| 1 |
.\" RCSid "$Id: pabopto2bsdf.1,v 1.10 2022/06/14 17:45:53 greg Exp $" |
| 2 |
.TH PABOPTO2BSDF 1 2/24/2021 RADIANCE |
| 3 |
.SH NAME |
| 4 |
pabopto2bsdf - convert BSDF measurements to a scattering interpolant representation |
| 5 |
.SH SYNOPSIS |
| 6 |
.B pabopto2bsdf |
| 7 |
| 8 |
.B \-t |
| 9 |
| 10 |
.B "\-n nproc" |
| 11 |
| 12 |
.B "\-s symmetry" |
| 13 |
| 14 |
.B "\-g angle | 'A'" |
| 15 |
| 16 |
.B "meas1 meas2 .." |
| 17 |
.SH DESCRIPTION |
| 18 |
.I Pabopto2bsdf |
| 19 |
takes two or more pab-opto |
| 20 |
.I Mountain |
| 21 |
files, each nominally containing |
| 22 |
different incident beam angles or sampling patterns, |
| 23 |
and produces a Scattering Interpolant Representation (SIR) |
| 24 |
on the standard output for further processing. |
| 25 |
The binary SIR contains a Radial Basis Function fitting |
| 26 |
each incident BSDF data file |
| 27 |
and a "transport plan" matrix for each pair of neighboring RBF |
| 28 |
directions in a spherical Delaunay mesh. |
| 29 |
.PP |
| 30 |
The SIR provides a complete 4-dimensional |
| 31 |
BSDF description that may be resampled for other |
| 32 |
formats such as Klems and tensor tree. |
| 33 |
However, a separate run of |
| 34 |
.I pabopto2bsdf |
| 35 |
is needed to produce an SIR for each |
| 36 |
incident and scattered hemisphere pair. |
| 37 |
At most, there will be 4 such hemisphere pairs for |
| 38 |
front reflection, back reflection, front transmission, |
| 39 |
and back transmission. |
| 40 |
Theoretically, only one transmission direction is required, |
| 41 |
but it is often safest to measure both if they are to |
| 42 |
be used in a simulation. |
| 43 |
(See |
| 44 |
.I bsdf2klems(1) |
| 45 |
and |
| 46 |
.I bsdf2ttree(1) |
| 47 |
for details. |
| 48 |
The |
| 49 |
.I bsdf2rad(1) |
| 50 |
and |
| 51 |
.I bsdfview(1) |
| 52 |
tools are also useful for visualizaing SIR and XML files.) |
| 53 |
.PP |
| 54 |
The |
| 55 |
.I pabopto2bsdf |
| 56 |
.I \-t |
| 57 |
option reverses the assumed sample orientation front-to-back, |
| 58 |
and is discussed below under the "#intheta" header entry. |
| 59 |
.PP |
| 60 |
Multi-processing may be used to accelerate the program |
| 61 |
on systems that support it via the |
| 62 |
.I \-n |
| 63 |
option. |
| 64 |
.PP |
| 65 |
BSDF symmetry may be specified with the |
| 66 |
.I \-s |
| 67 |
option, which is one of "isotropic", "quadrilateral", |
| 68 |
"bilateral", "up", or "anisotropic". |
| 69 |
Any of these may be abbreviated with as little as a single |
| 70 |
letter, and case is ignored. |
| 71 |
.PP |
| 72 |
Normally, |
| 73 |
.I pabopto2bsdf |
| 74 |
will assume a BSDF symmetry from the incident phi angles provided. |
| 75 |
If every input data file uses the same incident phi angle, the |
| 76 |
BSDF is assumed to be "isotropic", or rotationally symmetric. |
| 77 |
If input phi angles only cover one quarter of the incident hemisphere, |
| 78 |
then the sample is assumed to have quadrilateral symmetry. |
| 79 |
Similarly, half-hemisphere coverage implies "bilateral" symmetry, |
| 80 |
although it is also compatible with "up" symmetry, which must be specified |
| 81 |
on the command line. |
| 82 |
The difference is crucial. |
| 83 |
Similar to quadrilateral symmetry, bilateral symmetry is "mirrored," |
| 84 |
meaning that the sample material looks identical when viewed in a mirror. |
| 85 |
However, "up" symmetry means that the sample looks the same when |
| 86 |
rotated by 180-degree (upside-down), but does not look the same in a mirror. |
| 87 |
The "up" symmetry was a late addition, and involves rotating and copying the |
| 88 |
input data, treating the result as anisotropic. |
| 89 |
It is therefore less efficient, and should only be used when necessary. |
| 90 |
Finally, if the incident hemisphere is fully covered, the final BSDF |
| 91 |
is anisotropic. |
| 92 |
.PP |
| 93 |
If a |
| 94 |
.I \-s |
| 95 |
symmetry option is specified and it does not agree with the input |
| 96 |
data provided, an error message is issued and no output is produced. |
| 97 |
Note that only the "up" and "bilateral" symmetry options have |
