| 1 | greg | 1.3 | .\" RCSid "$Id: meta2tga.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
| 2 | greg | 1.1 | .TH META2TGA 1 6/24/98 RADIANCE |
| 3 |  |  | .SH NAME |
| 4 |  |  | meta2tga - convert metafile to Targa image format |
| 5 |  |  | .SH SYNOPSIS |
| 6 |  |  | .B meta2tga |
| 7 |  |  | [ |
| 8 |  |  | .B \-c | \-r |
| 9 |  |  | ][ |
| 10 |  |  | .B "\-x width" |
| 11 |  |  | ][ |
| 12 |  |  | .B "\-y height" |
| 13 |  |  | ][ |
| 14 |  |  | .B "\-m minrad" |
| 15 |  |  | ][ |
| 16 |  |  | .B "\-o outname" |
| 17 |  |  | ] |
| 18 |  |  | file .. |
| 19 |  |  | .SH DESCRIPTION |
| 20 |  |  | .I Meta2tga |
| 21 |  |  | reads each metafile |
| 22 |  |  | .I file |
| 23 |  |  | in sequence and converts it to a compressed, color-mapped Targa file. |
| 24 |  |  | The result is sent to the standard output (which must be redirected) |
| 25 |  |  | unless the |
| 26 |  |  | .I \-o |
| 27 |  |  | option is used. |
| 28 |  |  | The argument to the |
| 29 |  |  | .I \-o |
| 30 |  |  | option specifies the base file name, to which a page number and ".tga" is added |
| 31 |  |  | as a suffix. |
| 32 |  |  | Note that this option must be present in order to produce more than a single |
| 33 |  |  | page of output. |
| 34 |  |  | .PP |
| 35 |  |  | The default output resolution is 400 by 400, but a different resolution |
| 36 |  |  | can be given with the |
| 37 |  |  | .I \-x |
| 38 |  |  | and |
| 39 |  |  | .I \-y |
| 40 |  |  | options. |
| 41 |  |  | .PP |
| 42 |  |  | The |
| 43 |  |  | .I \-m |
| 44 |  |  | option can be used to set a minimum value for the line radius in pixels. |
| 45 |  |  | This may be helpful for improving the readability of high resolution output. |
| 46 |  |  | The default value is 0, which allows lines of one pixel thickness. |
| 47 |  |  | .PP |
| 48 |  |  | If the option |
| 49 |  |  | .I \-c |
| 50 |  |  | is specified, the input files are only conditioned for output, ie. |
| 51 |  |  | expanded (see pexpand). |
| 52 |  |  | This is useful if many copies of the same output is desired. |
| 53 |  |  | If the option |
| 54 |  |  | .I \-r |
| 55 |  |  | is instead specified, the input is assumed already to be conditioned. |
| 56 |  |  | If no input files are specified, the standard input is read. |
| 57 |  |  | .SH EXAMPLE |
| 58 |  |  | To convert the plots examp1.plt and examp2.plt to 1024x1024 Targa files: |
| 59 |  |  | .IP "" .2i |
| 60 |  |  | bgraph examp1.plt examp2.plt | meta2tga -o examp -x 1024 -y 1024 |
| 61 |  |  | .SH FILES |
| 62 |  |  | see pexpand(1) and psort(1) |
| 63 |  |  | .SH AUTHOR |
| 64 |  |  | Greg Ward |
| 65 |  |  | .SH "SEE ALSO" |
| 66 | greg | 1.3 | bgraph(1), igraph(1), imagew(1), meta2bmp(1), mx80(1), pexpand(1), |
| 67 | greg | 1.1 | psort(1), ra_t8(1), t4014(1) |
