root/radiance/doc/man/man1/genprism.1
Revision: 1.3
Committed: Thu Jan 1 19:31:44 2004 UTC (21 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: genprism.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH GENPRISM 1 3/19/96 RADIANCE
3     .SH NAME
4     genprism - generate a RADIANCE description of a prism
5     .SH SYNOPSIS
6     .B "genprism mat name"
7     {
8     .B -
9     |
10     .B vfile
11     |
12     .B "N v1 v2 .. vN"
13     }
14     [
15     .B "\-l lvect"
16     ][
17     .B "\-r radius"
18     ][
19     .B \-c
20     ][
21     .B \-e
22     ]
23     .SH DESCRIPTION
24     .I Genprism
25     produces a RADIANCE scene description of a prism, or extruded polygon.
26     The polygon to extrude lies in the z==0 plane, and
27     is given as a list of (x,y) pairs on the
28     standard input (-), or from the file
29     .I vfile,
30     or on the command line preceded by the number of vertices,
31     .I N.
32     The order of the vertices and the extrusion vector
33     .I lvect
34     (default (0,0,1)) determine the surface orientations.
35     The surfaces that make up the prism will be modified by
36     .I mat
37     and their identifiers will begin with
38     .I name.
39     The
40     .I \-r
41     option may be used to round the corners of the object using spheres
42     and cylinders.
43     The
44     .I \-c
45     option inhibits generation of a face connecting the last vertex to the first.
46     The
47     .I \-e
48     option inhibits generation of the end polygons.
49     .SH EXAMPLE
50     To produce a equilateral triangular prism:
51     .IP "" .2i
52     genprism clear_plastic prism 3 0 0 .5 .866 1 0
53     .SH AUTHOR
54     Greg Ward
55     .SH BUGS
56     The rounding option only works for opaque prisms with outward facing
57     normals.
58     If the normals face inward, the appearance will be bizarre.
59     .SH "SEE ALSO"
60 greg 1.3 genbox(1), genrev(1), gensurf(1), genworm(1), rpict(1), rvu(1), xform(1)
