root/radiance/doc/man/man1/rcomb.1
Revision: 1.15
Committed: Thu Oct 23 23:34:59 2025 UTC (9 days, 21 hours ago) by greg
Changes since 1.14: +2 -2 lines
docs: Added rxfluxmtx man page and updated others accordingly
# User Rev Content
1 greg 1.15 .\" RCSid "$Id: rcomb.1,v 1.14 2025/06/19 22:36:53 greg Exp $"
2 greg 1.1 .TH RCOMB 12/5/2023 RADIANCE
3     .SH NAME
4     rcomb - combine and convert matrices a row at a time
5     .SH SYNOPSIS
6     .B rcomb
7     [
8     .B \-h
9     ][
10     .B \-w
11     ][
12     .B \-f[afdc]
13     ][
14 greg 1.8 .B "\-n nproc"
15     ][
16 greg 1.1 .B "\-f file"
17     ][
18     .B "\-e expr"
19     ][
20     .B "\-C {symbols|file}"
21     ][
22     .B "\-c ce .."
23     ][
24     .B "\-s sf .."
25     ]
26     .B "m1 .."
27     [
28 greg 1.14 .B "\-m[t] mcat"
29 greg 1.1 ]
30     .SH DESCRIPTION
31     .I Rcomb
32     combines inputs given on the command line,
33     one matrix row or picture scanline at a time.
34     By default, the result is a linear combination of
35     the matrix elements or pixels transformed by
36     .I \-c
37     specifications and scaled by
38     .I \-s
39     coefficients, but an arbitrary mapping can be assigned with the
40     .I \-e
41     and
42     .I \-f
43     options, similar to the
44     .I pcomb(1)
45     and
46     .I rcalc(1)
47     commands.
48     (The definitions in each
49     .I \-f source
50     file are read and compiled from the RADIANCE library where it is found.)\0
51     .PP
52     If any
53     .I \-c
54     or
55     .I \-s
56     options follow the last input matrix, output results will be transformed
57     and/or scaled accordingly.
58 greg 1.7 These operations are discussed in greater detail below.
59 greg 1.1 A single concatenation matrix may be applied after element operations
60     using the
61     .I \-m
62     option.
63 greg 1.14 If the option is given as
64     .I \-mt
65     then the concatenation matrix will be transposed before it is applied.
66 greg 1.1 Matrix concatenation will happen before or after any trailing
67     operations, depending on relative command line placement.
68     .PP
69     Each input file must have a header containing the following metadata:
70     .sp
71     .nf
72     NROWS={number of rows}
73     NCOLS={number of columns}
74     NCOMP={number of components}
75     FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
76     .fi
77     .sp
78     The number of components indicates that each matrix element is actually
79 greg 1.7 composed of multiple channels, most commonly an RGB triple.
80 greg 1.1 This is essentially dividing the matrix into planes, where each component
81     participates in a separate calculation.
82     If an appropriate header is not present, it may be added with a call to
83     .I rcollate(1).
84     A matrix may be read from the standard input using a hyphen by itself ('-')
85     in the appropriate place on the command line.
86     Similarly, any of the inputs may be read from a command
87     instead of a file by
88     using quotes and a beginning exclamation point ('!').
89     .PP
90     In the case of Radiance picture files,
91     the number of columns is the X-dimension of the picture, and
92     the number of rows is the Y-dimension.
93     The picture must be in standard pixel ordering, and the zeroeth row
94     is at the top with the zeroeth column on the left.
95     Any exposure changes that were applied to the pictures before
96     .I rcomb
97     will be undone, similar to the
98     .I "pcomb \-o"
99     option.
100     Radiance spectral pictures with more than 3 components are also supported.
101     These are typically produced by
102 greg 1.5 .I rtpict(1)
103 greg 1.1 or
104     .I rfluxmtx(1).
105     .PP
106     Before each input, the
107     .I \-c
108     and/or
109     .I \-s
110     options may be used to modify the matrix elements.
111     The
112     .I \-c
113     option can "transform" the element values, possibly changing
114     the number of components in the matrix.
115     For example, a 3-component matrix can be transformed into a single-component
116     matrix by using
117     .I \-c
118     with three coefficients.
119     A four-component matrix can be turned into a two-component matrix using 8
120     coefficients, where the first four coefficients will be used to compute
121     the first new component, and the second four coefficients
122     yield the second new component.
123     Note that the number of coefficients must be an even multiple of the number
124     of original components.
