root/radiance/doc/man/man1/rad2mgf.1
Revision: 1.4
Committed: Sun Nov 30 17:53:07 2008 UTC (16 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad4R2P1, rad4R2P2, HEAD
Changes since 1.3: +6 -5 lines
Added mention of "mesh" primitive
1 .\" RCSid "$Id: rad2mgf.1,v 1.3 2007/09/04 17:36:41 greg Exp $"
2 .TH RAD2MGF 1 5/15/95 RADIANCE
3 .SH NAME
4 rad2mgf - convert RADIANCE scene description to Materials and Geometry Format
5 .SH SYNOPSIS
6 .B rad2mgf
7 [
8 .B \-dU
9 ]
10 [
11 .B input ..
12 ]
13 .SH DESCRIPTION
14 .I Rad2mgf
15 converts one or more RADIANCE scene files
16 to the Materials and Geometry Format (MGF).
17 Input units are specified with the
18 .I \-mU
19 option, where
20 .I U
21 is one of 'm' (meters), 'c' (centimeters), 'f' (feet) or 'i'
22 (inches).
23 The assumed unit is meters, which is the required output unit for
24 MGF (thus the need to know).
25 If the input dimensions are in none of these units, then the user
26 should apply
27 .I xform(1)
28 with the
29 .I \-s
30 option to bring the units into line prior to translation.
31 .PP
32 The MGF material names and properties
33 for the surfaces will be those assigned in RADIANCE.
34 If a referenced material has not been defined, then its name will
35 be invoked in the MGF output without definition, and the description
36 will be incomplete.
37 .SH LIMITATIONS
38 Although MGF supports all of the geometric types and the most
39 common material types used in RADIANCE, there is currently no
40 support for advanced BRDF materials, patterns, textures or mixtures.
41 Also, the special types "source" and "antimatter" are not supported,
42 and all light source materials are converted to simple diffuse emitters
43 (except "illum" materials, which are converted to their alternates).
44 These primitives are reproduced as comments in the output and
45 must be replaced manually if necessary.
46 .PP
47 The RADIANCE "instance" and "mesh" types aretreated specially.
48 .I Rad2mgf
49 converts each instance or mesh to an MGF include statement,
50 using the corresponding
51 transformation and a file name derived from the octree or mesh name.
52 (The original octree/mesh suffix is replaced by ".mgf".)\0
53 For this to work, the user must separately create the referenced
54 MGF files from the original RADIANCE descriptions.
55 The description file names can usually be determined using the
56 .I getinfo(1)
57 command run on the octrees in question.
58 .SH EXAMPLE
59 To convert three RADIANCE files (in feet) to one MGF file:
60 .IP "" .2i
61 rad2mgf \-df file1.rad file2.rad file3.rad > scene.mgf
62 .PP
63 To translate a RADIANCE materials file to MGF:
64 .IP "" .2i
65 rad2mgf materials.rad > materials.mgf
66 .SH AUTHOR
67 Greg Ward
68 .SH "SEE ALSO"
69 getinfo(1), ies2rad(1), mgf2meta(1), mgf2rad(1), obj2rad(1), oconv(1), xform(1)
70 .PP
71 MGF web site "http://radsite.lbl.gov/mgf/HOME.html"
