root/radiance/doc/man/man1/gendaymtx.1
Revision: 1.20
Committed: Thu Oct 23 23:34:59 2025 UTC (2 weeks, 1 day ago) by greg
Changes since 1.19: +3 -5 lines
docs: Added rxfluxmtx man page and updated others accordingly
# User Rev Content
1 greg 1.20 .\" RCSid $Id: gendaymtx.1,v 1.19 2025/02/26 20:39:28 greg Exp $
2 greg 1.1 .TH GENDAYMTX 1 01/19/13 RADIANCE
3     .SH NAME
4     gendaymtx - generate an annual Perez sky matrix from a weather tape
5     .SH SYNOPSIS
6     .B gendaymtx
7     [
8     .B "\-v"
9     ][
10 greg 1.6 .B "\-h"
11     ][
12 greg 1.10 .B "\-A"
13     ][
14 greg 1.11 .B "\-d|\-s|\-n"
15     ][
16 greg 1.14 .B "\-u"
17     ][
18 greg 1.11 .B "\-D sunfile"
19 greg 1.13 [
20 greg 1.12 .B "\-M sunmods"
21 greg 1.13 ]][
22 greg 1.2 .B "\-r deg"
23     ][
24 greg 1.1 .B "\-m N"
25     ][
26     .B "\-g r g b"
27     ][
28     .B "\-c r g b"
29     ][
30     .B "-o{f|d}"
31 greg 1.4 ][
32 greg 1.17 .B "\-O{0|1}"
33     ][
34     .B "\-i intvl"
35 greg 1.1 ]
36     [
37     .B "tape.wea"
38 greg 1.19 or
39     .B "tape.epw"
40 greg 1.1 ]
41     .SH DESCRIPTION
42     .I Gendaymtx
43     takes a weather tape as input and produces a matrix of sky patch
44     values using the Perez all-weather model.
45 greg 1.19 The weather tape may be in the simple ASCII format understood
46 greg 1.1 by DAYSIM, which contains a short header with the site parameters followed
47     by the month, day, standard time, direct normal and diffuse horizontal
48     irradiance values, one time step per line.
49 greg 1.19 Alternatively, a standard EPW (Energy Plus Weather) input may be provided,
50     in which case additional information such as the dew point temperature may
51     be used in the calculation.
52 greg 1.1 Each time step line is used to compute a column in the output matrix,
53     where rows correspond to sky patch positions, starting with 0 for
54     the ground and continuing to 145 for the zenith using the default
55     .I "\-m 1"
56     parameter setting.
57     .PP
58     Increasing the
59     .I \-m
60 greg 1.11 parameter yields a higher resolution
61 greg 1.1 sky using the Reinhart patch subdivision.
62     For example, setting
63     .I "\-m 4"
64     yields a sky with 2305 patches plus one patch for the ground.
65     Each matrix entry is in fact three values, corresponding to
66     red green and blue radiance channels (watts/sr/meter^2).
67     Thus, an hourly weather tape for an entire year would
68     yield 8760x3 (26280) values per output line (row).
69     .PP
70     The
71 greg 1.10 .I \-A
72     option tells
73     .I gendaymtx
74     to generate a single column corresponding to an average sky
75     computed over all the input time steps, rather than one
76     column per time step.
77     .PP
78     The
79 greg 1.1 .I \-c
80     option may be used to specify a color for the sky.
81 greg 1.7 The gray value should equal 1 for proper energy balance.
82 greg 1.1 The default sky color is
83     .I "\-c 0.960 1.004 1.118".
84     Similarly, the
85     .I \-g
86     option may be used to specify a ground color.
87     The default value is
88     .I "\-g 0.2 0.2 0.2"
89     corresponding to a 20% gray.
90     .PP
91 greg 1.16 If there is a sun in the description,
92     .I gendaymtx
93     will include its contribution in the four nearest sky patches,
94     distributing energy according to centroid proximity.
95 greg 1.1 The
96     .I \-d
97 greg 1.9 option may be used to produce a sun-only matrix, with no sky contributions,
98     and the ground patch also set to zero.
