| 1 |
.\" RCSid "$Id: genworm.1,v 1.3 2004/01/01 19:31:45 greg Exp $" |
| 2 |
.TH GENWORM 1 11/15/93 RADIANCE |
| 3 |
.SH NAME |
| 4 |
genworm - generate a RADIANCE description of a functional worm |
| 5 |
.SH SYNOPSIS |
| 6 |
.B "genworm mat name 'x(t)' 'y(t)' 'z(t)' 'r(t)' nseg" |
| 7 |
| 8 |
.B "\-e expr" |
| 9 |
| 10 |
.B "\-f file" |
| 11 |
| 12 |
.SH DESCRIPTION |
| 13 |
.I Genworm |
| 14 |
produces a RADIANCE scene description of a |
| 15 |
worm defined by the parametric equations |
| 16 |
.I x(t), |
| 17 |
.I y(t), |
| 18 |
.I z(t), |
| 19 |
and |
| 20 |
.I r(t) |
| 21 |
(the radius). |
| 22 |
.I T |
| 23 |
will vary from 0 to 1 in steps of |
| 24 |
.I 1/nseg. |
| 25 |
The surface will be composed of |
| 26 |
.I nseg |
| 27 |
cones or cylinders and |
| 28 |
.I nseg+1 |
| 29 |
spheres. |
| 30 |
The expressions are of the same type used in RADIANCE |
| 31 |
function files. |
| 32 |
Auxiliary expressions and/or files may be specified |
| 33 |
in any number of |
| 34 |
.I \-e |
| 35 |
and |
| 36 |
.I \-f |
| 37 |
options. |
| 38 |
The variable and function definitions in each |
| 39 |
.I \-f source |
| 40 |
file are read and compiled from the RADIANCE library where it is found. |
| 41 |
.SH EXAMPLE |
| 42 |
To generate a banana: |
| 43 |
.IP "" .2i |
| 44 |
genworm yellow banana '0' '5*sin(t)' '5*cos(t)' '.4-(.5-t)*(.5-t)' 20 |
| 45 |
.SH ENVIRONMENT |
| 46 |
RAYPATH the directories to check for auxiliary files. |
| 47 |
.SH AUTHOR |
| 48 |
Greg Ward |
| 49 |
.SH BUGS |
| 50 |
Since the worm is constructed of intersecting surfaces, only |
| 51 |
opaque materials should be used with this object. |
| 52 |
Also, a worm cannot double back inside itself without making a mess. |
| 53 |
.SH "SEE ALSO" |
| 54 |
genbox(1), genrev(1), gensurf(1), icalc(1), rpict(1), rvu(1), xform(1) |
