| 1 |
.\" RCSid "$Id: rcalc.1,v 1.16 2022/03/11 22:50:13 greg Exp $"
| 2 |
.TH RCALC 1 4/6/99 RADIANCE
| 3 |
.SH NAME
| 4 |
rcalc - record calculator
| 5 |
.SH SYNOPSIS
| 6 |
.B rcalc
| 7 |
| 8 |
.B \-b
| 9 |
| 10 |
.B \-l
| 11 |
| 12 |
.B "\-p | \-P"
| 13 |
| 14 |
.B \-n
| 15 |
| 16 |
.B \-w
| 17 |
| 18 |
.B \-u
| 19 |
| 20 |
.B \-tS
| 21 |
| 22 |
.B "\-i format"
| 23 |
| 24 |
.B "\-o format"
| 25 |
| 26 |
.B "\-in M"
| 27 |
| 28 |
.B "\-on M"
| 29 |
| 30 |
.B "\-f source"
| 31 |
| 32 |
.B "\-e expr"
| 33 |
| 34 |
.B "\-s svar=sval"
| 35 |
| 36 |
file ..
| 37 |
.SH DESCRIPTION
| 38 |
.I Rcalc
| 39 |
transforms ``records'' from each
| 40 |
.I file
| 41 |
according to the given set of literal and relational information.
| 42 |
By default, records are separated by newlines, and contain
| 43 |
numeric fields separated by tabs.
| 44 |
The
| 45 |
.I \-tS
| 46 |
option is used to specify an alternate tab character.
| 47 |
.PP
| 48 |
A
| 49 |
.I \-i format
| 50 |
option specifies a template for an alternate
| 51 |
input record format.
| 52 |
.I Format
| 53 |
is interpreted as a specification string if it contains a dollar sign '$'.
| 54 |
Otherwise, it is interpreted as the name of the file containing
| 55 |
the format specification.
| 56 |
In either case, if the format does not end with a newline, one will be added
| 57 |
automatically.
| 58 |
A special form of the
| 59 |
.I \-i
| 60 |
option may be followed immediately by a 'd' or an 'f' and an optional
| 61 |
count, which defaults to 1, indicating the number of double or float
| 62 |
binary values to read per record on the input file.
| 63 |
If the input is byte-swapped, the
| 64 |
.I \-iD
| 65 |
or
| 66 |
.I \-iF
| 67 |
options may be substituted.
| 68 |
If binary input is specified, no format string or file is needed.
| 69 |
.PP
| 70 |
A
| 71 |
.I \-o format
| 72 |
option specifies an alternate output record format.
| 73 |
It is interpreted the same as an input specification, except that
| 74 |
the special
| 75 |
.I \-od
| 76 |
or
| 77 |
.I \-of
| 78 |
options do not require a count, as this will be determined by the
| 79 |
number of output channels in the given expressions.
| 80 |
If byte-swapped output is desired, the
| 81 |
.I \-oD
| 82 |
or
| 83 |
.I \-oF
| 84 |
| 85 |
.PP
| 86 |
The
| 87 |
.I \-p
| 88 |
option specifies "passive mode," where characters that do not
| 89 |
match the input format are passed unaltered to the output.
| 90 |
If the
| 91 |
.I \-P
| 92 |
option is given instead, then valid input records that do not
| 93 |
yield a positive
| 94 |
.I cond
| 95 |
value are similarly passed to the output.
| 96 |
(See paragraph below.)\0
| 97 |
These options options require that the
| 98 |
.I \-i
| 99 |
input format and
| 100 |
.I \-o
| 101 |
output format also be present.
| 102 |
With both input and output formats, the passive mode can
| 103 |
effectively substitute information in the middle of a file
| 104 |
or stream without affecting the rest of the data.
| 105 |
.PP
| 106 |
If a
| 107 |
.I \-in
| 108 |
option is given with a positive integer argument,
| 109 |
.I rcalc
| 110 |
will stop processing input once it has loaded this number of records.
| 111 |
Similarly, if a
| 112 |
.I \-on
| 113 |
option is present,
| 114 |
.I rcalc
| 115 |
will stop after producing this many records, which may be a smaller
| 116 |
number if the
| 117 |
.I cond
| 118 |
variable is used.
| 119 |
If multiple input files are given, these counts are continuous over
| 120 |
the input and do not reset on each file.
| 121 |
.PP
| 122 |
The variable and function definitions in each
| 123 |
.I \-f source
| 124 |
file are read and compiled from the RADIANCE library where it is found.
| 125 |
The
| 126 |
.I \-e expr
| 127 |
option can be used to define variables on the command line.
| 128 |
Since many of the characters in an expression have special meaning
| 129 |
to the shell, it should usually be enclosed in single quotes.
| 130 |
The
| 131 |
.I \-s svar=sval
| 132 |
option can be used to assign a string variable a string value.