| 98 |
identical input coverage, so this is the only time the |
| 99 |
.I \-s |
| 100 |
option must be specified if the default mirroring is not appropriate. |
| 101 |
.PP |
| 102 |
If a |
| 103 |
.I \-g |
| 104 |
option is present, it will cull scattered measurements that are nearer |
| 105 |
to grazing than the given angle in degrees. |
| 106 |
If the word "auto" (which can be abbreviated as 'a' or 'A') is given |
| 107 |
instead of an angle, then the near-grazing angle will be determined |
| 108 |
by the lowest incident angle measurement present in the input data. |
| 109 |
This is sometimes necessary to eliminate noise and edge effects that |
| 110 |
some measurements exhibit near grazing. |
| 111 |
.PP |
| 112 |
The |
| 113 |
.I Mountain |
| 114 |
program, written by Peter Apian-Bennewitz, stores data taken by |
| 115 |
his pg2 goniophotometer in separate |
| 116 |
BSDF scattering files for each incident angle, beginning with a header |
| 117 |
whose lines each start with a pound sign ('#'). |
| 118 |
Some header settings require colons and others do not, as indicated below. |
| 119 |
The |
| 120 |
.i pabopto2bsdf |
| 121 |
program understands the following lines from each header and ignores |
| 122 |
the rest: |
| 123 |
.TP |
| 124 |
.BR #sample_name |
| 125 |
A double-quoted string containing the name associated with this sample. |
| 126 |
If input files contain different sample names, the final sample name read |
| 127 |
will be the one passed to the SIR output. |
| 128 |
.TP |
| 129 |
.BR #format: |
| 130 |
The data format, typically one of "theta phi DSF" or "theta phi BSDF". |
| 131 |
These differ only in their inclusion of a cosine factor. |
| 132 |
The word "BRDF" or "BTDF" is accepted in place of "BSDF". |
| 133 |
Any other specification or a format missing generates an error. |
| 134 |
.TP |
| 135 |
.BR #intheta |
| 136 |
The incident theta (polar) angle in degrees, measured from the sample's |
| 137 |
surface normal. |
| 138 |
Theta values should be between 0 and 180, where values less than 90 |
| 139 |
are considered incident to the "front" side of the sample, and |
| 140 |
theta values greater than 90 are incident to the "back" side in |
| 141 |
the standard coordinate system. |
| 142 |
Notions of "front" and "back" may be reversed using the |
| 143 |
.I -t |
| 144 |
option if desired. |
| 145 |
.TP |
| 146 |
.BR #inphi |
| 147 |
The incident phi (azimuthal) angle in degrees counter-clockwise as |
| 148 |
seen from the "front" side of the sample. |
| 149 |
.TP |
| 150 |
.BR #incident_angle |
| 151 |
The incident theta and phi angles are each given in this header |
| 152 |
line, offered as an alternative to separate "#intheta" and "#inphi" |
| 153 |
angles. |
| 154 |
The interpretation is the same as above. |
| 155 |
.TP |
| 156 |
.BR #upphi |
| 157 |
If present, this phi angle that corresponds to |
| 158 |
the sample "up" orientation. |
| 159 |
By default, it is assumed to be 0, meaning that "up" |
| 160 |
is phi=0. |
| 161 |
To get the standard RADIANCE coordinates for BSDFs, "#upphi" should |
| 162 |
be set to 90 (degrees). |
| 163 |
.TP |
| 164 |
.BR #colorimetry: |
| 165 |
Two colorimetry values are currently understood: "CIE-Y" and "CIE-XYZ". |
| 166 |
The default "CIE-Y" colorimetry |
| 167 |
takes each DSF or BSDF value as photometric. |
| 168 |
If "CIE-XYZ" is specified, then the DSF or BSDF values must be triplets |
| 169 |
corresponding to CIE XYZ values. |
| 170 |
Such files are typically produced by the |
| 171 |
.I pabopto2xyz(1) |
| 172 |
tool rather than |
| 173 |
.I Mountain, |
| 174 |
directly. |
| 175 |
.PP |
| 176 |
The BSDF scattering data follows the header in unspecified order, |
| 177 |
where each line in the file |
| 178 |
contains the scattered theta and phi angles measured in the same |
| 179 |
coordinate system as incident theta and phi, followed by the DSF |
| 180 |
or BSDF value, which may either be a single photometric quantity |
| 181 |
for "CIE-Y" colorimetry or a triplet if the colorimetry is "CIE-XYZ". |
| 182 |
