| 1 | greg | 1.6 | .\" RCSid "$Id: glrad.1,v 1.5 2007/09/04 17:36:40 greg Exp $" |
| 2 | greg | 1.2 | .TH GLRAD 1 6/10/98 RADIANCE |
| 3 | greg | 1.1 | .SH NAME |
| 4 |  |  | glrad - render a RADIANCE scene using OpenGL |
| 5 |  |  | .SH SYNOPSIS |
| 6 |  |  | .B glrad |
| 7 |  |  | [ |
| 8 |  |  | .B \-w |
| 9 |  |  | ][ |
| 10 |  |  | .B \-b |
| 11 |  |  | ][ |
| 12 |  |  | .B \-s |
| 13 |  |  | ][ |
| 14 |  |  | .B \-S |
| 15 |  |  | ][ |
| 16 |  |  | .B "\-v view" |
| 17 |  |  | ] |
| 18 |  |  | .B rfile |
| 19 |  |  | [ |
| 20 |  |  | .B "VAR\=value .." |
| 21 |  |  | ] |
| 22 |  |  | .SH DESCRIPTION |
| 23 |  |  | .I Glrad |
| 24 |  |  | renders a Radiance scene description in OpenGL. |
| 25 |  |  | Its syntax and behavior is similar to |
| 26 |  |  | .I rad(1) |
| 27 |  |  | with the |
| 28 |  |  | .I \-o |
| 29 |  |  | option, where the output device is assumed to be an X11 server |
| 30 |  |  | with GLX extensions. |
| 31 |  |  | .PP |
| 32 |  |  | The |
| 33 |  |  | .I \-w |
| 34 |  |  | option turns off warnings. |
| 35 |  |  | The |
| 36 |  |  | .I \-s |
| 37 |  |  | option tells |
| 38 |  |  | .I glrad |
| 39 |  |  | to run |
| 40 |  |  | .I rad |
| 41 |  |  | silently, not echoing |
| 42 |  |  | .I oconv(1) |
| 43 |  |  | command. |
| 44 |  |  | The |
| 45 |  |  | .I \-b |
| 46 |  |  | option turns off back face visibility (i.e., enables back face culling). |
| 47 |  |  | This is equivalent to the |
| 48 |  |  | .I \-bv |
| 49 |  |  | option of |
| 50 |  |  | .I rpict(1) |
| 51 |  |  | and |
| 52 | greg | 1.4 | .I rvu(1). |
| 53 | greg | 1.1 | The |
| 54 |  |  | .I \-S |
| 55 |  |  | option turns on full-screen stereo for displays that support it. |
| 56 |  |  | (Be sure to run |
| 57 |  |  | .I /usr/gfx/setmon(1) |
| 58 |  |  | or its equivalent to set STR_TOP or STR_BOT, first.)\0 |
| 59 |  |  | The |
| 60 |  |  | .I \-v |
| 61 |  |  | option may be used to specify a starting view, either by symbolic name |
| 62 |  |  | as entered in the |
| 63 |  |  | .I view |
| 64 |  |  | assignments in |
| 65 |  |  | .I rfile, |
| 66 |  |  | or by a complete view specification, enclosed in quotes. |
| 67 |  |  | If no view is specified, then the first standard view from |
| 68 |  |  | .I rfile |
| 69 |  |  | is used to start. |
| 70 |  |  | .PP |
| 71 |  |  | Variables permitted in |
| 72 |  |  | .I rfile |
| 73 |  |  | are described in the |
| 74 |  |  | .I rad |
| 75 |  |  | manual page. |
| 76 |  |  | Additional or overriding assignments may be given on the command line |
| 77 |  |  | following |
| 78 |  |  | .I rfile. |
| 79 |  |  | .PP |
| 80 |  |  | The view is controlled via the mouse and simple one-character commands, |
| 81 |  |  | listed below: |
| 82 |  |  | .TP 10n |
| 83 |  |  | .BR "(mouse)" |
| 84 |  |  | Modify the current view. |
| 85 |  |  | The mouse is used to control the current view in the following ways: |
| 86 |  |  | .sp |
| 87 |  |  | .nf |
| 88 |  |  | CONTROL MOUSE   ACTION |
| 89 | greg | 1.6 | (none)  left            Move forward towards cursor position |
| 90 | greg | 1.1 | (none)  right   Move backward away from cursor position |
| 91 |  |  | (none)  middle  Rotate in place (usually safe) |
| 92 | greg | 1.6 | (none)  wheel-up        Zoom in on current position |
| 93 |  |  | (non)   wheel-dn        Zoom out around current position |
| 94 |  |  | shift   left            Orbit left around cursor position |
| 95 | greg | 1.1 | shift   right   Orbit right around cursor position |
| 96 |  |  | shift   middle  Orbit skyward |
| 97 | greg | 1.6 | cntl            middle  Orbit earthward |
| 98 | greg | 1.1 | .fi |
| 99 |  |  | .sp |