125     .PP
126     Alternatively, a set of symbolic output components may be given to the
127     .I \-c
128     option, with the following definitions:
129     .sp
130     .nf
131     R - red channel
132     G - green channel
133     B - blue channel
134     X - CIE X channel
135     Y - CIE Y channel (aka., luminance or illuminance)
136     Z - CIE Z channel
137     S - scotopic luminance or illuminance
138     M - melanopic luminance or illuminance
139     A - average component value
140     .fi
141     .sp
142     These letters may be given in any order as a single string, and if
143     .I "-c RGB"
144     or
145     .I "-c XYZ"
146     is specified for an input picture or the
147     .I "-fc"
148     option is given, the output will be written as a RGBE or XYZE picture.
149 greg 1.9 Note that conversion from a float or RGBE color space applies an efficacy factor
150 greg 1.1 of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
151 greg 1.9 and the inverse happens for conversion from XYZE input to RGB or RGBE output.
152 greg 1.3 Lower case versions of all these components are also supported, the only
153 greg 1.9 difference being that the efficacy factors are ignored.
154 greg 1.1 .PP
155     If a matrix or picture file path is given to the
156     .I \-c
157     option, then the color space of that file will be used, instead.
158     .PP
159     The
160     .I \-C
161     option takes either a symbolic color space or an input file, and will be
162     applied to all subsequent matrices that do not have their own associated
163     .I \-c
164     option.
165     .PP
166     Additionally, the
167     .I \-s
168     option applies the given scalar factor(s) to the elements of the matrix.
169     If only one factor is provided,
170     it will be used for all components.
171     If multiple factors are given, their number must match the number of matrix
172     components
173     .I after
174     application of any
175     .I \-c
176     option for this input matrix or picture, even if the
177     .I \-s
178     option appears first.
179     .PP
180     The number of components in all input
181     matrices after applying any
182     .I -c
183     transform must agree.
184     Similarly, the number of rows and columns of all results must match
185     exactly.
186     (The
187     .I rcrop(1)
188     utility may be used to trim inputs if necessary.)\0
189     .PP
190     If the
191     .I \-e
192     or
193     .I \-f
194     options are used to define a "co" variable or "co(p)" function,
195 greg 1.7 which will be evaluated for each output
196     component from the current element.
197 greg 1.1 The "co" variable defines identical operations for all components,
198     whereas "co(p)" may specify different operations for each component.
199     The element position is defined
200     by the "r" and "c" variables, where
201     .I r
202     goes from 0 to "nrows" minus one, and
203     .I c
204     goes from 0 to "ncols" minus one.
205 greg 1.2 (Note that "nrows" may be zero if unspecified in inputs, and this
206     is a unique capability of
207     .I rcomb
208     to handle these.)\0
209 greg 1.1 Component p from input i is accessed with the "ci(i,p)" function,
210     and the number of components is defined by the "ncomp" constant.
211     If given as "ci(i)", the function returns the current component
212     being evaluated by
213     .I rcomb.
214 greg 1.6 A different component may be referenced using the second argument.
215 greg 1.1 For example, "ci(1,2)" accesses
216     the second component from the first input.
217     If the input is a picture, the the constants "R", "G", and "B"
218     are conveniently defined as the channel numbers 1, 2, and 3,
219     respectively.
220     For color or spectral inputs, the function "wl(p)" gives the
221     central wavelength for channel
222     .I p
223     in nanometers.
224     For convenience and compatibility with
225     .I pcomb,
226     the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as
227     "ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively.
228     Accordingly, the "ro", "go", and "bo"
229 greg 1.6 variables may be used in place of "co(R)", "co(G)", and "co(B)",
230     but all three must be defined for this substitution to take place.
231 greg 1.1 Finally, the total number of input files is set in the constant "nfiles".
232     .PP
233     Results are sent to the standard output.
234     By default, the values will be written in the lowest precision format
235     among the inputs, but the
236     .I \-f[adfc]
237     option may be used to explicitly output components
238     as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
239     colors/spectra (-fc).
240     In the latter case, the actual matrix dimensions are written in the resolution string rather than the header.
241     Also, matrix results will be written as standard
242     Radiance pictures if they have either one
243     or three components.
244     In the one-component case, the output is written as grayscale.
245     If more than 3 components are in the final matrix and
246     .I -fc
247     is specified, the output will be a Radiance spectral picture.
