| 1 | greg | 1.4 | .\" RCSid $Id: pkgBSDF.1,v 1.3 2011/08/25 15:16:22 greg Exp $ |
| 2 | greg | 1.1 | .TH PKGBSDF 1 6/23/2011 RADIANCE |
| 3 |  |  | .SH NAME |
| 4 |  |  | pkgBSDF - package BSDFs provided as XML for Radiance |
| 5 |  |  | .SH SYNOPSIS |
| 6 |  |  | .B pkgBSDF |
| 7 |  |  | [ |
| 8 |  |  | .B \-i |
| 9 |  |  | ][ |
| 10 |  |  | .B \-s |
| 11 |  |  | ] |
| 12 |  |  | .B "bsdf.xml .." |
| 13 |  |  | .SH DESCRIPTION |
| 14 |  |  | .I PkgBSDF |
| 15 |  |  | takes one or more XML files, each describing the bidirectional scattering |
| 16 |  |  | distribution function of a surface or geometric system, and packages |
| 17 |  |  | them into RADIANCE scene descriptions. |
| 18 | greg | 1.3 | If the input file(s) do not begin with a '.' or '/', the directories |
| 19 |  |  | in the RAYPATH environment variable will be searched. |
| 20 | greg | 1.1 | One rectangle is produced for each BSDF that has |
| 21 |  |  | no detail geometry and/or no rear-side reflectance distribution. |
| 22 |  |  | If both front and back reflectance distributions are present with |
| 23 |  |  | detail geometry, then two rectangles will be used to sandwich |
| 24 |  |  | the geometry extracted from the BSDF file. |
| 25 | greg | 1.2 | The front surface will always be centered just in front of the |
| 26 |  |  | origin facing the positive Z-direction, with "up" in the positive |
| 27 |  |  | Y-direction. |
| 28 |  |  | The back surface, if present, will parallel the front surface at |
| 29 |  |  | a distance slightly greater than the BSDF system thickness. |
| 30 |  |  | Scene units will always be in meters. |
| 31 | greg | 1.1 | .PP |
| 32 |  |  | The |
| 33 |  |  | .I \-i |
| 34 |  |  | option causes |
| 35 |  |  | .I pkgBSDF |
| 36 |  |  | to produce frozen octree instances for any detail geometry, |
| 37 |  |  | which may reduce memory requirements in scenes with many |
| 38 |  |  | references to the same complex BSDF object. |
| 39 |  |  | .PP |
| 40 |  |  | Normally, |
| 41 |  |  | .I pkgBSDF |
| 42 |  |  | produces one RADIANCE scene file for each XML input, replacing |
| 43 | greg | 1.4 | the required '.xml' suffix with '.rad' and writing to the current directory. |
| 44 | greg | 1.1 | The |
| 45 |  |  | .I \-s |
| 46 |  |  | option sends the RADIANCE scene description to the standard |
| 47 |  |  | output rather than writing it to a file, but only works |
| 48 |  |  | for a single XML input. |
| 49 |  |  | Any instance octree is still written out to a file generated |
| 50 |  |  | by replacing the '.xml' suffix with '.oct' in the same directory. |
| 51 |  |  | .SH EXAMPLE |
| 52 |  |  | Package all the XML files in the current directory as Radiance |
| 53 |  |  | scene files, employing frozen octree instances for any |
| 54 |  |  | detail geometry: |
| 55 |  |  | .IP "" .2i |
| 56 |  |  | pkgBSDF -i *.xml |
| 57 |  |  | .SH AUTHOR |
| 58 |  |  | Greg Ward |
| 59 |  |  | .SH "SEE ALSO" |
| 60 |  |  | genBSDF(1), oconv(1), xform(1) |
