| 1 | greg | 1.5 | .\" RCSid "$Id$" |
| 2 |  |  | .TH IES2RAD "1" "2021-10-26" "Radiance" "Radiance Manual Pages" |
| 3 |  |  | .SH "NAME" |
| 4 |  |  | ies2rad \- convert IES luminaire data to RADIANCE description |
| 5 |  |  | .SH "SYNOPSIS" |
| 6 |  |  | \fBies2rad\fP [ \fIoptions\fP ] [ \fIfile file .\|.\|.\&\fP ] |
| 7 |  |  | .SH "DESCRIPTION" |
| 8 |  |  | \fIIes2rad\fP converts one or more IES luminaire data files to |
| 9 |  |  | an equivalent RADIANCE scene description. The light source geometry |
| 10 |  |  | will always be centered at the origin aimed in the negative Z |
| 11 |  |  | direction, with the 0 degree plane along the x-axis\(emthe IES |
| 12 |  |  | photometric horizontal or length. The IES width is oriented along |
| 13 |  |  | the y axis, and the IES up becomes the RADIANCE z-axis. |
| 14 |  |  | .PP |
| 15 |  |  | The IES(NA) LM-63 standard provides a limited range of light |
| 16 |  |  | source shapes (\(lqluminous openings\(rq), different in each |
| 17 |  |  | version of the standard. Of these shapes, \fIies2rad\fP supports |
| 18 |  |  | rectangles, boxes, points (as 1mm spheres), disks (as 1mm high |
| 19 |  |  | vertical cylinders), vertical cylinders, and spheres. Some versions |
| 20 |  |  | of the standard also define ellipses, ellipsoids, and horizontal |
| 21 |  |  | cylinders. \fIIes2rad\fP will approximate near-circular ellipses |
| 22 |  |  | as disks, near-spherical ellipsoids as spheres, and horizontal |
| 23 |  |  | cylinders as boxes. |
| 24 |  |  | .PP |
| 25 |  |  | The 1995 IES standard once included the materials and geometry |
| 26 |  |  | format (MGF) which can describe detailed luminaire and light |
| 27 |  |  | source geometry, but it was never used. \fIIes2rad\fP still supports |
| 28 |  |  | MGF. |
| 29 |  |  | .PP |
| 30 |  |  | \fIIes2rad\fP assigns light source colors based on information |
| 31 |  |  | in a lamp lookup table. Since most lamps are distinctly colored, |
| 32 | greg | 1.1 | it is often desirable to override this lookup procedure and use |
| 33 |  |  | a neutral value that will produced color-balanced renderings. |
| 34 | greg | 1.5 | In general, it is important to consider lamp color when an odd |
| 35 |  |  | assortment of fixture types is being used to illuminate the same |
| 36 |  |  | scene, and the rendering can always be balanced by \fBpfilt\fP(1) |
| 37 |  |  | to a specific white value later. |
| 38 |  |  | .SH "OPTIONS" |
| 39 |  |  | .TP |
| 40 |  |  | .BI "\-l" " libdir" |
| 41 |  |  | Set the library directory path to \fIlibdir\fP. This is where |
| 42 |  |  | all relative pathnames will begin for output file names. For |
| 43 |  |  | light sources that will be used by many people, this should be |
| 44 |  |  | set to some central location included in the RAYPATH environment |
| 45 |  |  | variable. The default is the current working directory. |
| 46 |  |  | .TP |
| 47 |  |  | .BI "\-p" " prefdir" |
| 48 |  |  | Set the library subdirectory path to \fIprefdir\fP. This is the |
| 49 |  |  | subdirectory from the library where all output files will be |
| 50 |  |  | placed. It is often most convenient to use a subdirectory for |
| 51 |  |  | the storage of light sources, since there tend to be many files |
| 52 |  |  | and placing them all in one directory is very messy. The default |
| 53 |  |  | value is the empty string. |
| 54 |  |  | .TP |
| 55 |  |  | .BI "\-o" " outname" |
| 56 |  |  | Set the output file name root to \fIoutname\fP. This overrides |
| 57 |  |  | the default output file name root which is the same as the input |
| 58 |  |  | file. This option may be used for only one input file, and is |
| 59 |  |  | required when reading data from the standard input. |
| 60 |  |  | .TP |
| 61 |  |  | .B "\-s" |
| 62 |  |  | Send the scene information to the standard output rather than |
| 63 |  |  | a separate file. This is appropriate when calling \fIies2rad\fP |
| 64 |  |  | from within a scene description via an inline command. The data |
| 65 |  |  | file(s) will still be written based on the output file name root, |
| 66 |  |  | but, since this information is unaffected by command line options, |
| 67 |  |  | it is safe to have multiple invocations of \fIies2rad\fP using |
