root/radiance/doc/man/man1/genskyvec.1
Revision: 1.6
Committed: Wed Sep 17 22:40:49 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2P2
Changes since 1.5: +11 -2 lines
1 .\" RCSid $Id: genskyvec.1,v 1.5 2013/01/20 02:07:16 greg Exp $
2 .TH GENSKYVEC 1 12/09/09 RADIANCE
3 .SH NAME
4 genskyvec - compute patch radiance averages for a specific sky
5 .SH SYNOPSIS
6 .B genskyvec
7 [
8 .B "\-h"
9 ][
10 .B "\-m N"
11 ][
12 .B "\-c r g b"
13 ][
14 .B "\-d"
15 ]
16 .SH DESCRIPTION
17 .I Genskyvec
18 samples the
19 .I Radinace
20 sky description given on the standard input to generate a list of
21 average patch radiances.
22 If there is a sun in the description,
23 .I genskyvec
24 will include its contribution in the three nearest sky patches,
25 distributing energy according to centroid proximity.
26 .PP
27 By default,
28 .I genskyvec
29 divides the sky into 2305 patches, plus one patch for the ground.
30 This corresponds to Reinhart's extension of the Tregenza sky,
31 where the original 145 patches are subdivided into 16 subpatches,
32 except at the zenith.
33 A different subdivision may be specified via the
34 .I \-m
35 option.
36 The value given will be used to subdivide each dimension, so the
37 default of 4 yields almost 16 times as many patches
38 as the original Tregenza sky, which can be specified with
39 .I "\-m 1."
40 A higher resolution sky is generally better for daylight
41 coefficient analysis where solar position is important.
42 .PP
43 The
44 .I \-c
45 option may be used to specify a color for the sky.
46 The gray value should equal 1 for proper energy balance
47 The default sky color is
48 .I "\-c 0.960 1.004 1.118".
49 .PP
50 The
51 .I \-d
52 option may be used to produce a sun-only vector, with no sky contributions.
53 If a time of day is selected or sky type that has no sun, then a zero vector
54 is produced.
55 .PP
56 Normally, a header will be produced containing the number of rows and other
57 information required by
58 .I dctimestep(1).
59 The
60 .I \-h
61 option may be used to elide this information header, producing data values only.
62 .SH EXAMPLE
63 To generate 578 patches corresponding to a 2x2 subdivision of the
64 Tregenza sky on a sunny equinox noon:
65 .IP "" .2i
66 gensky 9 21 12 | genskyvec -m 2 > sky09_21_12.dat
67 .SH AUTHOR
68 Greg Ward
69 .SH "SEE ALSO"
70 dctimestep(1), genBSDF(1), gendaylit(1),
71 gendaymtx(1), gensky(1), rcollate(1), rcontrib(1), rmtxop(1), rtrace(1)