A minimal incident BSDF data file might contain: |
| 183 |
.sp |
| 184 |
.nf |
| 185 |
#incident_angle 82.5 180 |
| 186 |
#format: theta phi DSF |
| 187 |
84.968 125.790 0.009744 |
| 188 |
84.889 125.610 0.007737 |
| 189 |
84.805 125.427 0.008569 |
| 190 |
| 191 |
.fi |
| 192 |
.sp |
| 193 |
The above header is equivalent to the more complete version below: |
| 194 |
.sp |
| 195 |
.nf |
| 196 |
| 197 |
| 198 |
#intheta 82.5 |
| 199 |
#inphi 180 |
| 200 |
#upphi 0 |
| 201 |
#colorimetry: CIE-Y |
| 202 |
| 203 |
| 204 |
| 205 |
| 206 |
.fi |
| 207 |
.sp |
| 208 |
The ordering of the header and data lines is unimportant, |
| 209 |
but all header lines must precede all data lines in each input file. |
| 210 |
.SH EXAMPLE |
| 211 |
To generate an SIR file from a collection of transmission measurements |
| 212 |
of a material with 180-degree symmetry using 4 processes: |
| 213 |
.IP "" .2i |
| 214 |
pabopto2bsdf -n 4 -s up f*_Tvis.txt > front_trans.sir |
| 215 |
.PP |
| 216 |
To combine this with front reflection measurements into a Klems BSDF file: |
| 217 |
.IP "" .2i |
| 218 |
pabopto2bsdf -n 4 -s up f*_Rvis.txt > front_refl.sir |
| 219 |
.br |
| 220 |
bsdf2klems front_trans.sir front_refl.sir > Klems_bsdf.xml |
| 221 |
.SH NOTES |
| 222 |
If the BSDF is being mirrored and there is no measured theta=0 incident |
| 223 |
angle data file, this part of the distribution is filled in |
| 224 |
by a special procedure. |
| 225 |
This is important because there is no way to extrapolate missing |
| 226 |
data at normal incidence. |
| 227 |
.PP |
| 228 |
The BSDF is extrapolated past the last measured theta angles towards |
| 229 |
grazing using a constant value plus a single Gaussian lobe if one can |
| 230 |
be reasonably fit to the near-grazing data. |
| 231 |
This lobe will always be in the mirror direction in the case of |
| 232 |
reflection, or the "through" direction in the case |
| 233 |
of transmission. |
| 234 |
The magnitude and width of this lobe is stored in the output header, |
| 235 |
along with the constant value. |
| 236 |
Both the lobe and the constant are neutral values, even with CIE-XYZ |
| 237 |
colorimetry. |
| 238 |
.PP |
| 239 |
While there is no explicit handling of infrared or solar radiometry, |
| 240 |
any single-channel BSDF will be created the same, and the final XML |
| 241 |
file generated by |
| 242 |
.I bsdf2klems |
| 243 |
or |
| 244 |
.I bsdf2ttree |
| 245 |
can be edited to specify a different radiometry. |
| 246 |
The interpolation process in |
| 247 |
.I pabopto2bsdf |
| 248 |
is not affected by this. |
| 249 |
.PP |
| 250 |
The standard BSDF coordinates in RADIANCE have the theta=0 direction |
| 251 |
corresponding to the front-side surface normal. |
| 252 |
The phi=0 direction points to the right as seen from the front, and |
| 253 |
phi=90 degrees corresponds to the "up" orientation for the sample. |
| 254 |
The same theta and phi are used for incoming and scattered angles, |
| 255 |
so theta=180 is the opposite side surface normal. |
| 256 |
This differs from the WINDOW, which use separate |
| 257 |
coordinate systems for the front and the back. |
| 258 |
To confuse things further, notions of "front" and "back" are |
| 259 |
opposite in WINDOW and RADIANCE. |
| 260 |
In RADIANCE, the normal of a window surface usually faces the |
| 261 |
interior of a space, where the WINDOW convention uses "FRONT" |
| 262 |
for the exterior of a building. |
| 263 |
.PP |
| 264 |
In the |
| 265 |
.I genBSDF(1) |
| 266 |
utility, the world coordinate system follows trigonometric |
| 267 |
conventions with theta=0 aligning to the Z-axis, |
| 268 |
the X-axis matches (theta,phi)=(90,0), and the Y-axis |
| 269 |
corresponds to (theta,phi)=(90,90). |
| 270 |
The latter is thought of as the "up" direction for the sample. |
| 271 |
This usually needs to be rotated into position, since most |
| 272 |
RADIANCE models use the Z-axis as the world "up" direction. |
| 273 |
.SH AUTHOR |
| 274 |
Greg Ward |
| 275 |
.SH "SEE ALSO" |
| 276 |
bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1), |
| 277 |
pabopto2xyz(1) |
