root/radiance/doc/man/man1/ev.1
Revision: 1.4
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: ev.1,v 1.3 2004/01/01 19:31:44 greg Exp $"
2 greg 1.1 .TH EV 1 10/28/96 RADIANCE
3     .SH NAME
4     ev - evaluate expressions
5     .SH SYNOPSIS
6     .B ev 'expr' ..
7     .SH DESCRIPTION
8     .I Ev
9     evaluates expressions given on the command line, and sends the
10     results to the standard output, one per line.
11     An expression contains real numbers, function calls,
12     and the following operators:
13     .PP
14     + - * / ^
15     .PP
16     Operators are evaluated left to right, except '^',
17     which is right associative.
18     Powers have the highest precedence; multiplication and
19     division are evaluated before addition and subtraction.
20     Expressions can be grouped with parentheses.
21     All values are double precision real.
22     .PP
23     The following library of functions is available:
24     .TP 10n
25     .BR "if(cond, then, else)"
26     if cond is greater than zero,
27     then is evaluated, otherwise else is evaluated.
28     .TP
29     .BR "select(N, a1, a2, ..)"
30     return aN (N is rounded to the nearest integer).
31     If
32     .I N
33     is zero, the number of available arguments is returned.
34     .TP
35     .BR "rand(x)"
36     compute a random number between 0 and 1 based on x.
37     .TP
38     .BR "floor(x)"
39     return largest integer not greater than x.
40     .TP
41     .BR "ceil(x)"
42     return smallest integer not less than x.
43     .TP
44     .BR "sqrt(x)"
45     return square root of x.
46     .TP
47     .BR "exp(x)"
48     compute e to the power of x (e approx = 2.718281828).
49     .TP
50     .BR "log(x)"
51     compute the logarithm of x to the base e.
52     .TP
53     .BR "log10(x)"
54     compute the logarithm of x to the base 10.
55     .TP
56     .BR "sin(x), cos(x), tan(x)"
57     trigonometric functions.
58     .TP
59     .BR "asin(x), acos(x), atan(x)"
60     inverse trigonometric functions.
61     .TP
62     .BR "atan2(y, x)"
63 greg 1.4 inverse tangent of y/x (range \-pi to pi).
64 greg 1.1 .SH EXAMPLE
65     To pass the square root of two and the sine of .5 to a program:
66     .IP "" .2i
67     program `ev 'sqrt(2)' 'sin(.5)'`
68     .SH AUTHOR
69     Greg Ward
70     .SH "SEE ALSO"
71 greg 1.3 icalc(1), rcalc(1)