248     .PP
249     The
250     .I \-h
251     option may be used to reduce the information header size, which
252     can grow disproportionately, otherwise.
253     The
254     .I \-w
255     option turns off warnings about divide-by-zero and other non-fatal
256     calculation errors.
257 greg 1.8 .PP
258     The
259     .I \-n
260     option specifies how many execution processes to employ,
261     which may improve performance on multi-core architectures,
262     especially for matrix multiplication
263     and complex operations on long input rows.
264 greg 1.1 .SH EXAMPLES
265 greg 1.10 To convert two hyperspectral pictures to RGB color space,
266 greg 1.1 average them together, and write them out as a RADIANCE picture:
267     .IP "" .2i
268 greg 1.10 rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr
269 greg 1.1 .PP
270     Divide one set of matrix elements by the Euclidean sum of two others:
271     .IP "" .2i
272     rcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx
273     inp2.mtx inp3.mtx > out.mtx
274     .PP
275     Compute the absolute and relative differences between melanopic and photopic values
276     in a spectral image:
277     .IP "" .2i
278 greg 1.10 rcomb -C MY -e "abs(x):if(x,x,-x)"
279 greg 1.1 -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))"
280 greg 1.10 input_spec.hsr -fa > compare.mtx
281 greg 1.1 .PP
282     Concatenate a spectral flux coefficient matrix with a spectral sky
283     matrix to compute a set of melanopic lux values:
284     .IP "" .2i
285     rcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx
286     .SH NOTES
287     The
288     .I rcomb
289     tool was created to overcome some limitations of
290     .I rmtxop
291     and
292     .I pcomb,
293     whose capabilities somewhat overlap.
294     The former loads each matrix into memory before operations,
295 greg 1.7 and element components are stored as double-precision.
296 greg 1.1 Very large matrices therefore present a problem with that tool.
297     Furthermore,
298     .I rmtxop
299     does not allow arbitrary expressions, limiting
300     what can be accomplished easily on the command-line.
301     In contrast,
302     .I pcomb
303     is fully programmable and operates on its input using a
304     scanline window, so it can handle much larger input dimensions.
305     It also handles single- and three-component float matrices on
306     input and output, but unlike
307     .I rmtxop,
308     .I pcomb
309     has not been extended to handle RADIANCE hyperspectral images
310     or more general matrix data.
311     .PP
312     The
313     .I rcomb
314     tool is a compromise that exceeds the capabilities of either of
315     its predecessors in certain circumstances.
316     In particular, very large matrices may be combined using
317     arbitrary, user-defined operations, and the convenient
318     color conversions of
319     .I rmtxop
320     are supported for both input and output.
321     Finally, a single matrix may be concatenated after operations,
322     permitting a flux transfer matrix with millions of rows to
323     pass through.
324     Generally speaking,
325     .I rcomb
326     should be preferred over
327     .I rmtxop
328 greg 1.7 for any operations it can handle, which is everything except
329 greg 1.1 multiple matrix concatenations and transpose
330 greg 1.7 operations.
331     The latter may be handled more efficiently by
332     .I rcollate(1).
333 greg 1.1 That said, there is no significant difference for
334 greg 1.7 simple operations on small matrices, and only
335 greg 1.1 .I rmtxop
336     and
337     .I dctimestep(1)
338 greg 1.7 accept XML files as inputs.
339     Also note that the resizing function of
340 greg 1.1 .I pcomb
341     is not supported in
342     .I rcomb,
343     and should instead be handled by
344     .I pfilt(1).
345 greg 1.13 .PP
346     Similar to
347     .I rmtxop,
348     all calculations are peformed internally using 32-bit floating-point,
349     so there is little benefit in either reading or writing 64-bit double
350     data.
351     This may be overridden at compile time using the macro
352     "-DDTrmx_native=DTdouble".
353 greg 1.4 .SH BUGS
354     The
355     .I rcomb
356     command currently ignores the "PRIMARIES" setting in input
357     headers, and does not produce any on output, even in
358     circumstances where it would make sense to.
359 greg 1.1 .SH AUTHOR
360     Greg Ward
361     .SH "SEE ALSO"
362     dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1),
363 greg 1.12 pvsum(1), ra_rgbe(1), ra_xyze(1), rcalc(1),
364 greg 1.1 rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
365 greg 1.15 rmtxop(1), rtpict(1), rtrace(1), rxfluxmtx(1), vwrays(1)
