| 1 |
greg |
1.1 |
.TH RCODE2BMP 1 7/25/2019 RADIANCE |
| 2 |
.SH NAME |
| 3 |
rcode2bmp - convert identifier, depth, and normal maps to BMP images |
| 4 |
.SH SYNOPSIS |
| 5 |
.B rcode2bmp |
| 6 |
| 7 |
.B "\-x xres \-y yres" |
| 8 |
| 9 |
.B input1.typ |
| 10 |
| 11 |
.B "input2.typ .." |
| 12 |
| 13 |
.SH DESCRIPTION |
| 14 |
.I Ra_bmp |
| 15 |
converts each input map to a suitable visualization as a BMP image. |
| 16 |
greg |
1.2 |
Supported types include Radiance pictures and hyperspectral images, |
| 17 |
depth maps produced by |
| 18 |
greg |
1.1 |
.I rcode_depth(1), |
| 19 |
identifier maps from |
| 20 |
.I rcode_ident(1), |
| 21 |
and surface normal maps from |
| 22 |
.I rcode_norm(1). |
| 23 |
Each input file is identified by the FORMAT string it its header, |
| 24 |
and if it belongs to one of the supported types, a new file with the |
| 25 |
same name will be created with its suffix replaced by ".bmp". |
| 26 |
If a previous BMP file exists with the same name, it will be overwritten. |
| 27 |
.PP |
| 28 |
Radiance pictures are tone-mapped as if calling: |
| 29 |
.IP "" .2i |
| 30 |
ra_bmp -e auto file.hdr file.bmp |
| 31 |
.PP |
| 32 |
If the |
| 33 |
.I \-x |
| 34 |
and |
| 35 |
.I \-y |
| 36 |
options are given, these will be used as the maximum output image dimensions, |
| 37 |
and this holds for all input types. |
| 38 |
.PP |
| 39 |
Depth maps from |
| 40 |
.I rcode_depth |
| 41 |
are processed using |
| 42 |
.I falsecolor(1) |
| 43 |
with an appropriate scale and label. |
| 44 |
.PP |
| 45 |
Identifier maps from |
| 46 |
.I rcode_ident |
| 47 |
are assigned a random color for each identifier. |
| 48 |
.PP |
| 49 |
Surface normal maps are processed using an HSV (hue, saturation, value) |
| 50 |
color space that assigns normal orientation |
| 51 |
to a hue angle, and saturation runs from 0 when the normal is aligned to |
| 52 |
the view origin, to maximum saturation at tangential edges. |
| 53 |
Back-facing normals will be darker -- a normal in the direction opposite |
| 54 |
to the viewer being pure black. |
| 55 |
.SH AUTHOR |
| 56 |
Greg Ward |
| 57 |
.SH "SEE ALSO" |
| 58 |
falsecolor(1), ra_bmp(1), rcode_depth(1), rcode_ident(1), rcode_norm(1), |
| 59 |
greg |
1.2 |
rcomb(1), rtpict(1) |
