| 1 |
greg |
1.1 |
.TH NORMTIFF 1 2/25/99 RADIANCE
| 2 |
.SH NAME
| 3 |
normtiff - tone-map and convert RADIANCE picture or SGILOG TIFF to RGB TIFF
| 4 |
.SH SYNOPSIS
| 5 |
.B normtiff
| 6 |
| 7 |
.B options
| 8 |
| 9 |
.B input
| 10 |
.B output.tif
| 11 |
.SH DESCRIPTION
| 12 |
.I Normtiff
| 13 |
prepares a Radiance picture or SGILOG (high dynamic range) TIFF
| 14 |
for output to a display or hard copy device.
| 15 |
If the dynamic range of the scene exceeds that of the display (as is
| 16 |
usually the case),
| 17 |
.I normtiff
| 18 |
will compress the dynamic range of the picture such that both
| 19 |
dark and bright regions are visible.
| 20 |
In addition, certain limitations in human vision may be mimicked in
| 21 |
order to provide an appearance similar to the experience one might
| 22 |
have in the actual scene.
| 23 |
.PP
| 24 |
Output is always an uncompressed RGB TIFF, which must be named
| 25 |
on the command line along with the input file.
| 26 |
If the input file has a ".tif" or ".tiff" extension,
| 27 |
.I normtiff
| 28 |
attempts to read it as a TIFF.
| 29 |
Otherwise,
| 30 |
.I normtiff
| 31 |
first tries opening it as a RADIANCE picture, only opening it
| 32 |
as a TIFF if it fails header inspection.
| 33 |
(See the
| 34 |
.I getinfo(1)
| 35 |
program.)\0
| 36 |
If the input is neither a RADIANCE picture nor an SGILOG-encoded TIFF,
| 37 |
the program reports an error and exits.
| 38 |
.PP
| 39 |
The following command line options are understood.
| 40 |
Since this program is very similar to
| 41 |
.I pcond(1),
| 42 |
several of the switches are identical.
| 43 |
.TP 10n
| 44 |
.BR -b
| 45 |
Toggle 8-bit black and white (grayscale) TIFF output.
| 46 |
If the input is a 16-bit SGILOG luminance-only TIFF, this switch is
| 47 |
automatically selected.
| 48 |
Otherwise, the output defaults to 24-bit RGB.
| 49 |
.TP
| 50 |
.BR -h
| 51 |
Mimic human visual response in the output.
| 52 |
The goal of this process is to produce output that correlates
| 53 |
strongly with a person's subjective impression of a scene.
| 54 |
This switch turns on both the
| 55 |
.I \-s
| 56 |
and
| 57 |
.I \-c
| 58 |
switches, described below.
| 59 |
.TP
| 60 |
.BR -s
| 61 |
Toggle the use of the human contrast sensitivity function in determining the
| 62 |
exposure for the image.
| 63 |
A darker scene will have relatively lower exposure with lower
| 64 |
contrast than a well-lit scene.
| 65 |
.TP
| 66 |
.BR -c
| 67 |
Toggle mesopic color correction.
| 68 |
If parts of the image are in the mesopic or scotopic range where
| 69 |
the cone photoreceptors lose their efficiency, this switch will
| 70 |
cause a corresponding loss of color visibility in the output and a
| 71 |
shift to a scotopic (blue-dominant) response function.
| 72 |
.TP
| 73 |
.BR -l
| 74 |
Toggle the use of a linear response function versus the standard dynamic
| 75 |
range compression algorithm.
| 76 |
This may make some parts of the resulting image too
| 77 |
dark or too bright to see.
| 78 |
.TP
| 79 |
.BI -u \ Ldmax
| 80 |
Specifies the top of the luminance range for the target output device.
| 81 |
That is, the luminance (in candelas/m^2) for an output pixel value
| 82 |
of (R,G,B)=(255,255,255).
| 83 |
This parameter affects tone mapping only when the
| 84 |
.I \-s
| 85 |
switch is on.
| 86 |
The default value is 100 cd/m^2.
| 87 |
.TP
| 88 |
.BI -d \ Lddyn
| 89 |
Specifies the dynamic range for the target output device, which is
| 90 |
the ratio of the maximum and minimum usable display luminances.
| 91 |
The default value is 32, which is typical for CRT monitors.
| 92 |
.TP
| 93 |
.BI -p " xr yr xg yg xb yb xw yw"
| 94 |
Specifies the RGB primaries for the target output device.
| 95 |
These are the 1931 CIE (x,y) chromaticity values for red, green,
| 96 |
blue and white, respectively.
| 97 |
.TP
| 98 |
.BI -g \ gamma
| 99 |
Specifies the output device gamma correction value.
| 100 |
The default value is 2.2, which is appropriate for most CRT monitors.
| 101 |
(A value of 1.8 is common in color prepress and color printers.)\0
| 102 |
.SH EXAMPLES
| 103 |
To convert a RADIANCE picture to an 8-bit grayscale TIFF:
| 104 |
.IP "" .2i
| 105 |
normtiff -b scene.pic sceneb.tif
| 106 |
.PP
| 107 |
To condition an SGILOG TIFF for a particular film recorder with
| 108 |
known color primaries, dynamic range and gamma response:
| 109 |
.IP "" .2i
| 110 |
pcond -d 50 -g 2.5 -p .580 .340 .281 .570 .153 .079 .333 .333 orig.tif filmrgb.tif
| 111 |
.PP
| 112 |
To simulate human visual response on a monitor with known maximum luminance:
| 113 |
.IP "" .2i
| 114 |
normtiff -h -u 80 scene.pic sceneh.tif
| 115 |
.SH REFERENCE
| 116 |
Greg Ward Larson, Holly Rushmeier, Christine Piatko,
| 117 |
``A Visibility Matching Tone Reproduction Operator for High Dynamic Range
| 118 |
Scenes,''
| 119 |
.I "IEEE Transactions on Visualization and Computer Graphics",
| 120 |
December 1997.
| 121 |
.PP
| 122 |
http://positron.cs.berkeley.edu/gwlarson/pixformat/
| 123 |
.SH AUTHOR
| 124 |
Greg Ward Larson
| 125 |
.SH ACKNOWLEDGMENT
| 126 |
This work was supported by Silicon Graphics, Inc.
| 127 |
.SH "SEE ALSO"
| 128 |
getinfo(1), pcond(1), pflip(1),
| 129 |
pvalue(1), protate(1), ra_xyze(1), rpict(1), ximage(1)