| 68 |  |  | the same input file and different output options. The \fI\-s\fP |
| 69 | greg | 1.1 | option may be used for only one input file. |
| 70 |  |  | .TP |
| 71 | greg | 1.5 | .BI "\-d" " units" |
| 72 |  |  | Output dimensions are in \fIunits\fP, which is one of the letters |
| 73 |  |  | 'm', 'c', 'f', or 'i' for meters, centimeters, feet or inches, |
| 74 |  |  | respectively. The letter specification may be followed by a slash |
| 75 |  |  | ('/') and an optional divisor. For example, \fI\-dm/1000\fP would |
| 76 |  |  | be millimeters. The default output is in meters, regardless of |
| 77 |  |  | the original units in the IES input file. Note that there is |
| 78 |  |  | no space in this option. |
| 79 |  |  | .TP |
| 80 |  |  | .BI "\-i" " rad" |
| 81 |  |  | Ignore the crude geometry given by the IES input file and use |
| 82 |  |  | instead an illum sphere with radius \fIrad\fP. This option may |
| 83 |  |  | be useful when the user wishes to add a more accurate geometric |
| 84 |  |  | description to the light source model, though this need is obviated |
| 85 |  |  | by the recent LM-63-1995 specification, which uses MGF detail |
| 86 |  |  | geometry. (See \fI\-g\fP option below.) |
| 87 |  |  | .TP |
| 88 |  |  | .B "\-g" |
| 89 |  |  | If the IES file contains MGF detail geometry, compile this geometry |
| 90 |  |  | into a separate octree and create a single instance referencing |
| 91 |  |  | it instead of including the converted geometry directly in the |
| 92 |  |  | Radiance output file. This can result in a considerable memory |
| 93 |  |  | savings for luminaires which are later duplicated many times |
| 94 |  |  | in a scene, though the appearance may suffer for certain luminaires |
| 95 |  |  | since the enclosed glow sources will not light the local geometry |
| 96 |  |  | as they would otherwise. |
| 97 |  |  | .TP |
| 98 |  |  | .BI "\-f" " lampdat" |
| 99 |  |  | Use \fIlampdat\fP instead of the default lamp lookup table (lamp.tab) |
| 100 |  |  | to map lamp names to xy chromaticity and lumen depreciation data. |
| 101 | greg | 1.1 | It is often helpful to have customized lookup tables for specific |
| 102 |  |  | manufacturers and applications. |
| 103 |  |  | .TP |
| 104 | greg | 1.5 | .BI "\-t" " lamp" |
| 105 |  |  | Use the given lamp type for all input files. Normally, \fIies2rad\fP |
| 106 | greg | 1.1 | looks at the header lines of the IES file to try and determine |
| 107 | greg | 1.5 | what lamp is being used in the fixture. If any of the lines is |
| 108 |  |  | matched by a pattern in the lamp lookup table (see the \fB\-f\fP |
| 109 |  |  | option above), that color and depreciation factor will be used |
| 110 |  |  | instead of the default (see the \fB\-c\fP and \fB\-u\fP options). |
| 111 |  |  | The \fIlamp\fP specification is also looked up in the lamp table |
| 112 |  |  | unless it is set to \(lqdefault\(rq, in which case the default |
| 113 |  |  | color is used instead. |
| 114 |  |  | .TP |
| 115 |  |  | .BI "\-c" " red grn blu" |
| 116 |  |  | Use the given color if the type of the lamp is unknown or the |
| 117 |  |  | \fB\-t\fP option is set to \(lqdefault\(rq. If unspecified, the |
| 118 |  |  | default color will be white. |
| 119 |  |  | .TP |
| 120 |  |  | .BI "\-u" " lamp" |
| 121 |  |  | Set the default lamp color according to the entry for \fIlamp\fP |
| 122 |  |  | in the lookup table (see the \fB\-f\fP option). This is the color |
| 123 |  |  | that will be used if the input specification does not match any |
| 124 |  |  | lamp type patterns. This option is used instead of the \fB\-c\fP |
| 125 |  |  | option. |
| 126 |  |  | .TP |
| 127 |  |  | .BI "\-m" " factor" |
| 128 |  |  | Multiply all output quantities by \fIfactor\fP. This is the best |
| 129 |  |  | way to scale fixture brightness for different lamps, but care |
| 130 | greg | 1.1 | should be taken when this option is applied to multiple files. |
| 131 | greg | 1.5 | .SH "EXIT STATUS" |
| 132 |  |  | 0 if successful, 1 if not. |
| 133 |  |  | .SH "ENVIRONMENT" |
| 134 |  |  | .TP |
| 135 |  |  | RAYPATH |
| 136 |  |  | Colon-separated list of directories to search for lamp lookup |
| 137 |  |  | table |
| 138 |  |  | .SH "FILES" |
