| 1 |
.\" RCSid "$Id: meta2bmp.1,v 1.2 2005/10/27 00:20:08 greg Exp $" |
| 2 |
.TH META2BMP 1 6/24/98 RADIANCE |
| 3 |
.SH NAME |
| 4 |
meta2bmp - convert metafile to Windows Bitmap (BMP) File |
| 5 |
.SH SYNOPSIS |
| 6 |
.B meta2bmp |
| 7 |
| 8 |
.B \-c | \-r |
| 9 |
| 10 |
.B "\-x width" |
| 11 |
| 12 |
.B "\-y height" |
| 13 |
| 14 |
.B "\-m minrad" |
| 15 |
| 16 |
.B "\-o outname" |
| 17 |
| 18 |
file .. |
| 19 |
.SH DESCRIPTION |
| 20 |
.I Meta2bmp |
| 21 |
reads each metafile |
| 22 |
.I file |
| 23 |
in sequence and converts it to a compressed, color-mapped BMP file. |
| 24 |
The result is sent to the standard output (which must be redirected) |
| 25 |
unless the |
| 26 |
.I \-o |
| 27 |
option is used. |
| 28 |
The argument to the |
| 29 |
.I \-o |
| 30 |
option specifies the base file name, to which a page number and ".bmp" is added |
| 31 |
as a suffix. |
| 32 |
Note that this option must be present in order to produce more than a single |
| 33 |
page of output. |
| 34 |
.PP |
| 35 |
The default output resolution is 400 by 400, but a different resolution |
| 36 |
can be given with the |
| 37 |
.I \-x |
| 38 |
and |
| 39 |
.I \-y |
| 40 |
options. |
| 41 |
.PP |
| 42 |
The |
| 43 |
.I \-m |
| 44 |
option can be used to set a minimum value for the line radius in pixels. |
| 45 |
This may be helpful for improving the readability of high resolution output. |
| 46 |
The default value is 0, which allows lines of one pixel thickness. |
| 47 |
.PP |
| 48 |
If the option |
| 49 |
.I \-c |
| 50 |
is specified, the input files are only conditioned for output, ie. |
| 51 |
expanded (see pexpand). |
| 52 |
This is useful if many copies of the same output is desired. |
| 53 |
If the option |
| 54 |
.I \-r |
| 55 |
is instead specified, the input is assumed already to be conditioned. |
| 56 |
If no input files are specified, the standard input is read. |
| 57 |
.SH EXAMPLE |
| 58 |
To convert the plots examp1.plt and examp2.plt to 1024x1024 Targa files: |
| 59 |
.IP "" .2i |
| 60 |
bgraph examp1.plt examp2.plt | meta2bmp \-o examp \-x 1024 \-y 1024 |
| 61 |
.SH FILES |
| 62 |
see pexpand(1) and psort(1) |
| 63 |
.SH AUTHOR |
| 64 |
Greg Ward |
| 65 |
.SH "SEE ALSO" |
| 66 |
bgraph(1), igraph(1), meta2tga(1), pexpand(1), psmeta(1), |
| 67 |
psort(1), ra_t8(1) |
