| 1 | greg | 1.2 | .\" RCSid "$Id$" |
| 2 | greg | 1.1 | .TH IES2RAD 1 6/14/96 RADIANCE |
| 3 |  |  | .SH NAME |
| 4 |  |  | ies2rad - convert IES luminaire data to RADIANCE description |
| 5 |  |  | .SH SYNOPSIS |
| 6 |  |  | .B ies2rad |
| 7 |  |  | [ |
| 8 |  |  | .B options |
| 9 |  |  | ] |
| 10 |  |  | [ |
| 11 |  |  | .B input .. |
| 12 |  |  | ] |
| 13 |  |  | .SH DESCRIPTION |
| 14 |  |  | .I Ies2rad |
| 15 |  |  | converts one or more IES luminaire data files to the equivalent RADIANCE |
| 16 |  |  | scene description. |
| 17 |  |  | The light source geometry will always be centered at the origin aimed |
| 18 |  |  | in the negative z direction, with the 0 degree plane along the x axis. |
| 19 |  |  | Usually, two output files will be created for every input file, one |
| 20 |  |  | scene file (with a ".rad" suffix) and one data file (with a ".dat" |
| 21 |  |  | suffix). |
| 22 |  |  | If the IES input file includes tilt data, then another data file |
| 23 |  |  | will be created (with a "+.dat" suffix). |
| 24 |  |  | If the |
| 25 |  |  | .I \-s |
| 26 |  |  | option is used, the scene data will be sent to the standard output |
| 27 |  |  | instead of being written to a file. |
| 28 |  |  | Since the data file does not change with other options to |
| 29 |  |  | .I ies2rad, |
| 30 |  |  | this is a convenient way to specify different lamp colors and |
| 31 |  |  | multipliers inline in a scene description. |
| 32 |  |  | If the |
| 33 |  |  | .I \-g |
| 34 |  |  | option is used, then an octree file will be created (with the ".oct" |
| 35 |  |  | suffix). |
| 36 |  |  | The root portion of the output file names will be the same as the |
| 37 |  |  | corresponding input file, unless the |
| 38 |  |  | .I \-o |
| 39 |  |  | option is used. |
| 40 |  |  | The output files will be created in the current directory (no matter |
| 41 |  |  | which directory the input files came from) unless the |
| 42 |  |  | .I \-l |
| 43 |  |  | or |
| 44 |  |  | .I \-p |
| 45 |  |  | options are used. |
| 46 |  |  | .PP |
| 47 |  |  | .I Ies2rad |
| 48 |  |  | assigns light source colors based on information in a lamp lookup table. |
| 49 |  |  | Since most lamps are distinctly colored, |
| 50 |  |  | it is often desirable to override this lookup procedure and use |
| 51 |  |  | a neutral value that will produced color-balanced renderings. |
| 52 |  |  | In general, it is important to consider lamp color when an odd assortment |
| 53 |  |  | of fixture types is being used to illuminate the same scene, and |
| 54 |  |  | the rendering can always be balanced by pfilt(1) to a specific white value |
| 55 |  |  | later. |
| 56 |  |  | .TP 10n |
| 57 |  |  | .BI -l \ libdir |
| 58 |  |  | Set the library directory path to |
| 59 |  |  | .I libdir. |
| 60 |  |  | This is where all relative pathnames will begin for output file names. |
| 61 |  |  | For light sources that will be used by many people, this should be |
| 62 |  |  | set to some central location included in the RAYPATH environment variable. |
| 63 |  |  | The default is the current working directory. |
| 64 |  |  | .TP |
| 65 |  |  | .BI -p \ prefdir |
| 66 |  |  | Set the library subdirectory path to |
| 67 |  |  | .I prefdir. |
| 68 |  |  | This is the subdirectory from the library where all output files will |
| 69 |  |  | be placed. |
| 70 |  |  | It is often most convenient to use a subdirectory for the storage of |
| 71 |  |  | light sources, since there tend to be many files and placing them all |
| 72 |  |  | in one directory is very messy. |
| 73 |  |  | The default value is the empty string. |
| 74 |  |  | .TP |
| 75 |  |  | .BI -o \ outname |
