root/radiance/doc/man/man1/genworm.1
Revision: 1.3
Committed: Thu Jan 1 19:31:45 2004 UTC (21 years, 10 months ago) by greg
CVS Tags: rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: genworm.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH GENWORM 1 11/15/93 RADIANCE
3     .SH NAME
4     genworm - generate a RADIANCE description of a functional worm
5     .SH SYNOPSIS
6     .B "genworm mat name 'x(t)' 'y(t)' 'z(t)' 'r(t)' nseg"
7     [
8     .B "\-e expr"
9     ][
10     .B "\-f file"
11     ]
12     .SH DESCRIPTION
13     .I Genworm
14     produces a RADIANCE scene description of a
15     worm defined by the parametric equations
16     .I x(t),
17     .I y(t),
18     .I z(t),
19     and
20     .I r(t)
21     (the radius).
22     .I T
23     will vary from 0 to 1 in steps of
24     .I 1/nseg.
25     The surface will be composed of
26     .I nseg
27     cones or cylinders and
28     .I nseg+1
29     spheres.
30     The expressions are of the same type used in RADIANCE
31     function files.
32     Auxiliary expressions and/or files may be specified
33     in any number of
34     .I \-e
35     and
36     .I \-f
37     options.
38     .SH EXAMPLE
39     To generate a banana:
40     .IP "" .2i
41     genworm yellow banana '0' '5*sin(t)' '5*cos(t)' '.4-(.5-t)*(.5-t)' 20
42     .SH AUTHOR
43     Greg Ward
44     .SH BUGS
45     Since the worm is constructed of intersecting surfaces, only
46     opaque materials should be used with this object.
47     Also, a worm cannot double back inside itself without making a mess.
48     .SH "SEE ALSO"
49 greg 1.3 genbox(1), genrev(1), gensurf(1), icalc(1), rpict(1), rvu(1), xform(1)
