root/radiance/doc/man/man1/ies2rad.1
Revision: 1.5
Committed: Mon Nov 29 16:07:36 2021 UTC (3 years, 10 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 1.4: +206 -200 lines
feat(ies2rad): changes and enhancements to ies2rad by Randolph Fritz
# User Rev Content
1 greg 1.5 .\" RCSid "$Id$"
2     .TH IES2RAD "1" "2021-10-26" "Radiance" "Radiance Manual Pages"
3     .SH "NAME"
4     ies2rad \- convert IES luminaire data to RADIANCE description
5     .SH "SYNOPSIS"
6     \fBies2rad\fP [ \fIoptions\fP ] [ \fIfile file .\|.\|.\&\fP ]
7     .SH "DESCRIPTION"
8     \fIIes2rad\fP converts one or more IES luminaire data files to
9     an equivalent RADIANCE scene description. The light source geometry
10     will always be centered at the origin aimed in the negative Z
11     direction, with the 0 degree plane along the x-axis\(emthe IES
12     photometric horizontal or length. The IES width is oriented along
13     the y axis, and the IES up becomes the RADIANCE z-axis.
14     .PP
15     The IES(NA) LM-63 standard provides a limited range of light
16     source shapes (\(lqluminous openings\(rq), different in each
17     version of the standard. Of these shapes, \fIies2rad\fP supports
18     rectangles, boxes, points (as 1mm spheres), disks (as 1mm high
19     vertical cylinders), vertical cylinders, and spheres. Some versions
20     of the standard also define ellipses, ellipsoids, and horizontal
21     cylinders. \fIIes2rad\fP will approximate near-circular ellipses
22     as disks, near-spherical ellipsoids as spheres, and horizontal
23     cylinders as boxes.
24     .PP
25     The 1995 IES standard once included the materials and geometry
26     format (MGF) which can describe detailed luminaire and light
27     source geometry, but it was never used. \fIIes2rad\fP still supports
28     MGF.
29     .PP
30     \fIIes2rad\fP assigns light source colors based on information
31     in a lamp lookup table. Since most lamps are distinctly colored,
32 greg 1.1 it is often desirable to override this lookup procedure and use
33     a neutral value that will produced color-balanced renderings.
34 greg 1.5 In general, it is important to consider lamp color when an odd
35     assortment of fixture types is being used to illuminate the same
36     scene, and the rendering can always be balanced by \fBpfilt\fP(1)
37     to a specific white value later.
38     .SH "OPTIONS"
39     .TP
40     .BI "\-l" " libdir"
41     Set the library directory path to \fIlibdir\fP. This is where
42     all relative pathnames will begin for output file names. For
43     light sources that will be used by many people, this should be
44     set to some central location included in the RAYPATH environment
45     variable. The default is the current working directory.
46     .TP
47     .BI "\-p" " prefdir"
48     Set the library subdirectory path to \fIprefdir\fP. This is the
49     subdirectory from the library where all output files will be
50     placed. It is often most convenient to use a subdirectory for
51     the storage of light sources, since there tend to be many files
52     and placing them all in one directory is very messy. The default
53     value is the empty string.
54     .TP
55     .BI "\-o" " outname"
56     Set the output file name root to \fIoutname\fP. This overrides
57     the default output file name root which is the same as the input
58     file. This option may be used for only one input file, and is
59     required when reading data from the standard input.
60     .TP
61     .B "\-s"
62     Send the scene information to the standard output rather than
63     a separate file. This is appropriate when calling \fIies2rad\fP
64     from within a scene description via an inline command. The data
65     file(s) will still be written based on the output file name root,
66     but, since this information is unaffected by command line options,
67     it is safe to have multiple invocations of \fIies2rad\fP using
68     the same input file and different output options. The \fI\-s\fP
69 greg 1.1 option may be used for only one input file.
70     .TP
71 greg 1.5 .BI "\-d" " units"
72     Output dimensions are in \fIunits\fP, which is one of the letters
73     'm', 'c', 'f', or 'i' for meters, centimeters, feet or inches,
74     respectively. The letter specification may be followed by a slash
75     ('/') and an optional divisor. For example, \fI\-dm/1000\fP would
76     be millimeters. The default output is in meters, regardless of
77     the original units in the IES input file. Note that there is
78     no space in this option.
79     .TP
80     .BI "\-i" " rad"
81     Ignore the crude geometry given by the IES input file and use
82     instead an illum sphere with radius \fIrad\fP. This option may
83     be useful when the user wishes to add a more accurate geometric
84     description to the light source model, though this need is obviated
85     by the recent LM-63-1995 specification, which uses MGF detail
86     geometry. (See \fI\-g\fP option below.)
87     .TP
88     .B "\-g"
89     If the IES file contains MGF detail geometry, compile this geometry
90     into a separate octree and create a single instance referencing
91     it instead of including the converted geometry directly in the
92     Radiance output file. This can result in a considerable memory
93     savings for luminaires which are later duplicated many times
94     in a scene, though the appearance may suffer for certain luminaires
95     since the enclosed glow sources will not light the local geometry
96     as they would otherwise.
97     .TP
98     .BI "\-f" " lampdat"
99     Use \fIlampdat\fP instead of the default lamp lookup table (lamp.tab)
100     to map lamp names to xy chromaticity and lumen depreciation data.
101 greg 1.1 It is often helpful to have customized lookup tables for specific
102     manufacturers and applications.