| 76 |  |  | Set the output file name root to |
| 77 |  |  | .I outname. |
| 78 |  |  | This overrides the default output file name root which is the same as the |
| 79 |  |  | input file. |
| 80 |  |  | This option may be used for only one input file, and is required when |
| 81 |  |  | reading data from the standard input. |
| 82 |  |  | .TP |
| 83 |  |  | .BR -s |
| 84 |  |  | Send the scene information to the standard output rather than a |
| 85 |  |  | separate file. |
| 86 |  |  | This is appropriate when calling |
| 87 |  |  | .I ies2rad |
| 88 |  |  | from within a scene description via an inline command. |
| 89 |  |  | The data file(s) will still be written based on the output file name |
| 90 |  |  | root, but since this information is unaffected by command line options, |
| 91 |  |  | it is safe to have multiple invocations of |
| 92 |  |  | .I ies2rad |
| 93 |  |  | using the same input file and different output options. |
| 94 |  |  | The |
| 95 |  |  | .I \-s |
| 96 |  |  | option may be used for only one input file. |
| 97 |  |  | .TP |
| 98 |  |  | .BI -d units |
| 99 |  |  | Output dimensions are in |
| 100 |  |  | .I units, |
| 101 |  |  | which is one of the letters 'm', 'c', 'f', or 'i' for meters, |
| 102 |  |  | centimeters, feet or inches, respectively. |
| 103 |  |  | The letter specification may be followed by a slash ('/') and an |
| 104 |  |  | optional divisor. |
| 105 |  |  | For example, |
| 106 |  |  | .I \-dm/1000 |
| 107 |  |  | would be millimeters. |
| 108 |  |  | The default output is in meters, regardless of the original units in |
| 109 |  |  | the IES input file. |
| 110 |  |  | Note that there is no space in this option. |
| 111 |  |  | .TP |
| 112 |  |  | .BI -i \ rad |
| 113 |  |  | Ignore the crude geometry given by the IES input file and use instead an illum |
| 114 |  |  | sphere with radius |
| 115 |  |  | .I rad. |
| 116 |  |  | This option may be useful when the user wishes to add a more accurate |
| 117 |  |  | geometric description to the light source model, though this need |
| 118 |  |  | is obviated by the recent LM-63-1995 specification, which uses MGF |
| 119 |  |  | detail geometry. |
| 120 |  |  | (See |
| 121 |  |  | .I \-g |
| 122 |  |  | option below.)\0 |
| 123 |  |  | .TP |
| 124 |  |  | .BR -g |
| 125 |  |  | If the IES file contains MGF detail geometry, compile this geometry into |
| 126 |  |  | a separate octree and create a single instance referencing it |
| 127 |  |  | instead of including the converted geometry directly in the Radiance |
| 128 |  |  | output file. |
| 129 |  |  | This can result in a considerable memory savings for luminaires |
| 130 |  |  | which are later duplicated many times in a scene, though the |
| 131 |  |  | appearance may suffer for certain luminaires since the enclosed glow |
| 132 |  |  | sources will not light the local geometry as they would otherwise. |
| 133 |  |  | .TP |
| 134 |  |  | .BI -f \ lampdat |
| 135 |  |  | Use |
| 136 |  |  | .I lampdat |
| 137 |  |  | instead of the default lamp lookup table (lamp.tab) to map lamp |
| 138 |  |  | names to xy chromaticity and lumen depreciation data. |
| 139 |  |  | It is often helpful to have customized lookup tables for specific |
| 140 |  |  | manufacturers and applications. |
| 141 |  |  | .TP |
| 142 |  |  | .BI -t \ lamp |
| 143 |  |  | Use the given lamp type for all input files. |
| 144 |  |  | Normally, |
| 145 |  |  | .I ies2rad |
| 146 |  |  | looks at the header lines of the IES file to try and determine |
| 147 |  |  | what lamp is being used in the fixture. |
| 148 |  |  | If any of the lines is matched by a pattern in the lamp lookup |
| 149 |  |  | table (see the -f option above), that color and depreciation factor will |
