| 1 |
.\" RCSid "$Id: ra_pict.1,v 1.3 2007/09/04 17:36:40 greg Exp $" |
| 2 |
.TH RA_PICT 1 11/15/93 RADIANCE |
| 3 |
.SH NAME |
| 4 |
ra_pict - convert Radiance pictures to Macintosh PICT files |
| 5 |
.SH SYNOPSIS |
| 6 |
.B ra_pict |
| 7 |
| 8 |
.B \-e +/- |
| 9 |
.I stops |
| 10 |
| 11 |
.B \-v |
| 12 |
| 13 |
.B \-g |
| 14 |
.I gamma |
| 15 |
| 16 |
.I infile |
| 17 |
| 18 |
.I outfile |
| 19 |
| 20 |
.SH DESCRIPTION |
| 21 |
.B Ra_pict |
| 22 |
converts a Radiance picture, as produced by |
| 23 |
.B rpict |
| 24 |
(1) to a Macintosh PICT file. The picture will be a 24 bit PICT 2 picture, |
| 25 |
using a single bit map (DirectRect). |
| 26 |
.SH OPTIONS |
| 27 |
.TP 10n |
| 28 |
.BI \-g " gamma" |
| 29 |
This sets an explict gamma correction for the image. If it is not |
| 30 |
specified, the default value of 2.0 is used. |
| 31 |
.TP |
| 32 |
.B \-v |
| 33 |
Invokes verbose mode, and gives line on standard error giving the |
| 34 |
size of the picture and the gamma correction used. |
| 35 |
.TP |
| 36 |
.BI "\-e +/\-" " stops" |
| 37 |
Adjusts the exposure by stops. |
| 38 |
.TP |
| 39 |
.I infile |
| 40 |
Specifies the file to read the picture from. If none is specified, |
| 41 |
it takes it from standard input. If standard input is used, then |
| 42 |
the picture is sent to standard output. |
| 43 |
.TP |
| 44 |
.I outfile |
| 45 |
Specifies the file to send the PICT file to. If none is specified, |
| 46 |
it is sent to standard output. |
| 47 |
.SH EXAMPLES |
| 48 |
.PP |
| 49 |
ra_pict mypict.hdr mypict.pict |
| 50 |
.PP |
| 51 |
Will convert the Radiance picture mypict.hdr, giving the Macintosh |
| 52 |
PICT mypict.pict. |
| 53 |
.PP |
| 54 |
ra_pict \-g 2.2 mypict.hdr mypict.pict |
| 55 |
.PP |
| 56 |
Will convert the file using a gamma of 2.2. |
| 57 |
.SH "SEE ALSO" |
| 58 |
rpict(1) |
| 59 |
.SH BUGS |
| 60 |
Does not yet do Macintosh PICT to Radiance PIC, as this PICT files |
| 61 |
are a lot more complex than just one bit map. This is left as an |
| 62 |
exercise for the reader :-) |
| 63 |
.SH AUTHOR |
| 64 |
Russell Street |
