
