| 139 |  |  | The output files will be created in the current directory (no |
| 140 |  |  | matter which directory the input files came from) unless the |
| 141 |  |  | \fI\-l\fP or \fI\-p\fP options are used. |
| 142 |  |  | .TP |
| 143 |  |  | .RI "<" "luminaire" ">.ies" |
| 144 |  |  | The IES LM-63 input file. May also be from the standard input. |
| 145 |  |  | If the standard input is the source, the \fB-o\fP option must |
| 146 |  |  | be specified, to provide a filename. |
| 147 |  |  | .TP |
| 148 |  |  | .RI "<" "luminaire" ">.rad" |
| 149 |  |  | The RADIANCE scene description. May also be sent to the standard |
| 150 |  |  | output. |
| 151 |  |  | .TP |
| 152 |  |  | .RI "<" "luminaire" ">.dat" |
| 153 |  |  | The IES candela values. |
| 154 |  |  | .TP |
| 155 |  |  | .RI "<" "luminaire" ">+.dat" |
| 156 |  |  | The IES tilt data. If tilt data is not provided (it is mostly |
| 157 |  |  | needed for luminaires which use metal halide lamps), this file |
| 158 |  |  | is not generated. |
| 159 |  |  | .TP |
| 160 |  |  | .RI "<" "luminaire" ">.oct" |
| 161 |  |  | If the \fB-g\fP option is given, the compiled MGF geometry is |
| 162 |  |  | placed in this octree file. |
| 163 |  |  | .TP |
| 164 |  |  | .RI "<" "RAYPATH" ">/lamp.tab" |
| 165 |  |  | lamp table |
| 166 |  |  | .SH "EXAMPLES" |
| 167 |  |  | To convert a single IES data file in inches with color balanced |
| 168 |  |  | output and 15% lumen depreciation, creating the files \(lqfluor01.rad\(rq |
| 169 |  |  | and \(lqfluor01.dat\(rq in the current directory: |
| 170 |  |  | .RS 2n |
| 171 |  |  | .sp 0.25 |
| 172 |  |  | ies2rad -di -t default -m .85 fluor01.ies |
| 173 |  |  | .sp 0.25 |
| 174 |  |  | .RE |
| 175 |  |  | .PP |
| 176 |  |  | To convert three IES files of various types to tenths of a foot |
| 177 |  |  | and put them in the library \(lq/usr/local/lib/ray\(rq subdirectory |
| 178 |  |  | \(lqsource/ies\(rq: |
| 179 |  |  | .RS 2n |
| 180 |  |  | .sp 0.25 |
| 181 |  |  | ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03 |
| 182 |  |  | .sp 0.25 |
| 183 |  |  | .RE |
| 184 | greg | 1.1 | .PP |
| 185 |  |  | To convert a single file and give the output a different name: |
| 186 | greg | 1.5 | .RS 2n |
| 187 |  |  | .sp 0.25 |
| 188 |  |  | ies2rad -o fluorescent ies03 |
| 189 |  |  | .sp 0.25 |
| 190 |  |  | .RE |
| 191 |  |  | .SH "REFERENCES" |
| 192 |  |  | .TP |
| 193 |  |  | LM-63-86, LM-63-91, LM-63-95, LM-63-02, LM-63-19 |
| 194 |  |  | \fIIES Standard File Format for the Electronic Transfer of Photometric |
| 195 |  |  | Data and Related Information\fP. IESNA - Lighting Measurement |
| 196 |  |  | and Testing. Illuminating Engineering Society, 1986, 1991, 1995, |
| 197 |  |  | 2002, 2019. |
| 198 |  |  | .TP |
| 199 |  |  | LM-75-01 |
| 200 |  |  | \fIGoniophotometer Types and Photometric Coordinates\fP. New |
| 201 |  |  | York: Illuminating Engineering Society of North America, 2001. |
| 202 |  |  | .TP |
| 203 |  |  | The Materials and Geometry Format |
| 204 |  |  | Greg Ward. \fIThe Materials and Geometry Format\fP <https://floyd.lbl.gov/mgf/mgfdoc.pdf>. |
| 205 |  |  | Lawrence Berkeley Laboratory, 1996. |
| 206 |  |  | .SH "AUTHOR" |
| 207 | greg | 1.1 | Greg Ward |
| 208 | greg | 1.5 | .SH "BUGS" |
| 209 |  |  | In pre-1991 standard IES files, all header lines will be examined |
| 210 |  |  | for a lamp table string match. In post-1991 standard files, only |
| 211 |  |  | those lamps with the [LAMP] or [LAMPCAT] keywords will be searched. |
| 212 |  |  | The first match found in the file is always the one used. This |
| 213 |  |  | method of assigning colors to fixtures is less than perfect, |
| 214 | greg | 1.1 | and the IES would do well to include explicit spectral information |
| 215 |  |  | somehow in their specification. |
| 216 |  |  | .PP |
| 217 | greg | 1.5 | Not all luminous openings defined in the IES standard are supported. |
| 218 |  |  | So far, however, we have yet to find IES files which use the |
| 219 |  |  | unsupported shapes. |
| 220 | greg | 1.1 | .SH "SEE ALSO" |
| 221 | greg | 1.5 | \fBlamp.tab\fP(5), \fBmgf2rad\fP(1), \fBoconv\fP(1), \fBpfilt\fP(1), |
| 222 |  |  | \fBrad2mgf\fP(1), \fBrpict\fP(1), \fBxform\fP(1) |