103     .TP
104 greg 1.5 .BI "\-t" " lamp"
105     Use the given lamp type for all input files. Normally, \fIies2rad\fP
106 greg 1.1 looks at the header lines of the IES file to try and determine
107 greg 1.5 what lamp is being used in the fixture. If any of the lines is
108     matched by a pattern in the lamp lookup table (see the \fB\-f\fP
109     option above), that color and depreciation factor will be used
110     instead of the default (see the \fB\-c\fP and \fB\-u\fP options).
111     The \fIlamp\fP specification is also looked up in the lamp table
112     unless it is set to \(lqdefault\(rq, in which case the default
113     color is used instead.
114     .TP
115     .BI "\-c" " red grn blu"
116     Use the given color if the type of the lamp is unknown or the
117     \fB\-t\fP option is set to \(lqdefault\(rq. If unspecified, the
118     default color will be white.
119     .TP
120     .BI "\-u" " lamp"
121     Set the default lamp color according to the entry for \fIlamp\fP
122     in the lookup table (see the \fB\-f\fP option). This is the color
123     that will be used if the input specification does not match any
124     lamp type patterns. This option is used instead of the \fB\-c\fP
125     option.
126     .TP
127     .BI "\-m" " factor"
128     Multiply all output quantities by \fIfactor\fP. This is the best
129     way to scale fixture brightness for different lamps, but care
130 greg 1.1 should be taken when this option is applied to multiple files.
131 greg 1.5 .SH "EXIT STATUS"
132     0 if successful, 1 if not.
133     .SH "ENVIRONMENT"
134     .TP
135     RAYPATH
136     Colon-separated list of directories to search for lamp lookup
137     table
138     .SH "FILES"
139     The output files will be created in the current directory (no
140     matter which directory the input files came from) unless the
141     \fI\-l\fP or \fI\-p\fP options are used.
142     .TP
143     .RI "<" "luminaire" ">.ies"
144     The IES LM-63 input file. May also be from the standard input.
145     If the standard input is the source, the \fB-o\fP option must
146     be specified, to provide a filename.
147     .TP
148     .RI "<" "luminaire" ">.rad"
149     The RADIANCE scene description. May also be sent to the standard
150     output.
151     .TP
152     .RI "<" "luminaire" ">.dat"
153     The IES candela values.
154     .TP
155     .RI "<" "luminaire" ">+.dat"
156     The IES tilt data. If tilt data is not provided (it is mostly
157     needed for luminaires which use metal halide lamps), this file
158     is not generated.
159     .TP
160     .RI "<" "luminaire" ">.oct"
161     If the \fB-g\fP option is given, the compiled MGF geometry is
162     placed in this octree file.
163     .TP
164     .RI "<" "RAYPATH" ">/lamp.tab"
165     lamp table
166     .SH "EXAMPLES"
167     To convert a single IES data file in inches with color balanced
168     output and 15% lumen depreciation, creating the files \(lqfluor01.rad\(rq
169     and \(lqfluor01.dat\(rq in the current directory:
170     .RS 2n
171     .sp 0.25
172     ies2rad -di -t default -m .85 fluor01.ies
173     .sp 0.25
174     .RE
175     .PP
176     To convert three IES files of various types to tenths of a foot
177     and put them in the library \(lq/usr/local/lib/ray\(rq subdirectory
178     \(lqsource/ies\(rq:
179     .RS 2n
180     .sp 0.25
181     ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03
182     .sp 0.25
183     .RE
184 greg 1.1 .PP
185     To convert a single file and give the output a different name:
186 greg 1.5 .RS 2n
187     .sp 0.25
188     ies2rad -o fluorescent ies03
189     .sp 0.25
190     .RE
191     .SH "REFERENCES"
192     .TP
193     LM-63-86, LM-63-91, LM-63-95, LM-63-02, LM-63-19
194     \fIIES Standard File Format for the Electronic Transfer of Photometric
195     Data and Related Information\fP. IESNA - Lighting Measurement
196     and Testing. Illuminating Engineering Society, 1986, 1991, 1995,
197     2002, 2019.
198     .TP
199     LM-75-01
200     \fIGoniophotometer Types and Photometric Coordinates\fP. New
201     York: Illuminating Engineering Society of North America, 2001.
202     .TP
203     The Materials and Geometry Format
204     Greg Ward. \fIThe Materials and Geometry Format\fP <https://floyd.lbl.gov/mgf/mgfdoc.pdf>.
205     Lawrence Berkeley Laboratory, 1996.
206     .SH "AUTHOR"
207 greg 1.1 Greg Ward
208 greg 1.5 .SH "BUGS"
209     In pre-1991 standard IES files, all header lines will be examined
210     for a lamp table string match. In post-1991 standard files, only
211     those lamps with the [LAMP] or [LAMPCAT] keywords will be searched.
212     The first match found in the file is always the one used. This
213     method of assigning colors to fixtures is less than perfect,
214 greg 1.1 and the IES would do well to include explicit spectral information
215     somehow in their specification.
216     .PP
217 greg 1.5 Not all luminous openings defined in the IES standard are supported.
218     So far, however, we have yet to find IES files which use the
219     unsupported shapes.
220 greg 1.1 .SH "SEE ALSO"
221 greg 1.5 \fBlamp.tab\fP(5), \fBmgf2rad\fP(1), \fBoconv\fP(1), \fBpfilt\fP(1),
222     \fBrad2mgf\fP(1), \fBrpict\fP(1), \fBxform\fP(1)
