root/radiance/doc/man/man1/glrad.1
Revision: 1.6
Committed: Thu Apr 28 16:28:20 2016 UTC (9 years, 6 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 1.5: +6 -5 lines
Added listening for mouse wheel
1 .\" RCSid "$Id: glrad.1,v 1.5 2007/09/04 17:36:40 greg Exp $"
2 .TH GLRAD 1 6/10/98 RADIANCE
3 .SH NAME
4 glrad - render a RADIANCE scene using OpenGL
5 .SH SYNOPSIS
6 .B glrad
7 [
8 .B \-w
9 ][
10 .B \-b
11 ][
12 .B \-s
13 ][
14 .B \-S
15 ][
16 .B "\-v view"
17 ]
18 .B rfile
19 [
20 .B "VAR\=value .."
21 ]
22 .SH DESCRIPTION
23 .I Glrad
24 renders a Radiance scene description in OpenGL.
25 Its syntax and behavior is similar to
26 .I rad(1)
27 with the
28 .I \-o
29 option, where the output device is assumed to be an X11 server
30 with GLX extensions.
31 .PP
32 The
33 .I \-w
34 option turns off warnings.
35 The
36 .I \-s
37 option tells
38 .I glrad
39 to run
40 .I rad
41 silently, not echoing
42 .I oconv(1)
43 command.
44 The
45 .I \-b
46 option turns off back face visibility (i.e., enables back face culling).
47 This is equivalent to the
48 .I \-bv
49 option of
50 .I rpict(1)
51 and
52 .I rvu(1).
53 The
54 .I \-S
55 option turns on full-screen stereo for displays that support it.
56 (Be sure to run
57 .I /usr/gfx/setmon(1)
58 or its equivalent to set STR_TOP or STR_BOT, first.)\0
59 The
60 .I \-v
61 option may be used to specify a starting view, either by symbolic name
62 as entered in the
63 .I view
64 assignments in
65 .I rfile,
66 or by a complete view specification, enclosed in quotes.
67 If no view is specified, then the first standard view from
68 .I rfile
69 is used to start.
70 .PP
71 Variables permitted in
72 .I rfile
73 are described in the
74 .I rad
75 manual page.
76 Additional or overriding assignments may be given on the command line
77 following
78 .I rfile.
79 .PP
80 The view is controlled via the mouse and simple one-character commands,
81 listed below:
82 .TP 10n
83 .BR "(mouse)"
84 Modify the current view.
85 The mouse is used to control the current view in the following ways:
86 .sp
87 .nf
88 CONTROL MOUSE ACTION
89 (none) left Move forward towards cursor position
90 (none) right Move backward away from cursor position
91 (none) middle Rotate in place (usually safe)
92 (none) wheel-up Zoom in on current position
93 (non) wheel-dn Zoom out around current position
94 shift left Orbit left around cursor position
95 shift right Orbit right around cursor position
96 shift middle Orbit skyward
97 cntl middle Orbit earthward
98 .fi
99 .sp
100 For all movements but rotating in place, the cursor must be placed over some
101 bit of visible geometry, otherwise the program has no reference point from
102 which to work.
103 It is best to just experiment with these controls until you learn to fly
104 safely in your model.
105 And if you run into trouble, the 'l' command is very useful.
106 (See below.)\0
107 .TP
108 .BR '+'
109 Zoom in on the current cursor position.
110 .TP
111 .BR '-'
112 Zoom out from the current cursor position.
113 .TP
114 .BR 'l'
115 Return to the last saved view.
116 Each time a new command changes the current view, the last view
117 is saved, and may be recalled with this command.
118 Multiple uses of the same command (e.g., rotation, zoom) will
119 save only the view before the first such command.
120 This way, it is easy to get back to where you were before a sequence
121 of view changes.
122 .TP
123 .BR 'h'
124 Fix the head height.
125 All mouse-controlled view motions will be adjusted so that the head height
126 does not change (where vertical is determined by the current
127 view up vector).
128 .TP
129 .BR 'H'
130 Release the head height, allowing it to change again during mouse-controlled
131 movements.
132 .TP
133 .BR 'v'
134 Print the current view parameters to the standard output.
135 This is useful for finding out where you are, or for saving specific
136 views in a keyframe file for animations or returning to later.
137 .TP
138 .BR 'V'
139 Append the current view to the original
140 .I rfile.
141 This view will be unnamed, but can be referred to by number or the
142 user may add a name later with a text editor.
143 The current view number becomes the last standard view.
144 (See the 'n' and 'p' commands, below.)
145 .TP
146 .BR 'n'
147 Go to the next standard view stored in
148 .I rfile.
149 If the last view is currently displayed, then cycle to the first one.
150 .TP
151 .BR 'p'
152 Go to the previous standard view stored in
153 .I rfile.
154 If the first view is currently displayed, then cycle to the last one.
155 .TP
156 .BR 'q'
157 Quit
158 .I glrad.
159 This is the normal way to exit the program.
160 .SH AUTHOR
161 Greg Ward Larson
162 .SH BUGS
163 It would be nice if
164 .I glrad
165 set the appropriate video format for stereo viewing automatically,
166 but the process is different on different systems and there is no
167 single, sure-fire way to do it for all systems.
168 On systems that do not support stereo extensions, the program
169 may be compiled with the \-DNOSTEREO option, which will avoid
170 undefined symbol errors.
171 .SH "SEE ALSO"
172 chmod(1), getinfo(1), ls(1), objview(1), oconv(1), ps(1), rad(1),
173 ranimate(1), rhcopy(1), rholo(1), rpict(1), rtrace(1), rvu(1), setmon(1)