| 100 |  |  | For all movements but rotating in place, the cursor must be placed over some |
| 101 |  |  | bit of visible geometry, otherwise the program has no reference point from |
| 102 |  |  | which to work. |
| 103 |  |  | It is best to just experiment with these controls until you learn to fly |
| 104 |  |  | safely in your model. |
| 105 |  |  | And if you run into trouble, the 'l' command is very useful. |
| 106 |  |  | (See below.)\0 |
| 107 |  |  | .TP |
| 108 |  |  | .BR '+' |
| 109 |  |  | Zoom in on the current cursor position. |
| 110 |  |  | .TP |
| 111 |  |  | .BR '-' |
| 112 |  |  | Zoom out from the current cursor position. |
| 113 |  |  | .TP |
| 114 |  |  | .BR 'l' |
| 115 |  |  | Return to the last saved view. |
| 116 |  |  | Each time a new command changes the current view, the last view |
| 117 |  |  | is saved, and may be recalled with this command. |
| 118 |  |  | Multiple uses of the same command (e.g., rotation, zoom) will |
| 119 |  |  | save only the view before the first such command. |
| 120 |  |  | This way, it is easy to get back to where you were before a sequence |
| 121 |  |  | of view changes. |
| 122 |  |  | .TP |
| 123 |  |  | .BR 'h' |
| 124 |  |  | Fix the head height. |
| 125 |  |  | All mouse-controlled view motions will be adjusted so that the head height |
| 126 |  |  | does not change (where vertical is determined by the current |
| 127 |  |  | view up vector). |
| 128 |  |  | .TP |
| 129 |  |  | .BR 'H' |
| 130 |  |  | Release the head height, allowing it to change again during mouse-controlled |
| 131 |  |  | movements. |
| 132 |  |  | .TP |
| 133 |  |  | .BR 'v' |
| 134 |  |  | Print the current view parameters to the standard output. |
| 135 |  |  | This is useful for finding out where you are, or for saving specific |
| 136 |  |  | views in a keyframe file for animations or returning to later. |
| 137 |  |  | .TP |
| 138 |  |  | .BR 'V' |
| 139 |  |  | Append the current view to the original |
| 140 |  |  | .I rfile. |
| 141 |  |  | This view will be unnamed, but can be referred to by number or the |
| 142 |  |  | user may add a name later with a text editor. |
| 143 |  |  | The current view number becomes the last standard view. |
| 144 |  |  | (See the 'n' and 'p' commands, below.) |
| 145 |  |  | .TP |
| 146 |  |  | .BR 'n' |
| 147 |  |  | Go to the next standard view stored in |
| 148 |  |  | .I rfile. |
| 149 |  |  | If the last view is currently displayed, then cycle to the first one. |
| 150 |  |  | .TP |
| 151 |  |  | .BR 'p' |
| 152 |  |  | Go to the previous standard view stored in |
| 153 |  |  | .I rfile. |
| 154 |  |  | If the first view is currently displayed, then cycle to the last one. |
| 155 |  |  | .TP |
| 156 |  |  | .BR 'q' |
| 157 |  |  | Quit |
| 158 |  |  | .I glrad. |
| 159 |  |  | This is the normal way to exit the program. |
| 160 |  |  | .SH AUTHOR |
| 161 |  |  | Greg Ward Larson |
| 162 |  |  | .SH BUGS |
| 163 |  |  | It would be nice if |
| 164 |  |  | .I glrad |
| 165 |  |  | set the appropriate video format for stereo viewing automatically, |
| 166 |  |  | but the process is different on different systems and there is no |
| 167 |  |  | single, sure-fire way to do it for all systems. |
| 168 |  |  | On systems that do not support stereo extensions, the program |
| 169 | greg | 1.5 | may be compiled with the \-DNOSTEREO option, which will avoid |
| 170 | greg | 1.1 | undefined symbol errors. |
| 171 |  |  | .SH "SEE ALSO" |
| 172 |  |  | chmod(1), getinfo(1), ls(1), objview(1), oconv(1), ps(1), rad(1), |
| 173 | greg | 1.4 | ranimate(1), rhcopy(1), rholo(1), rpict(1), rtrace(1), rvu(1), setmon(1) |