99 greg 1.1 Alternatively, the
100     .I \-s
101 greg 1.9 option may be used to exclude any direct solar component from the output,
102 greg 1.16 with the other sky and ground patches unaffected.
103 greg 1.1 .PP
104 greg 1.11 The
105 greg 1.13 .I \-u
106     option ignores input times when the sun is below the horizon.
107     This is a convenient way to average daylight hours only with the
108     .I \-A
109     option or to ensure that matrix entries correspond to solar positions
110     produced with the
111     .I \-D
112     option, described below.
113     .PP
114     The
115 greg 1.11 .I \-n
116 greg 1.13 option may be used if no matrix output is desired at all.
117 greg 1.11 This may be used to merely check the input, or in combination with the
118     .I \-D
119     option, below.
120     .PP
121     The
122     .I \-D
123     option may be used to specify an output file to contain a list of
124     solar positions and intensities corresponding to time steps in the
125 greg 1.15 weather tape where the sun has any portion above the horizon.
126 greg 1.12 Sun radiance values may be zero if the direct amount is zero on the input.
127     Sun modifiers and names will be indexed by the minute, numbered from
128     midnight, January 1st.
129     If a hyphen ('-') is given as the argument to
130     .I \-D,
131     then the sun descriptions will be directed to the standard output.
132     This implies the
133     .I \-n
134     option just described.
135     If the
136     .I \-M
137     option is given as well, it will be used to record the modifier
138     names used in the
139     .I \-D
140     output, for convenient input to
141 greg 1.20 .I rcontrib(1).
142 greg 1.11 .PP
143 greg 1.3 By default,
144     .I gendaymtx
145     assumes the positive Y-axis points north such that the first sky patch
146     is in the Y-axis direction on the horizon, the second patch is just
147     west of that, and so on spiraling around to the final patch near the zenith.
148 greg 1.1 The
149 greg 1.2 .I \-r
150     (or
151     .I \-rz)
152     option rotates the sky the specified number of degrees counter-clockwise
153 greg 1.3 about the zenith, i.e., west of north.
154 greg 1.2 This is in keeping with the effect of passing the output of
155     .I gensky(1)
156     or
157     .I gendaylit(1)
158     through
159     .I xform(1)
160     using a similar transform.
161     .PP
162     The
163 greg 1.17 .I \-i
164     option specifies the actual capture interval in minutes of the original
165     weather data.
166     Please see the man page for
167     .I gendaylit
168     to understand this correction, which is applied only near sunrise and
169     sunset.
170     .PP
171     The
172 greg 1.1 .I \-of
173     or
174     .I \-od
175     option may be used to specify binary float or double output, respectively.
176     This is much faster to write and to read, and is therefore preferred on
177     systems that support it.
178     (MS Windows is not one of them.)\0
179 greg 1.4 The
180     .I \-O1
181     option specifies that output should be total solar radiance rather
182     than visible radiance.
183 greg 1.6 The
184     .I \-h
185     option prevents the output of the usual header information.
186 greg 1.1 Finally, the
187     .I \-v
188     option will enable verbose reporting, which is mostly useful for
189     finding out how many time steps are actually in the weather tape.
190     .SH EXAMPLES
191     Produce an uncolored Tregenza sky matrix without solar direct:
192     .IP "" .2i
193     gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx
194     .PP
195     Produce an hourly, annual Reinhart sky matrix
196     with 2306 patches including solar contributions
197     and send float output to
198     .I dctimestep(1)
199     to compute a sensor value matrix:
200     .IP "" .2i
201     gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
202     .SH AUTHORS
203     Ian Ashdown wrote most of the code,
204     based on Jean-Jacques Delaunay's original gendaylit(1) implementation.
205     Greg Ward wrote the final parameter parsing and weather tape conversion.
206     .SH "SEE ALSO"
207 greg 1.18 dctimestep(1), genBSDF(1), gendaylit(1), gensdaymtx(1), gensky(1),
208     genskyvec(1), genssky(1),
209 greg 1.20 rcollate(1), rcontrib(1), rfluxmtx(1), rmtxop(1), rxfluxmtx(1), xform(1)
