root/radiance/doc/man/man1/rcollate.1
Fri Jan 26 00:47:17 2024 UTC (21 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 1.18: +8 -4 lines
Diff to previous 1.18
feat(rcollate): Made -c option override new -fbN behavior
Thu Jan 25 19:25:50 2024 UTC (21 months ago) by greg
Changes since 1.17: +8 -3 lines
Diff to previous 1.17
feat(rcollate): Made -fbN where N>1 to specify exact input record size
Wed Dec 6 01:27:00 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 1.16: +3 -3 lines
Diff to previous 1.16
docs(rmtxcomb): Added man page for new rmtxcomb tool
Wed Mar 16 17:36:45 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15
feat(rcollate): Added formatting check for ASCII input with -c option
Tue Mar 15 00:25:50 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.14: +3 -3 lines
Diff to previous 1.14
feat(rcrop): Created simple cropping utility for matrices and pictures
Mon Sep 7 17:08:08 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.13: +14 -2 lines
Diff to previous 1.13
feat(rcollate): Added -c option to force operation with checks.
Mon Nov 11 18:50:07 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.12: +18 -17 lines
Diff to previous 1.12
Further wording improvments and details
Mon Nov 11 18:38:41 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.11: +5 -4 lines
Diff to previous 1.11
Improved wording
Fri Nov 8 22:19:23 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.10
More specific wording
Fri Nov 8 05:39:05 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.9: +5 -1 lines
Diff to previous 1.9
Fixing minor issues with new -o code
Fri Nov 8 02:10:38 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.8: +22 -1 lines
Diff to previous 1.8
Added capability to rcollate for reblocking input order for tensors
Sat Jul 20 00:57:43 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.7: +4 -3 lines
Diff to previous 1.7
Added mention of rsplit(1)
Sat May 31 21:33:21 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.6: +8 -3 lines
Diff to previous 1.6
Added rmtxop command for manipulating component matrices
Fri May 30 16:50:43 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.5: +10 -4 lines
Diff to previous 1.5
Added -hi and -ho options to control input and output headers separately
Fri May 30 00:00:54 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.4: +11 -1 lines
Diff to previous 1.4
Wed Sep 18 21:24:36 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 1.3
Added missing word
Fri Sep 6 21:34:38 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.2: +6 -1 lines
Diff to previous 1.2
Added -w option to turn off warnings
Thu Sep 5 18:50:30 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.1: +8 -12 lines
Minor wording fixes
Thu Sep 5 17:53:22 2013 UTC (12 years, 1 month ago) by greg