| 150 |  |  | be used instead of the default (see the -c and -u options). |
| 151 |  |  | The |
| 152 |  |  | .I lamp |
| 153 |  |  | specification is also looked up in the lamp table unless it is |
| 154 |  |  | set to "default", in which case the default color is used instead. |
| 155 |  |  | .TP |
| 156 |  |  | .BI -c " red grn blu" |
| 157 |  |  | Use the given color if the type of the lamp is unknown or |
| 158 |  |  | the -t option is set to "default". |
| 159 |  |  | If unspecified, the default color will be white. |
| 160 |  |  | .TP |
| 161 |  |  | .BI -u \ lamp |
| 162 |  |  | Set the default lamp color according to the entry for |
| 163 |  |  | .I lamp |
| 164 |  |  | in the lookup table (see the -f option). |
| 165 |  |  | This is the color that will be used if the input specification |
| 166 |  |  | does not match any lamp type patterns. |
| 167 |  |  | This option is used instead of the -c option. |
| 168 |  |  | .TP |
| 169 |  |  | .BI -m \ factor |
| 170 |  |  | Multiply all output quantities by |
| 171 |  |  | .I factor. |
| 172 |  |  | This is the best way to scale fixture brightness for different lamps, but care |
| 173 |  |  | should be taken when this option is applied to multiple files. |
| 174 |  |  | .SH EXAMPLE |
| 175 |  |  | To convert a single IES data file in inches with color balanced output |
| 176 |  |  | and 15% lumen depreciation, |
| 177 |  |  | creating the files "fluor01.rad" and "fluor01.dat" in the current directory: |
| 178 |  |  | .IP "" .2i |
| 179 |  |  | ies2rad -di -t default -m .85 fluor01.ies |
| 180 |  |  | .PP |
| 181 |  |  | To convert three IES files of various types to tenths of a foot and put |
| 182 |  |  | them in the library "/usr/local/lib/ray" subdirectory "source/ies": |
| 183 |  |  | .IP "" .2i |
| 184 |  |  | ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03 |
| 185 |  |  | .PP |
| 186 |  |  | To convert a single file and give the output a different name: |
| 187 |  |  | .IP "" .2i |
| 188 |  |  | ies2rad -o fluorescent ies03 |
| 189 |  |  | .SH ENVIRONMENT |
| 190 |  |  | RAYPATH         directories to search for lamp lookup table |
| 191 |  |  | .SH AUTHOR |
| 192 |  |  | Greg Ward |
| 193 |  |  | .SH BUGS |
| 194 |  |  | In pre-1991 standard IES files, all header lines will be examined |
| 195 |  |  | for a lamp table string match. |
| 196 |  |  | In post-1991 standard files, only those lamps with the [LAMP] or |
| 197 |  |  | [LAMPCAT] keywords will be searched. |
| 198 |  |  | The first match found in the file is always the one used. |
| 199 |  |  | This method of assigning colors to fixtures is less than perfect, |
| 200 |  |  | and the IES would do well to include explicit spectral information |
| 201 |  |  | somehow in their specification. |
| 202 |  |  | .PP |
| 203 |  |  | The IESNA LM-63 specification prior to 1995 provided three basic source |
| 204 |  |  | shapes, rectangular, round, and elliptical. |
| 205 |  |  | The details of these shapes is vague at best. |
| 206 |  |  | Rectangular sources will always be rectangular, but ies2rad will |
| 207 |  |  | approximate round sources as spherical if the height is close to |
| 208 |  |  | or greater than the width and length, and as a ring otherwise. |
| 209 |  |  | Elliptical sources are treated the same as round sources. |
| 210 |  |  | The 1995 standard rectifies this problem by including detailed |
| 211 |  |  | luminaire geometry as MGF data, though nothing in the standard |
| 212 |  |  | requires manufacturers to provide this information. |
| 213 |  |  | .SH "SEE ALSO" |
| 214 |  |  | mgf2rad(1), oconv(1), pfilt(1), rad2mgf(1), rpict(1), xform(1) |
