| 1 |
.\" RCSid "$Id$"
| 2 |
.TH NORMPAT 1 11/15/93 RADIANCE
| 3 |
.SH NAME
| 4 |
normpat - normalize RADIANCE pictures for use as patterns.
| 5 |
.SH SYNOPSIS
| 6 |
.B normpat
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B \-b
| 11 |
| 12 |
.B \-f
| 13 |
| 14 |
.B "\-r maxres"
| 15 |
| 16 |
.B "picture .."
| 17 |
.SH DESCRIPTION
| 18 |
.I Normpat
| 19 |
normalizes one or more RADIANCE pictures to an average brightness of 1.0
| 20 |
and optionally removes fundamental frequencies and blends the edges
| 21 |
of the image.
| 22 |
The original images are overwritten during this process, and it is
| 23 |
recommended that the program work on copies of the pictures for this reason.
| 24 |
.PP
| 25 |
The
| 26 |
.I \-r
| 27 |
option can be used to set the maximum horizontal or vertical resolution
| 28 |
of the final result, which should not be greater than 256 for most
| 29 |
patterns (due to the associated memory burden during rendering).
| 30 |
The
| 31 |
.I \-f
| 32 |
option uses a Fourier transform to remove the lowest frequencies
| 33 |
from the image, reducing the noticeability of pattern repitition.
| 34 |
The
| 35 |
.I \-b
| 36 |
option can be used to blend the edges of the image so that when
| 37 |
it is tiled, the seams are less apparent.
| 38 |
The
| 39 |
.I \-v
| 40 |
option turns on the verbose flag, which prints on the standard output
| 41 |
progress messages as the script runs.
| 42 |
.PP
| 43 |
.I Normpat
| 44 |
is a shell script that makes calls to other RADIANCE programs
| 45 |
that do the actual work.
| 46 |
.SH AUTHOR
| 47 |
Greg Ward
| 48 |
.SH "SEE ALSO"
| 49 |
getinfo(1), pcomb(1), pcompos(1), pfilt(1), pflip(1), protate(1),
| 50 |
psign(1), ra_bn(1), ra_pr(1), ra_t8(1), ra_t16(1), rpict(1)
