| 1 |
.\" RCSid "$Id: pexpand.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
| 2 |
.TH PEXPAND 1 6/24/98 RADIANCE |
| 3 |
.SH NAME |
| 4 |
pexpand - expand requested commands in metafile |
| 5 |
.SH SYNOPSIS |
| 6 |
.B pexpand |
| 7 |
| 8 |
.B +/\-EPDOCSURIlrtmvsp |
| 9 |
| 10 |
file .. |
| 11 |
.SH DESCRIPTION |
| 12 |
.I Pexpand |
| 13 |
reads each metafile |
| 14 |
.I file |
| 15 |
in sequence and expands any commands specified in a '+' option, |
| 16 |
and deletes any commands specified in a '-' option. |
| 17 |
This is necessary because most drivers will not support many |
| 18 |
metafile commands such as 'v' (vector string) and 'O', 'C', and 's' |
| 19 |
(segments). |
| 20 |
.I Pexpand |
| 21 |
will expand '+' instances into the corresponding primitives which |
| 22 |
are supported, and delete all '-' instances. |
| 23 |
.PP |
| 24 |
Certain commands are currently considered basic, and must be supported |
| 25 |
by all drivers. |
| 26 |
The commands 'D', 'E', 'S', 'U', 'R', 'l', 'r', and 't' are |
| 27 |
basic (see metafile(5)). |
| 28 |
.PP |
| 29 |
If no input files are specified, the standard input is read. |
| 30 |
.TP 10n |
| 31 |
.BR +EPDOCSURIlrtmvsp |
| 32 |
Expand the requested command(s). |
| 33 |
.TP |
| 34 |
.BR \-EPDOCSURIlrtmvsp |
| 35 |
Delete the requested command(s). |
| 36 |
.SH EXAMPLE |
| 37 |
To expand vector strings and segements, and delete pauses from "meta": |
| 38 |
.IP "" .2i |
| 39 |
pexpand +vOCs \-P meta |
| 40 |
.SH FILES |
| 41 |
/usr/lib/meta/vchars.mta (see metafile(5)) |
| 42 |
.SH AUTHOR |
| 43 |
Greg Ward |
| 44 |
.SH "SEE ALSO" |
| 45 |
metafile(5), psort(1) |
