root/radiance/doc/man/man1/gendaymtx.1
Wed Feb 26 20:39:28 2025 UTC (7 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.18: +7 -2 lines
Diff to previous 1.18
feat(gendaymtx): Added ability to read dew point from EPW input data
Mon Aug 5 17:23:56 2024 UTC (14 months, 2 weeks ago) by greg
Changes since 1.17: +4 -3 lines
Diff to previous 1.17
docs: Slight wording modifications and added links to other tools
Fri Apr 26 23:10:59 2024 UTC (17 months, 4 weeks ago) by greg
Changes since 1.16: +13 -2 lines
Diff to previous 1.16
fix(gendaymtx): Added -i option and improved consistency with gendaylit, thanks to Yongqing
Sat Aug 13 17:24:56 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.15: +6 -6 lines
Diff to previous 1.15
docs(gendaymtx): wording improvement
Wed Feb 17 02:30:08 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14
docs: typo
Fri Sep 11 16:53:57 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13
docs(gendaymtx): Added missing -u option from usage line
Sat Aug 15 03:28:56 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.12: +14 -4 lines
Diff to previous 1.12
feat(gendaymtx): added -u option for daylight hours only
Mon Apr 13 17:12:19 2020 UTC (5 years, 6 months ago) by greg
Changes since 1.11: +23 -3 lines
Diff to previous 1.11
Updates to gendaymtx requested by Ladybug Tools
Tue Jan 7 01:42:30 2020 UTC (5 years, 9 months ago) by greg
Changes since 1.10: +18 -3 lines
Diff to previous 1.10
Added -n and -D options to gendaymtx
Tue Jun 25 00:09:45 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.9: +11 -1 lines
Diff to previous 1.9
Added gendaymtx -A option to efficiently compute average skies
Tue May 28 15:19:17 2019 UTC (6 years, 4 months ago) by greg
Diff to previous 1.8
Clarified wording as recommended by Lars.
Thu May 24 15:21:15 2018 UTC (7 years, 5 months ago) by greg
Changes since 1.7: +5 -1 lines
Diff to previous 1.7
Added mention of solar energy being distributed into 4 nearest sky patches
Tue Jun 17 18:03:48 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 1.6
Hopeful fix to performance issue for gendaymtx under Windows
Fri May 30 00:00:54 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.5: +6 -1 lines
Diff to previous 1.5
Thu Sep 5 17:53:22 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.4: +3 -3 lines
Diff to previous 1.4
Tue Apr 30 17:05:27 2013 UTC (12 years, 5 months ago) by greg
Changes since 1.3: +7 -1 lines
Diff to previous 1.3
Added -O1 option to output total solar radiance
Tue Feb 5 19:31:40 2013 UTC (12 years, 8 months ago) by greg
Changes since 1.2: +7 -2 lines
Diff to previous 1.2
Added clarification about output directions
Tue Feb 5 06:00:19 2013 UTC (12 years, 8 months ago) by greg
Changes since 1.1: +19 -2 lines
Added -r option to gendaymtx for rotating the sky about the zenith
Sun Jan 20 02:07:16 2013 UTC (12 years, 9 months ago) by greg
Added documentation for new gendaymtx tool
