root/radiance/doc/man/man1/pcompos.1
Revision: 1.9
Committed: Fri Mar 18 21:09:16 2022 UTC (3 years, 7 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 1.8: +9 -1 lines
Error occurred while calculating annotation data.
docs(pcomb, pcompos): Added remarks about EXPOSURE settings
1 .\" RCSid "$Id: pcompos.1,v 1.8 2022/03/15 00:25:50 greg Exp $"
2 .TH PCOMPOS 1 12/18/97 RADIANCE
3 .SH NAME
4 pcompos - composite RADIANCE pictures.
5 .SH SYNOPSIS
6 .B pcompos
7 [
8 .B \-h
9 ][
10 .B "\-x xres"
11 ][
12 .B "\-y yres"
13 ][
14 .B "\-b r g b"
15 ][
16 .B "\-lh h"
17 ][
18 .B \-la
19 ]
20 [
21 .B "\-t min1"
22 ][
23 .B "\+t max1"
24 ][
25 .B "\-l lab"
26 ][
27 .B "=SS"
28 ]
29 .B "pic1 x1 y1 .."
30 .br
31 or
32 .br
33 .B pcompos
34 [
35 .B "\-a ncols"
36 ][
37 .B "\-s spacing"
38 ][
39 .B "\-o x0 y0"
40 ][
41 options
42 ]
43 .B "pic1 pic2 .."
44 .SH DESCRIPTION
45 .I Pcompos
46 arranges and composites RADIANCE pictures and sends the result to the
47 standard output.
48 Each input picture must be accompanied by an anchor point (unless the
49 .I \-a
50 option is used, see below).
51 This anchor point is the usually position of the picture's
52 left lower corner in the final output, but can be changed
53 for individual pictures with an
54 .I =SS
55 option, where
56 .I S
57 is one of '-', '+' or '0', indicating the minimum, maximum or center
58 of the image, respectively.
59 (For example,
60 .I =+-
61 would indicate the anchor is relative to the right lower corner, and
62 .I =-0
63 would indicate the anchor is relative to the center of the left
64 edge.)\0
65 Negative anchor coordinates result in the input being cropped at the origin.
66 By default, the size of the output picture will be just large enough
67 to encompass all the input files.
68 By specifying a smaller dimension using the
69 .I \-x
70 and
71 .I \-y
72 options, input files can be cropped at the upper boundary.
73 Specifying a larger dimension produces a border.
74 The
75 .I \-b
76 option specifies a background color to appear wherever input
77 files do not cover.
78 The default value is black (0 0 0).
79 The
80 .I \-h
81 option may be used to reduce the information header size, which
82 can grow disproportionately after multiple runs of
83 .I pcompos
84 and/or
85 .I pcomb(1).
86 .PP
87 If input files overlap, later pictures will overwrite earlier ones.
88 By default, input files are copied unconditionally within the output
89 boundaries.
90 The
91 .I \-t
92 option specifies a lower threshold intensity under which input pixels
93 will not be copied to the output.
94 The
95 .I \+t
96 option specifies an upper threshold.
97 These options are useful for cutting around irregular boundaries in
98 the input.
99 .PP
100 The
101 .I \-l
102 option can be used to specify a label for a specific picture, which
103 will be given a height determined by the
104 .I \-lh
105 option (default 24 pixels) and placed in the upper left corner of
106 the picture.
107 This label is generated by the program
108 .I psign(1).
109 The
110 .I \-la
111 option instructs
112 .I pcompos
113 to label each picture automatically by its name.
114 This is particularly useful in conjunction with the
115 .I \-a
116 option for producing a catalog of images (see example below).
117 The
118 .I \-l
119 option may still be used to override the default label
120 for a picture.
121 .PP
122 The
123 .I \-a
124 option can be used to automatically compute anchor points
125 that place successive pictures next to each other in
126 .I ncols
127 columns.
128 The ordering will place the first picture in the lower left corner,
129 the next just to the right of it, and so on for
130 .I ncols
131 pictures.
132 Then, the next row up repeats the pattern until all the input
133 pictures have been added to the output.
134 If the pictures are of different size,
135 .I pcompos
136 will end up leaving some background areas in the output picture.
137 There will also be an unfinished row at the top if the number
138 of pictures is not evenly divided by
139 .I ncols.
140 The
141 .I "\-s N"
142 option will cause each image to be separated by at least N pixels.
143 The
144 .I "\-o x0 y0"
145 option specifies a nonzero anchor point for the bottom left image.
146 If a negative value is given for ncols, then the rows are reversed,
147 so they start from the top rather than the bottom.
148 This gives a more natural ordering in most cases, but has the
149 side-effect of moving any labels from the upper-left of each placed
150 subimage to the lower-left.
151 Also, the
152 .I \-o
153 option is interpreted differently, where the y0 value is number of
154 pixels from the top (rather than the bottom).
155 .PP
156 The standard input can be specified with a hyphen ('-').
157 A command that produces a RADIANCE picture can be given in place of a file
158 by preceeding it with an exclamation point ('!').
159 .SH EXAMPLE
160 To put a copyright label at the bottom of a picture:
161 .IP "" .2i
162 psign Copyright 1987 | pcompos inp.hdr 0 0 +t .5 - 384 64 > out.hdr
163 .PP
164 To make a catalog of images separated by white 10-pixel borders and
165 ordered four images per row starting from the top-left:
166 .IP "" .2i
167 pcompos -la -a -4 -s 10 -b 1 1 1 dog*.hdr > alldogs.hdr
168 .SH NOTES
169 Since there is a limit to the number of open files and processes,
170 large collections of images must be created in stages.
171 Even if the system limit on open files is large,
172 .I pcompos
173 places an artificial limit of 1024 on the number of open files and/or
174 processes.
175 .PP
176 The EXPOSURE= line is ignored on the input except when there is only
177 a single input picture, or mutliple pictures all have the same
178 exposure value.
179 In such cases,
180 .I pcompos
181 will echo the exposure line to the output header appropriately,
182 so that absolute calibration is maintained.
183 .SH AUTHOR
184 Greg Ward
185 .SH "SEE ALSO"
186 getinfo(1), pcomb(1), pfilt(1), psign(1), rcrop(1), rpict(1)
