docs: Added rxfluxmtx man page and updated others accordingly
docs: Wording fixes to man pages regarding -e and -f options
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
fix(rcontrib): Added a check that the number of color samples doesn't change after the first modifier is specified
docs(rmtxcomb): Added man page for new rmtxcomb tool
docs: made use of "virtual" and "secondary" sources more consistent
doc(rcontrib): Clarified -x and -y settings and interactions with -c, -t
Allow for colon as separator in parameter settings
Added warning for contribution coefficient calculation with participating media
Referred to rtrace for pmap settings
Revised documentation of rcontrib's photon mapping mode; Promoted from experimental (to semi-mature? ;^)
Silently ignore negative bin values.
Corrected errors in description
Corrected errors in final example mentioned by Lars Grobe
Added -bn requirement
Removed inaccurate references to rtrace subprocesses.
Missed a couple of other name changes
Missed one name change
