| 1 |
.\" RCSid "$Id: ev.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
| 2 |
.TH EV 1 10/28/96 RADIANCE |
| 3 |
.SH NAME |
| 4 |
ev - evaluate expressions |
| 5 |
.SH SYNOPSIS |
| 6 |
.B ev 'expr' .. |
| 7 |
.SH DESCRIPTION |
| 8 |
.I Ev |
| 9 |
evaluates expressions given on the command line, and sends the |
| 10 |
results to the standard output, one per line. |
| 11 |
An expression contains real numbers, function calls, |
| 12 |
and the following operators: |
| 13 |
.PP |
| 14 |
| 15 |
.PP |
| 16 |
Operators are evaluated left to right, except '^', |
| 17 |
which is right associative. |
| 18 |
Powers have the highest precedence; multiplication and |
| 19 |
division are evaluated before addition and subtraction. |
| 20 |
Expressions can be grouped with parentheses. |
| 21 |
All values are double precision real. |
| 22 |
.PP |
| 23 |
The following library of functions is available: |
| 24 |
.TP 10n |
| 25 |
.BR "if(cond, then, else)" |
| 26 |
if cond is greater than zero, |
| 27 |
then is evaluated, otherwise else is evaluated. |
| 28 |
.TP |
| 29 |
.BR "select(N, a1, a2, ..)" |
| 30 |
return aN (N is rounded to the nearest integer). |
| 31 |
If |
| 32 |
.I N |
| 33 |
is zero, the number of available arguments is returned. |
| 34 |
.TP |
| 35 |
.BR "rand(x)" |
| 36 |
compute a random number between 0 and 1 based on x. |
| 37 |
.TP |
| 38 |
.BR "floor(x)" |
| 39 |
return largest integer not greater than x. |
| 40 |
.TP |
| 41 |
.BR "ceil(x)" |
| 42 |
return smallest integer not less than x. |
| 43 |
.TP |
| 44 |
.BR "sqrt(x)" |
| 45 |
return square root of x. |
| 46 |
.TP |
| 47 |
.BR "exp(x)" |
| 48 |
compute e to the power of x (e approx = 2.718281828). |
| 49 |
.TP |
| 50 |
.BR "log(x)" |
| 51 |
compute the logarithm of x to the base e. |
| 52 |
.TP |
| 53 |
.BR "log10(x)" |
| 54 |
compute the logarithm of x to the base 10. |
| 55 |
.TP |
| 56 |
.BR "sin(x), cos(x), tan(x)" |
| 57 |
trigonometric functions. |
| 58 |
.TP |
| 59 |
.BR "asin(x), acos(x), atan(x)" |
| 60 |
inverse trigonometric functions. |
| 61 |
.TP |
| 62 |
.BR "atan2(y, x)" |
| 63 |
inverse tangent of y/x (range -pi to pi). |
| 64 |
.SH EXAMPLE |
| 65 |
To pass the square root of two and the sine of .5 to a program: |
| 66 |
.IP "" .2i |
| 67 |
program `ev 'sqrt(2)' 'sin(.5)'` |
| 68 |
.SH AUTHOR |
| 69 |
Greg Ward |
| 70 |
.SH "SEE ALSO" |
| 71 |
icalc(1), rcalc(1) |
