root/radiance/doc/man/man1/genrev.1
Revision: 1.7
Committed: Fri May 4 23:56:49 2018 UTC (7 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.6: +6 -1 lines
1 .\" RCSid "$Id: genrev.1,v 1.6 2017/04/10 14:48:08 greg Exp $"
2 .TH GENREV 1 11/15/93 RADIANCE
3 .SH NAME
4 genrev - generate a RADIANCE description of surface of revolution
5 .SH SYNOPSIS
6 .B "genrev mat name 'z(t)' 'r(t)' nseg"
7 [
8 .B "\-e expr"
9 ][
10 .B "\-f file"
11 ][
12 .B \-s
13 ]
14 .SH DESCRIPTION
15 .I Genrev
16 produces a RADIANCE scene description of a
17 surface of revolution.
18 The object will be composed of
19 .I nseg
20 cones, cups, cylinders, tubes or rings
21 following the parametric curve defined by
22 .I z(t)
23 (height)
24 and
25 .I r(t)
26 (radius).
27 When
28 .I z
29 is increasing with t, the surface normal points outward.
30 When
31 .I z
32 is decreasing, the normal points inward.
33 The variable
34 .I t
35 used in the function expressions varies
36 from 0 to 1 in even steps of
37 .I 1/nseg.
38 The expressions are of the same type used in RADIANCE
39 function files.
40 Auxiliary expressions and/or files may be specified
41 in any number of
42 .I \-e
43 and
44 .I \-f
45 options.
46 The variable and function definitions in each
47 .I \-f source
48 file are read and compiled from the RADIANCE library where it is found.
49 The
50 .I \-s
51 option smooths the surfaces using Phong normal interpolation.
52 .SH EXAMPLE
53 To generate a torus with an inner radius of 1 and an outer radius
54 of 3:
55 .IP "" .2i
56 genrev steel torus 'sin(2*PI*t)' '2+cos(2*PI*t)' 32
57 .SH ENVIRONMENT
58 RAYPATH the directories to check for auxiliary files.
59 .SH AUTHOR
60 Greg Ward
61 .SH "SEE ALSO"
62 genbox(1), gencat(1), genprism(1), gensurf(1),
63 genworm(1), rcalc(1), rpict(1), rvu(1), xform(1)
