root/radiance/doc/man/man1/genworm.1
Revision: 1.4
Committed: Fri May 4 23:56:49 2018 UTC (7 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.3: +6 -1 lines
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: genworm.1,v 1.3 2004/01/01 19:31:45 greg Exp $"
2 greg 1.1 .TH GENWORM 1 11/15/93 RADIANCE
3     .SH NAME
4     genworm - generate a RADIANCE description of a functional worm
5     .SH SYNOPSIS
6     .B "genworm mat name 'x(t)' 'y(t)' 'z(t)' 'r(t)' nseg"
7     [
8     .B "\-e expr"
9     ][
10     .B "\-f file"
11     ]
12     .SH DESCRIPTION
13     .I Genworm
14     produces a RADIANCE scene description of a
15     worm defined by the parametric equations
16     .I x(t),
17     .I y(t),
18     .I z(t),
19     and
20     .I r(t)
21     (the radius).
22     .I T
23     will vary from 0 to 1 in steps of
24     .I 1/nseg.
25     The surface will be composed of
26     .I nseg
27     cones or cylinders and
28     .I nseg+1
29     spheres.
30     The expressions are of the same type used in RADIANCE
31     function files.
32     Auxiliary expressions and/or files may be specified
33     in any number of
34     .I \-e
35     and
36     .I \-f
37     options.
38 greg 1.4 The variable and function definitions in each
39     .I \-f source
40     file are read and compiled from the RADIANCE library where it is found.
41 greg 1.1 .SH EXAMPLE
42     To generate a banana:
43     .IP "" .2i
44     genworm yellow banana '0' '5*sin(t)' '5*cos(t)' '.4-(.5-t)*(.5-t)' 20
45 greg 1.4 .SH ENVIRONMENT
46     RAYPATH the directories to check for auxiliary files.
47 greg 1.1 .SH AUTHOR
48     Greg Ward
49     .SH BUGS
50     Since the worm is constructed of intersecting surfaces, only
51     opaque materials should be used with this object.
52     Also, a worm cannot double back inside itself without making a mess.
53     .SH "SEE ALSO"
54 greg 1.3 genbox(1), genrev(1), gensurf(1), icalc(1), rpict(1), rvu(1), xform(1)