| 133 |
If this string variable appears in an input format, only records
| 134 |
with the specified value will be processed.
| 135 |
.PP
| 136 |
The
| 137 |
.I \-b
| 138 |
option instructs the program to accept only exact matches.
| 139 |
By default, tabs and spaces are ignored except
| 140 |
as field separators.
| 141 |
The
| 142 |
.I \-l
| 143 |
option instructs the program to ignore newlines in the input,
| 144 |
basically treating them the same as tabs and spaces.
| 145 |
Normally, the beginning of the input format matches the beginning of
| 146 |
a line, and the end of the format matches the end of a line.
| 147 |
With the
| 148 |
.I \-l
| 149 |
option, the input format can match anywhere on a line.
| 150 |
.PP
| 151 |
The
| 152 |
.I \-w
| 153 |
option causes non-fatal error messages (such as division by zero) to
| 154 |
be supressed.
| 155 |
The
| 156 |
.I \-u
| 157 |
option causes output to be flushed after each record.
| 158 |
The
| 159 |
.I \-n
| 160 |
option tells the program not to get any input, but to produce a
| 161 |
single output record.
| 162 |
Otherwise, if no files are given, the standard input is read.
| 163 |
.PP
| 164 |
Format files associate names with string and numeric fields
| 165 |
separated by literal information in a record.
| 166 |
A numeric field is given in a format file as a dollar sign, followed
| 167 |
by curly braces enclosing a variable name:
| 168 |
.PP
| 169 |
This is a numeric field: ${vname}
| 170 |
.PP
| 171 |
A string variable is enclosed in parentheses:
| 172 |
.PP
| 173 |
This is a string field: $(sname)
| 174 |
.PP
| 175 |
The program attempts to match literal information in
| 176 |
the input format to its input and assign string and numeric
| 177 |
fields accordingly.
| 178 |
If a string or numeric field variable appears more than once in
| 179 |
the input format, input values for the corresponding fields must
| 180 |
match (ie. have the same value) for the whole record to match.
| 181 |
Numeric values are allowed some deviation, on the order of 0.1%, but
| 182 |
string variables must match exactly.
| 183 |
Thus, dummy variables for "don't care" fields should be given unique
| 184 |
names so that they are not all required to take on the same value.
| 185 |
.PP
| 186 |
For each valid input record, an output record is produced
| 187 |
in its corresponding format.
| 188 |
Output field widths are given implicitly by the space occupied
| 189 |
in the format file, including the dollar sign and braces.
| 190 |
This makes it impossible to produce fields with fewer than four
| 191 |
characters.
| 192 |
If the
| 193 |
.I \-b
| 194 |
option is specified, input records must exactly match the
| 195 |
template.
| 196 |
By default, the character following each input field is used as
| 197 |
a delimiter.
| 198 |
This implies that string fields that are followed by white space
| 199 |
cannot contain strings with white space.
| 200 |
Also, numeric fields followed but not preceded by white space
| 201 |
will not accept numbers preceded by white space.
| 202 |
Adjacent input fields are advisable only with the
| 203 |
.I \-b
| 204 |
option.
| 205 |
Numeric output fields may contain expressions as well as variables.
| 206 |
A dollar sign may appear in a literal as two dollar signs ($$).
| 207 |
.PP
| 208 |
The definitions specified in
| 209 |
.I \-e
| 210 |
and
| 211 |
.I \-f
| 212 |
options relate numeric output fields to numeric input fields.
| 213 |
For the default record format, a field is a variable of the form
| 214 |
$N, where N is the column number, beginning with 1.
| 215 |
Output columns appear on the left-hand side of assignments, input
| 216 |
columns appear on the right-hand side.
| 217 |
.PP
| 218 |
A variable definition has the form:
| 219 |
.PP
| 220 |
| 221 |
var = expression ;
| 222 |
| 223 |
.PP
| 224 |
Any instance of the variable in an expression will be replaced
| 225 |
with its definition.
| 226 |
.PP
| 227 |
An expression contains real numbers, variable names, function calls,
| 228 |
and the following operators:
| 229 |
.PP
| 230 |
| 231 |
.PP
| 232 |
Operators are evaluated left to right, except '^',
| 233 |
which is right associative.
| 234 |
Powers have the highest precedence; multiplication and
| 235 |
division are evaluated before addition and subtraction.
| 236 |
Expressions can be grouped with parentheses.
| 237 |
All values are double precision real.
| 238 |
.PP
| 239 |
A function definition has the form:
| 240 |
.PP
| 241 |
| 242 |
func(a1, a2, ..) = expression ;
| 243 |
| 244 |
.PP
| 245 |
The expression can contain instances of the function arguments
| 246 |
as well as other variables and functions.
| 247 |
Function names can be passed as arguments.
| 248 |
Recursive functions can be defined using calls to the defined
| 249 |
function or other functions calling the defined function.
