| 1 |
greg |
1.3 |
.\" RCSid "$Id: pexpand.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
| 2 |
greg |
1.1 |
.TH PEXPAND 1 6/24/98 RADIANCE
| 3 |
.SH NAME
| 4 |
pexpand - expand requested commands in metafile
| 5 |
.SH SYNOPSIS
| 6 |
.B pexpand
| 7 |
| 8 |
.B +/\-EPDOCSURIlrtmvsp
| 9 |
| 10 |
file ..
| 11 |
.SH DESCRIPTION
| 12 |
.I Pexpand
| 13 |
reads each metafile
| 14 |
.I file
| 15 |
in sequence and expands any commands specified in a '+' option,
| 16 |
and deletes any commands specified in a '-' option.
| 17 |
This is necessary because most drivers will not support many
| 18 |
metafile commands such as 'v' (vector string) and 'O', 'C', and 's'
| 19 |
(segments).
| 20 |
.I Pexpand
| 21 |
will expand '+' instances into the corresponding primitives which
| 22 |
are supported, and delete all '-' instances.
| 23 |
.PP
| 24 |
Certain commands are currently considered basic, and must be supported
| 25 |
by all drivers.
| 26 |
The commands 'D', 'E', 'S', 'U', 'R', 'l', 'r', and 't' are
| 27 |
basic (see metafile(5)).
| 28 |
.PP
| 29 |
If no input files are specified, the standard input is read.
| 30 |
.TP 10n
| 31 |
.BR +EPDOCSURIlrtmvsp
| 32 |
Expand the requested command(s).
| 33 |
.TP
| 34 |
.BR \-EPDOCSURIlrtmvsp
| 35 |
Delete the requested command(s).
| 36 |
.SH EXAMPLE
| 37 |
To expand vector strings and segements, and delete pauses from "meta":
| 38 |
.IP "" .2i
| 39 |
greg |
1.3 |
pexpand +vOCs \-P meta
| 40 |
greg |
1.1 |
.SH FILES
| 41 |
/usr/lib/meta/vchars.mta (see metafile(5))
| 42 |
.SH AUTHOR
| 43 |
Greg Ward
| 44 |
.SH "SEE ALSO"
| 45 |
metafile(5), psort(1)
