| 1 |
.\" RCSid "$Id: icalc.1,v 1.4 2019/06/10 13:56:52 greg Exp $"
| 2 |
.TH ICALC 1 2/3/95 RADIANCE
| 3 |
.SH NAME
| 4 |
icalc - interactive calculator
| 5 |
.SH SYNOPSIS
| 6 |
.B icalc
| 7 |
| 8 |
.B file
| 9 |
| 10 |
.SH DESCRIPTION
| 11 |
.I Icalc
| 12 |
is a algebraic calculator designed primarily for
| 13 |
interactive use.
| 14 |
Each formula definition
| 15 |
.I file
| 16 |
is read and compiled from the RADIANCE library where it is found.
| 17 |
The standard input is then read, expressions are evaluated
| 18 |
and results are sent to the standard output.
| 19 |
If a newline is escaped using a backslash, input is continued
| 20 |
on the next line.
| 21 |
.PP
| 22 |
An expression contains real numbers, variable names, function calls,
| 23 |
and the following operators:
| 24 |
.PP
| 25 |
| 26 |
.PP
| 27 |
Operators are evaluated left to right, except '^',
| 28 |
which is right associative.
| 29 |
Exponentiation has the highest precedence; multiplication and
| 30 |
division are evaluated before addition and subtraction.
| 31 |
Expressions can be grouped with parentheses.
| 32 |
Each result is assigned a number, which can be used in future expressions.
| 33 |
For example, the expression ($3*10) is the result of the
| 34 |
third calculation multiplied by ten.
| 35 |
A dollar sign by itself may be used for the previous result.
| 36 |
All values are double precision real.
| 37 |
.PP
| 38 |
In addition, variables and functions can be defined by the
| 39 |
user.
| 40 |
A variable definition has the form:
| 41 |
.PP
| 42 |
| 43 |
var = expression ;
| 44 |
| 45 |
.PP
| 46 |
Any instance of the variable in an expression will be replaced
| 47 |
with its definition.
| 48 |
A function definition has the form:
| 49 |
.PP
| 50 |
| 51 |
func(a1, a2, ..) = expression ;
| 52 |
| 53 |
.PP
| 54 |
The expression can contain instances of the function arguments
| 55 |
as well as other variables and functions.
| 56 |
Function names can be passed as arguments.
| 57 |
Recursive functions can be defined using calls to the defined
| 58 |
function or other functions calling the defined function.
| 59 |
.PP
| 60 |
To define a constant expression, simply replace the equals sign ('=')
| 61 |
with a colon (':') in a definition.
| 62 |
Constant expressions are evaluated only once, the first time they are used.
| 63 |
This avoids repeated evaluation of expressions whose values never change.
| 64 |
Ideally, a constant expression contains only numbers and references
| 65 |
to previously defined constant expressions and functions.
| 66 |
Constant function definitions are are
| 67 |
replaced by their value in any expression that uses them with constant
| 68 |
arguments.
| 69 |
All predefined functions and variables have the constant attribute.
| 70 |
Thus, "sin(PI/4)" in an expression would be immediately replaced by ".707108"
| 71 |
unless sin() or PI were redefined by the user.
| 72 |
(Note that redefining constant expressions is not a recommended practice!)\
| 73 |
.PP
| 74 |
A variable or function's definition can be displayed with the '?'
| 75 |
command:
| 76 |
.PP
| 77 |
? name
| 78 |
.PP
| 79 |
If no name is given, all definitions are printed.
| 80 |
The '>' command writes definitions to a file:
| 81 |
.PP
| 82 |
> file
| 83 |
.PP
| 84 |
Similarly, the '<' command loads definitions.
| 85 |
.PP
| 86 |
The following library of predefined functions and variables is provided:
| 87 |
.TP 10n
| 88 |
.BR PI
| 89 |
the ratio of a circle's circumference to its diameter.
| 90 |
.TP
| 91 |
.BR "if(test, then, else)"
| 92 |
if test is greater than zero,
| 93 |
then is evaluated, otherwise else is evaluated.
| 94 |
This function is necessary for recursive definitions.
| 95 |
.TP
| 96 |
.BR "select(N, a1, a2, ..)"
| 97 |
return aN (N is rounded to the nearest integer).
| 98 |
This function provides array capabilities.
| 99 |
If
| 100 |
.I N
| 101 |
is zero, the number of available arguments is returned.
| 102 |
.TP
| 103 |
.BR "rand(x)"
| 104 |
compute a random number between 0 and 1 based on x.
| 105 |
.TP
| 106 |
.BR "min(a1, a2, ..)"
| 107 |
return the minimum value from a list of arguments.
| 108 |
.TP
| 109 |
.BR "max(a1, a2, ..)"
| 110 |
return the maximum value from a list of arguments.
| 111 |
.TP
| 112 |
.BR "floor(x)"
| 113 |
return largest integer not greater than x.
| 114 |
.TP
| 115 |
.BR "ceil(x)"
| 116 |
return smallest integer not less than x.
| 117 |
.TP
| 118 |
.BR "sqrt(x)"
| 119 |
return square root of x.
| 120 |
.TP
| 121 |
.BR "exp(x)"
| 122 |
compute e to the power of x (e approx = 2.718281828).
| 123 |
.TP
| 124 |
.BR "log(x)"
| 125 |
compute the logarithm of x to the base e.
| 126 |
.TP
| 127 |
.BR "log10(x)"
| 128 |
compute the logarithm of x to the base 10.
| 129 |
.TP
| 130 |
.BR "sin(x), cos(x), tan(x)"
| 131 |
trigonometric functions.
| 132 |
.TP
| 133 |
.BR "asin(x), acos(x), atan(x)"
| 134 |
inverse trigonometric functions.
| 135 |
.TP
| 136 |
.BR "atan2(y, x)"
| 137 |
inverse tangent of y/x (range \-pi to pi).
| 138 |
.SH ENVIRONMENT
| 139 |
RAYPATH the directories to check for auxiliary files.
| 140 |
.SH AUTHOR
| 141 |
Greg Ward
| 142 |
.SH "SEE ALSO"
| 143 |
ev(1), rcalc(1), tabfunc(1)