| 250 |
.PP
| 251 |
The variable
| 252 |
.I cond,
| 253 |
if defined, will determine whether the current input record produces
| 254 |
an output record.
| 255 |
If
| 256 |
.I cond
| 257 |
is positive, output is produced.
| 258 |
If
| 259 |
.I cond
| 260 |
is less than or equal to zero, the record is skipped (or passed to the
| 261 |
output if
| 262 |
.I \-P
| 263 |
is specified) and no other expressions
| 264 |
are evaluated.
| 265 |
This provides a convenient method for avoiding inappropriate calculations.
| 266 |
The following library of pre-defined functions and variables is provided:
| 267 |
.TP 10n
| 268 |
.BR $N
| 269 |
Return the value for input column
| 270 |
.I N.
| 271 |
If an input format is given, using a channel number generates an error.
| 272 |
.TP
| 273 |
.BR "in(n)"
| 274 |
| 275 |
.I n,
| 276 |
or the number of columns available in this record if
| 277 |
.I n
| 278 |
is 0.
| 279 |
This is an alternate way to get a column value instead of using
| 280 |
the $N notation, and is more flexible since it is programmable.
| 281 |
This function is disabled if an input format is used.
| 282 |
.TP
| 283 |
.BR "if(test, then, else)"
| 284 |
if test is greater than zero,
| 285 |
then is evaluated, otherwise else is evaluated.
| 286 |
This function is necessary for recursive definitions.
| 287 |
.TP
| 288 |
.BR "select(N, a1, a2, ..)"
| 289 |
return aN (N is rounded to the nearest integer).
| 290 |
This function provides array capabilities.
| 291 |
If
| 292 |
.I N
| 293 |
is zero, the number of available arguments is returned.
| 294 |
.TP
| 295 |
.BR "rand(x)"
| 296 |
compute a random number between 0 and 1 based on x.
| 297 |
.TP
| 298 |
.BR "min(a1, a2, ..)"
| 299 |
return the minimum value from a list of arguments.
| 300 |
.TP
| 301 |
.BR "max(a1, a2, ..)"
| 302 |
return the maximum value from a list of arguments.
| 303 |
.TP
| 304 |
.BR "floor(x)"
| 305 |
return largest integer not greater than x.
| 306 |
.TP
| 307 |
.BR "ceil(x)"
| 308 |
return smallest integer not less than x.
| 309 |
.TP
| 310 |
.BR "sqrt(x)"
| 311 |
return square root of x.
| 312 |
.TP
| 313 |
.BR "exp(x)"
| 314 |
compute e to the power of x (e approx = 2.718281828).
| 315 |
.TP
| 316 |
.BR "log(x)"
| 317 |
compute the logarithm of x to the base e.
| 318 |
.TP
| 319 |
.BR "log10(x)"
| 320 |
compute the logarithm of x to the base 10.
| 321 |
.TP
| 322 |
.BR PI
| 323 |
the ratio of a circle's circumference to its diameter.
| 324 |
.TP
| 325 |
.BR recno
| 326 |
the number of records recognized thus far.
| 327 |
.TP
| 328 |
.BR outno
| 329 |
the number or records output thus far (including this one).
| 330 |
.TP
| 331 |
.BR "sin(x), cos(x), tan(x)"
| 332 |
trigonometric functions.
| 333 |
.TP
| 334 |
.BR "asin(x), acos(x), atan(x)"
| 335 |
inverse trigonometric functions.
| 336 |
.TP
| 337 |
.BR "atan2(y, x)"
| 338 |
inverse tangent of y/x (range \-pi to pi).
| 339 |
.SH EXAMPLE
| 340 |
To print the square root of column two in column one,
| 341 |
and column one times column three in column two:
| 342 |
.IP "" .2i
| 343 |
rcalc -e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile
| 344 |
.SH ENVIRONMENT
| 345 |
RAYPATH the directories to check for auxiliary files.
| 346 |
.SH AUTHOR
| 347 |
Greg Ward
| 348 |
.SH BUGS
| 349 |
String variables can only be used in input and output formats and
| 350 |
.I \-s
| 351 |
options, not in definitions.
| 352 |
.PP
| 353 |
Tabs count as single spaces inside fields.
| 354 |
.PP
| 355 |
The
| 356 |
.I \-P
| 357 |
option buffers up to 16 Kbytes of data per record.
| 358 |
Longer records passed because the "cond" variable
| 359 |
evaluates to <= 0 will be partial; a warning will
| 360 |
be generated and the string "*** MISSING DATA ***"
| 361 |
will appear at the break.
| 362 |
The only workaround is to use the
| 363 |
.I \-p
| 364 |
option instead, which does not pass rejected records.
| 365 |
.SH "SEE ALSO"
| 366 |
cnt(1), ev(1), getinfo(1), icalc(1), rcollate(1), rlam(1),
| 367 |
rsplit(1), tabfunc(1), total(1)
